Old Dec 05, 2012, 12:23 PM
Njoro is offline
Find More Posts by Njoro
Joined Jan 2009
Gone to V2.0 will test tomorrow
Njoro is offline Find More Posts by Njoro
Old Dec 06, 2012, 12:01 AM
djyen is offline
Find More Posts by djyen
Joined Nov 2012
Hi guys!
I've got MCFC set and FlyCam OSD. OK, I put up on GPS problems. "Hold the position" means drift within 10m radius with this equipment.
Now I have two unsolved problems with my MCFC:
1) Can't set the enpoints to servo's. I've already broken the gear on one servo in the gimbal. Anyone who knows how to set the endpoint to tilt/roll servo please let know.
2) The current and voltage sensor on OSD is wrong. For example it writes 13.0V 1.0A when I put the fully charged battery. The real vaues must be 12.6V 0.6A.
I'd written to Minsoo about both problems but haven't recieved anything yet. He's just ignoring me.
Would be happy for any help.
djyen is offline Find More Posts by djyen
Old Dec 06, 2012, 03:02 AM
Minsoo Kim is offline
Find More Posts by Minsoo Kim
Joined Apr 2008
Originally Posted by cafecubain View Post
Dear Sir
please check as video.
IMG 0939 (0 min 17 sec)
if the connection is correct,the GPS module seems to be a problem.
actually, plug in the board and the blue led must be blink.
if the blue led fix,the MCFC does not get the signal of the GPS module.
we will send it
Minsoo Kim is offline Find More Posts by Minsoo Kim
Old Dec 06, 2012, 03:03 AM
Joined Apr 2008
Originally Posted by djyen View Post
Hi guys!
Dear Sir
I have sent emai already
please check email.
Old Dec 06, 2012, 06:45 AM
cafecubain is offline
Find More Posts by cafecubain
cafecubain's Avatar
Spain (MÓlaga)
Joined Aug 2010
Originally Posted by Minsoo Kim View Post
Dear Sir
http://youtu.be/2hxVtWgILm8
we will send it
Hi Mr Minsoo
I have a doubt, the blue LED GPS, should illuminate even when not connected to GPS module?
Anyway, I would send the whole set (the MCFC and GPS) to check it.
Please confirm if I send it.
many thanks!!
Gps Minsoo test (1 min 3 sec)
cafecubain is offline Find More Posts by cafecubain
Old Dec 06, 2012, 10:54 AM
GeO82 is offline
Find More Posts by GeO82
Belgium, Vlaams Gewest, Sint-Truiden
Joined Jul 2012
Hi Mr Minsoo
many thanks!!
http://youtu.be/djgsHhN0ECw
Hi,
like posted you in my last post yu had 2 options
-wire, connections
-gps module
Wen your GPS module is not working NO BLUE LED FLASHING
made you a vid check.
MCFC Blue led basic problem (NOT FLASHING) (2 min 16 sec)
GeO82 is offline Find More Posts by GeO82
Old Dec 06, 2012, 11:38 AM
cafecubain's Avatar
Spain (MÓlaga)
Joined Aug 2010
Originally Posted by GeO82 View Post
Hi,
-wire, connections
-gps module
Hi GeO82
Thanks for your time and help!!
Everything seems to be the GPS module (is possible battery be dead?).
I waiting for Mr Minsoo conclusions and confirmation to send this.
Thanks again and greetings!
Old Dec 06, 2012, 12:19 PM
GeO82 is offline
Joined Jul 2012
No problem,thats normal where a thread is for, i think that your gps module went kamikaze.
Maybe that also has something to do with your gps position hold, that gps module was not
operating correct. hopefully wen you get a new gps module your problem is fixed.
grtz!
Old Dec 06, 2012, 07:21 PM
funkis_jackson is offline
Find More Posts by funkis_jackson
Joined Sep 2012
Has anyone found out the correct way to program the 20A FlyCam ESCs?
It says to program it by the manual, but there isn't one so it's kind of tricky.
Mine are working fine, but I would like to be able to reprogram them if needed.
Also, I've changed all the four FlyCam 925 motors since three of them got to much axial play, and the rear bearings had puked out all their grease :/
funkis_jackson is offline Find More Posts by funkis_jackson
Old Dec 06, 2012, 08:43 PM
Joined Apr 2008
Hi Mr Minsoo
many thanks!!
Dear Sir
the blue led have to blink when the GPS function is activated.
your board is not blink. I think the GPS module is out of order.
we will replace it with new one.
Old Dec 07, 2012, 06:48 AM
Joined Sep 2012
Nevermind, I found out that the only programming that is possible is the throttle range on these
Old Dec 08, 2012, 05:21 AM
warthox is offline
Find More Posts by warthox
Joined Aug 2009
finally i had the time and parts to finish the mcfc quad.
warthox is offline Find More Posts by warthox
Old Dec 08, 2012, 05:59 AM
Joined Sep 2012
Very clean build Warthox!
Is it Tiger-motors outrunners you are using?
The prop-adapters look like so.
What KV engines are these?
I have 900kv mated with my 10 inch carbon fibre props.
Old Dec 08, 2012, 09:50 AM
warthox is offline
Joined Aug 2009
thanks. yes these are tigers. mt2208 1100kv.
i made a first flight today. all settings default. pots centered. acc and baro worked well.
i couldnt test gps since i got no stable lock. i left the quad on a table and it took several minutes to get a gps lock but it wasnt stable and 'locked out' shortly after.
the weather wasnt that good. snow and fog.
Old Dec 08, 2012, 12:49 PM
AsylumET is offline
Find More Posts by AsylumET
AsylumET's Avatar
United States, VT, Rutland
Joined Feb 2012
I am sure it isn't very noticeable if at all but binding your wires together makes more surface area to transfer vibrations. Leaving them loose inside a braided sleeve would still look nice and clean with less vibrations. That is one great looking quad though. Also not sure if you have seen or used them but this company has jumper wires of various sizes that fit much better than the typical servo jumpers. http://www.schmartboard.com/index.as...ucts_jch&id=42
AsylumET is offline Find More Posts by AsylumET
