Belgium, Vlaams Gewest, Sint-Truiden
Joined Jul 2012
It also easier to break down stuff than give info that can help people with their problems.I never had any plane helicopter,whatsoever. I am now playing around for a good half year with the quad.
The first board was the blackboard v2 work good till a gyro broke. Got it replace by mr minsoo for the MCFC and also bought the navi board. If ya want a bargan go buy HK lcd board and flash it with the 1.5fw works great and if you crash its only 25usd. I got 2 of them to do crazzy. But yesterday i did a complete reset of the MCFC board set everything to default settings!LIKE IT COME OUT OF THE BOX.even the pid settings are for a quad with 230 pitch and roll. I got a 290 pitch and roll In between the rain showers went out for a lift.Pretty cold outside and heavy winds.
So mail Mr minsoo try work something out. Else buy the naza, and have a good flight. |
Joined Jul 2012
Well wen i didnt fly for more then a day i t would take a little longer for the gps to lock,
also the first time it went for days, magnetometer going good,bad,good, till i calibrated the magnetometer correct. So today was a windy days again but without rain and less coolder, so tried my 9.5 inch FPV monitor, still new to it and only flying for 5 months so bare zith me, but it works!!!!
Joined Jan 2009
I bought a Fie-yu Tech Dream Catcher ages ago that was too stable to fly around, it just kept fighting the controls to stay in the hover but after some complaints from the many customers they did eventually do an update and also it needed 2 capacitors to be removed from the PCB board. It flies better now but I haven't FPV it yet due to bad weather; NAZA was not in existence then. Testing the X4-Pro with AEE HD set to 720P
Regards |
Joined Jul 2012
@Artelian: no offence but there where alot of other controllers out there, what did you made you use this one? I have read alot of thread with pro and cons. Pid tuning isnt as easy buy just changing some numbers,alot of factors to consider to make it perfect because it seems that what you want,
I dont know how its with the previous board i only started from the blackboard2, hk v2.0 lcd and flycam MCFC. Didnt even know that a hobbyking board and nav work together. All i can says i get mine to work and dont see to osilate ,yeah in the heavy wind but all by all it needs some fine tuning. @AndiOz: Try to lower your throttle trim. |
