Old Oct 04, 2011, 12:20 PM
rcimports is offline
Find More Posts by rcimports
South Africa
Joined Oct 2005
Warthox, I think you deisgned those power distribution boards? Where they from?
I run power the same as you, all ESC's.
Dion
rcimports is offline Find More Posts by rcimports
Old Oct 05, 2011, 09:25 PM
bigbro3760 is offline
Find More Posts by bigbro3760
Joined May 2010
one problem i encountered with navi board is that with navi board on, motor seem not to spool in harmony. red led blinking. but with navi board off, it spools well
bigbro3760 is offline Find More Posts by bigbro3760
Old Oct 06, 2011, 09:36 AM
G2loq is offline
Find More Posts by G2loq
G2loq Chopper
Montreal - Québec - Canada
Joined Jul 2007
Did you do the "interference danse" ? ;-)
Mean the higher PCB support, solder the wire on the Power board, adding a UBEC, separate the Buzzer, Barometer reinforcement etc... yes it is an RTF module as written on the sell page ;-)
Not sure what the F means....
G2loq is offline Find More Posts by G2loq
Old Oct 07, 2011, 04:22 AM
Minsoo Kim is offline
Find More Posts by Minsoo Kim
Joined Apr 2008
Dear All
First, I'm very sorry for the inconvenience.
I will gladly accept any requests.
regarding GPS not function of some area,we have a through grasp of the problem.
we are checking the firmware and will post next week the PC Programmer that can confirm the status of compass and GPS signal.
I'll do my best to satisfy with our products.
I promise to live up to users expectations now and forever
Thanks in advance
Minsoo
Minsoo Kim is offline Find More Posts by Minsoo Kim
Old Oct 07, 2011, 04:32 AM
Njoro is offline
Find More Posts by Njoro
Joined Jan 2009
Originally Posted by Minsoo Kim View Post
Dear All
Thanks in advance
Minsoo
"as I said in a privious post we can depend on Mr Minsoo to resolve the issue" Am looking forward to getting my copter working as it should.
Njoro is offline Find More Posts by Njoro
Old Oct 07, 2011, 04:57 AM
South Africa
Joined Oct 2005
Yes, I've had problem before but allways sorted out, let's see...
Old Oct 07, 2011, 07:41 AM
G2loq is offline
G2loq Chopper
Joined Jul 2007
Welcome back Minsoo ! And thanks for the infos and the Hope :-)
Old Oct 09, 2011, 09:41 PM
Joined May 2010
done set up with my navi board.
stick centering - done
calibration of gps & compass - done
arming - done
calibration of gyro & acceleromater - done
tower, ubec, jumper, sponge on barometer - done
black board blue led & navi board red light on
gps blue led on
upon hover it stays for a while but after a few seconds it drifts to the left & i can't control the drift so no choice but to cut the throttle.
but with navi board off, it flies well. doing figure eight
Old Oct 10, 2011, 07:39 AM
wessiercgroups is offline
Find More Posts by wessiercgroups
South Africa, GP, Johannesburg
Joined Apr 2011
Minsoo Navi Board
arming - done
gps blue led on
Hi All
Just completed assembling and test flying my quad from Minsoo this week-end.
Update:
I've done all of the above and the LED status is the same as above.
Much the same problem everyone is encountering.
1. Altitude hold not to great. At times it just shoots straight up like a home sick angel. I have to land, turn system off and on and try again. When it does hold it drifts up and down about 3 to 4 meters and then just gets progressively worse.
2. Position Hold - heads for Korea like it's stolen. Here I tried the calibration of the Gyro and GPS different ways. Sometimes it heads north other times it heads south. I have not tried the beta 1.2. Will this weekend.
3. Sensitivity between Navi on and off differs so much that I have to redo the Roll / Pitch for each selection. When flying with Navi off there is a slight oscillation ( I’ve set it as low as possible here ) Switching then to Navi on the oscillation are so bad it nearly gets out of control.
4. With Navi on - quad will start drifting one way. I then trim her out so she is nice and steady - do a circuit - hover and the trims are out again. Have to re-trim constantly. It flies nothing like Minsoo's video on his website.
I also fly a home build tri-copter (FPV-
Tricopter 2 (3 min 29 sec)
) with a homemade controller ( 3 x HK401 stripped gyros and a ATMega168 micro processor ), programmed with Minsoo’s 2.2 code and it is rock solid.
For the amount of money I spent on Minsoo’s kit I was expecting much much more. I acknowledge the fact that he has confirmed the problem and is working on a solution. I have faith that he’ll sort it.
Is there anyone within the forum that can translate the Navi board manual into more accurate English. I.e. with the GPS/Gyro calibration it says – rotate 360 in roll ( forward and backwards ) Is this not left and right ?
wessiercgroups is offline Find More Posts by wessiercgroups
Old Oct 10, 2011, 08:17 AM
South Africa
Joined Oct 2005
ROFL, now that was funny!
Glad to see I'm not the only one with the "keep on trimming" issues, and I think it's only the 2 of us with Tricopters...
Old Oct 10, 2011, 08:33 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
Gives "return to home" a whole new meaning.
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Oct 10, 2011, 12:32 PM
Dingo745 is offline
Find More Posts by Dingo745
Dingo745's Avatar
Australia, SA, Second Valley
Joined Jul 2011
After spending well over $350 to get this sort of result, I'm definitely not laughing.
Sent from my generic using Tapatalk
Dingo745 is offline Find More Posts by Dingo745
Old Oct 11, 2011, 01:50 AM
JiGe is offline
Find More Posts by JiGe
JiGe's Avatar
France, Midi-Pyrénées, Mauvezin
Joined Sep 2004
Hi all
Now, I'm fixing the navi firmware. Before release the latest version.
please download the beta version and see the video for the compass initialization.
http://www.youtube.com/watch?v=4Q0424lNyoo
Minsoo
Hi
Would it be possible to add sub-titles?
thanks
JiGe is offline Find More Posts by JiGe
Old Oct 11, 2011, 09:38 AM
Dingo745 is offline
Dingo745's Avatar
Joined Jul 2011
Us English speaking people want ENGLISH instructions please.
Sent from my HTC Wildfire using Tapatalk
Old Oct 11, 2011, 10:21 AM
Centurion1 is offline
Find More Posts by Centurion1
Joined Sep 2011
let me see if I can redo that vid with better subtitle. or translated audio overlay . I will see if I can capture that video to my pc so I can do that.
Centurion1 is offline Find More Posts by Centurion1
