Australia, NSW, Kellyville Ridge
Joined Mar 2010
I would never bought mine as well! And some of you guys are still lucky to still have it. But looks like it's finally over for me. The naviboard took over control today, and I couldn't even return it back. I had maybe 10% of control - aileron/elevator stick. Felt like huge expo. I couldn't even stoped it flying away for me. When I started to loose my quad from my eye sight, I had to cut the throttle and say goodbye to it. It collapsed so badly on the end of the field right in to the building. I was luck that I didn't hurt any one or damage someone property. Well, the whole tower with all electronics plus motors completely destroyed, battery smashed etc. I'll post pics tomorrow. And let me remind you: I had stable red led light, with gps locked. Isolated power distributor plate, external no interference BEC, lifted kkboard, separated buzzer, isolated power from esc, rings - updated firmware and I couldn't even took control over my quad when it suddenly started to flyaway without my command. Spectrum dx8 So, 120% sure I have done everything correct, and it wasn't my fault at all.. And guess what- I'm not buying it again.. |
Montreal - Québec - Canada
Joined Jul 2007
And if no, where would you plug it ? Thanks in advance Pierre |
Joined Jul 2007
Instead of adding pcb support, can't we use an interference shield in aluminium for example ? Ower expensive and not working naviboard will be more protected. Because crash after crash, someone will one day let us know that it is not working because of our crash ! |
![]() In all fairness though, it could have been you're Tx/Rx? how is you're failsafe setup? Let's give Minsoo time to reply, his service is usually good. I'm allso not very happy but maybe he can change that... |
Joined Jul 2007
As I can see on your pictures you are not using a power board, your ESC cable are solder together to the battery plug, you do not have any PCB support 30 or 50mm... then no ugly tower. Not sure you also did the buzzer separation... You do not have UBEC and it is working perfectly ! Is it possible M. Minsoo is selling 2 brand of naviboard or have a defective batch ?... Than Minsoo, let us know why do we need a UBEC as written on your web page and where do we have to plug it ? Thanks in advance ! |
