Old Nov 23, 2011, 07:48 PM
Scorpick is offline
Find More Posts by Scorpick
Scorpick's Avatar
Россия, Москва, город Москва
Joined Nov 2011
hi
you are using the original adapter? (USB by Minsoo)
Thank you very much! Naviboard is flashed successfully - just reverse pins on the cable. USBtoCOM adapter is original.
Someone has been testing the Tricopter with Naviboard (with new firmware) in all modes? Moscow's winter is very cold and windy - i have not many silent hours for testing my tricopter. I would like to know - correctly works the new firmware on Tricopter or have some bugs?
Scorpick is offline Find More Posts by Scorpick
Old Nov 23, 2011, 11:41 PM
Njoro is offline
Find More Posts by Njoro
Joined Jan 2009
Sonar set up
Sonar Set Up For Flycam Navigation Board (10 min 58 sec)
Njoro is offline Find More Posts by Njoro
Old Nov 24, 2011, 02:45 AM
Technotron is online now
Find More Posts by Technotron
Shoop da whoop!
Technotron's Avatar
Joined Jan 2009
Listen to cafecubain, perhabls the cable layout of your adapter is different. Double-check it to make sure.
Technotron is online now Find More Posts by Technotron
Old Nov 24, 2011, 02:54 AM
cafecubain is offline
Find More Posts by cafecubain
cafecubain's Avatar
Spain (MÓlaga)
Joined Aug 2010
Originally Posted by Njoro View Post
hahahaha! The best thing about video is the credits, I love . Seriously, thanks Njoro for the tutorial, very instructive.!!
greetings!
enrique
cafecubain is offline Find More Posts by cafecubain
Old Nov 24, 2011, 05:38 AM
teramax is offline
Find More Posts by teramax
sorry, my english is bad
teramax's Avatar
Austria, Wien, Vienna
Joined Apr 2011
Thanks for the Tutorial!
Sponsored by Tupperware your Copter is?
teramax is offline Find More Posts by teramax
Old Nov 24, 2011, 05:48 AM
Shoop da whoop!
Technotron's Avatar
Joined Jan 2009
Great job Njoro
Old Nov 24, 2011, 08:30 AM
Njoro is offline
Joined Jan 2009
Thanks for the kind words.
Regards
Old Nov 24, 2011, 01:35 PM
leowie is offline
Find More Posts by leowie
Propellerhead
leowie's Avatar
Joined Dec 2008
Sonar set up
Thx!
leowie is offline Find More Posts by leowie
Old Nov 25, 2011, 12:34 AM
slides is offline
Find More Posts by slides
Joined Oct 2009
Hello ! I do not understand, why we need to tune Sonars pots to move it to working status. This is buggy job of Mr Minsoo. Sorry friends, but I have to say that we are using and buying once again the unfinished "wet" and uglish product. I guess for our free betatesting the real price is 100$ for Naviboard, not more.
For your information - I have the same curves of Sonar - Sonar still doesn't affect to height lock
At the end - did somebody do any tests with Sonars's PID values ?
slides is offline Find More Posts by slides
Old Nov 25, 2011, 06:52 AM
wessiercgroups is offline
Find More Posts by wessiercgroups
South Africa, GP, Johannesburg
Joined Apr 2011
For all the propellerheads out there - attached is the technical spec for the sonar board.
wessiercgroups is offline Find More Posts by wessiercgroups
Old Nov 26, 2011, 02:34 AM
Scorpick is offline
Scorpick's Avatar
Joined Nov 2011
Answer me please to two questions:
1) How to switch between sonar and barometer (or this is only auto mode)?
2) The operation of Calibration of Gyro and Accelerometer (Right the rudder stick for 3 seconds)
is necessary everytime if i change the battery, or once (For example on ideally horizontal surface) and
after any "power off" the Naviboard remember for ever maintain level? And after start on non-ideal ground
my multicopter still stable with my settings every time?
Old Nov 26, 2011, 03:31 AM
Shoop da whoop!
Technotron's Avatar
Joined Jan 2009
Sorry, I am not using the sonar, so I can only answer the last question. Accelerometer calibration is definitely stored. I made sure it was perfectly (or as good as) level with a bubble level. Right rudder stick and it will arm. Keep holding until first beep, then second beep and let go. All set up now :-)
Old Nov 26, 2011, 08:44 AM
Scorpick is offline
Scorpick's Avatar
Joined Nov 2011
Thanks Chris. I already wanted to paste bubble level on my tricopter
It is necessary to understand as to switch a sonar/barometer
Old Nov 26, 2011, 11:00 AM
leowie is offline
Propellerhead
leowie's Avatar
Joined Dec 2008
hi from Vienna.
ad 1) I think it's combined: both sonar + baro is on or off. In low altitudes sonar makes the job, in higher baro does.
ad 2) I do the right rudder stick procedure before any copter start, leveled.
Old Nov 26, 2011, 11:19 AM
Shoop da whoop!
Technotron's Avatar
Joined Jan 2009
Well if you can do the accelerometer initialization perfectly level every time, it's fine. But I can tell you from experience that you shouldn't have to. I am happy about that because it's hard to get your multi perfectly level in the field (of course depending on location).
