Old Oct 12, 2011, 04:48 PM
G2loq is offline
Find More Posts by G2loq
G2loq Chopper
G2loq's Avatar
Canada, QC, La Prairie
Joined Jul 2007
Originally Posted by opatiac View Post
I installed the new firmware 2.3 for the Black Board and the GPS did work. Holds in the range of 5 m
NOT AT ALL ;-(
10 calibrations and 7 batteries later, after setting the VR2 pot in all the different position during 2 hours etc... same bad result. The GPS is not working at all for me and for most of the people in this thread.
I had no intereference at all and the GPS led was blue steady.
What should we think ?
G2loq is offline Find More Posts by G2loq
Old Oct 12, 2011, 07:46 PM
bigbro3760 is offline
Find More Posts by bigbro3760
Joined May 2010
does anybody have firmware for navi board except the beta version of minsoo?
thanks in advance for those who will share it
bigbro3760 is offline Find More Posts by bigbro3760
Old Oct 13, 2011, 01:08 AM
opatiac is offline
Find More Posts by opatiac
Joined Aug 2010
Originally Posted by G2loq View Post
NOT AT ALL ;-(
Before I installed the 2.3 firmware and my GPS did not hold a position.
Why now is not know
opatiac is offline Find More Posts by opatiac
Old Oct 13, 2011, 02:33 AM
Njoro is offline
Find More Posts by Njoro
Joined Jan 2009
Why now is not know
"are you saying that now your copter can hold its' GPS position in the air without drifting"?
Njoro is offline Find More Posts by Njoro
Old Oct 13, 2011, 02:53 AM
Njoro is offline
Joined Jan 2009
I have some thing to share, I've been running my X-copter on one ESC but since Mr Minsoo said to use a UBEC for the Navi I've installed an 11.1V 1300mAh lipo in close proximity to the side where the compass is situated and as I suspected the compass does not work with battery too close to it.
“When I bought my RVOSD Gen1 in 2009 some people were having issue with the GPS and it turned out to be only individuals in the Northern hemisphere, The code writer realised that he had to compensate for the Northern hemisphere in his code. I’m just mulling over as to what it could be with the Navi”.
Any thoughts?
Old Oct 13, 2011, 03:44 AM
rcimports is offline
Find More Posts by rcimports
South Africa
Joined Oct 2005
I'm in southern hemisphere.
rcimports is offline Find More Posts by rcimports
Old Oct 13, 2011, 03:51 AM
Njoro is offline
Joined Jan 2009
"oh well thats that then" eh
What is being up dated in Black board V2.3?
aaand what is v1.2 doing for the Navi?
Old Oct 13, 2011, 09:59 AM
cafecubain is offline
Find More Posts by cafecubain
cafecubain's Avatar
Spain (Mlaga)
Joined Aug 2010
Sonar install ...dont working
hi all
I come to put the "Sonar" but I see no changes. This not maintain the distance to the ground. need any configuration?
thanks in advance
enrique
cafecubain is offline Find More Posts by cafecubain
Old Oct 14, 2011, 12:13 PM
cafecubain's Avatar
Spain (Mlaga)
Joined Aug 2010
Help !
please can someone help me? I have connected the "Sonar", but how is activate or deactivate this?
Thanks!
ps
I put a video and do not see any change, I think dont work...
test fly KKmulticopter Flycam blackboard & Navi + Sonar (2 min 34 sec)
Old Oct 14, 2011, 02:28 PM
G2loq is offline
G2loq Chopper
G2loq's Avatar
Joined Jul 2007
Thanks!
ps
http://youtu.be/0cwBLNu1rlo
Did you checked at http://www.kkmulticopter.kr/index.ht...ea=navi_manual
The method of installation for Sonar
Connect the sonar cable to the pot of the NaviBoard.
Please check the direction of the cable.
It is possible to keep altitude in low altitude 6.5m.
The position of sonar sensor should be toward to the ground and install as far away from the ESC as possible.
The sonar is working with the switch of the 5th channel :
5th channel : Maintain altitude ( 2nd switch on,off )
It is more accurate versus the naviboard only when you are flying under 6.5meter.
IMHO, you should do your test outside ;-)
Regards
Pierre
Old Oct 14, 2011, 02:56 PM
cafecubain's Avatar
Spain (Mlaga)
Joined Aug 2010
Regards
Pierre
Salut Pierre
I thought that the "altitude hold", was to keep altitude only with the barometer (barosensor). then work both at the same time, right?
I will make a test with more space outdoors.
thanks for the help
enrique
Old Oct 14, 2011, 03:35 PM
G2loq is offline
G2loq Chopper
G2loq's Avatar
Joined Jul 2007
Ola Enrique ;-)
yes, that what I think too and my test confirmed that with the sonar, my multicopter are able to hold the altitude above 1 or 2 meter. And when you place your hand under, it react.
I agree there is no clear explanation on how the sonor is working, switch etc... in the text (but you have some video with Minsoo playing with the sonar...)
Did you test your GPS outside ?
Old Oct 14, 2011, 03:55 PM
G2loq is offline
G2loq Chopper
G2loq's Avatar
Joined Jul 2007
Originally Posted by Minsoo Kim View Post
we are checking the firmware and will post next week the PC Programmer that can confirm the status of compass and GPS signal.
I'll do my best to satisfy with our products.
I promise to live up to users expectations now and forever
It was on october 7th... 7 days ago... we are then "next week" and still no PC Programmer
and still no news from Minsoo ;-(
I ordered this morning a Wookong-M Multi-Rotor from DJI INNOVATIONS. It is just a little bit more expensive (in fact cheaper if I consider the money I invested and the time I spent on testing the not full working naviboard...) but the GPS is working rock solid... after reading all the thread and testimonies on it.
When I will receive it, and if my 2 naviboard are still drifting when GPS engaged, I will send them both back to Minsoo for a refund.
Yes, I am closed to give up...
Old Oct 15, 2011, 12:47 PM
wessiercgroups is offline
Find More Posts by wessiercgroups
South Africa, GP, Johannesburg
Joined Apr 2011
Hi All Im very despondence at the moment. After spending over 800 dollars with Minsoo and struggling the hole day to get any functionality out of the Navi board I feel like I wasted a lot of money on something that does not work as advertised. Perhaps Im just tired and frustrated at the moment. If this tread was up and running before I purchased the Navi board I doubt that I would have ordered it.
I upgraded to beta 1.2 on the Navi and 2.3 on the black board. Nothing changed I have to keep on trimming to keep the quad level. Altitude hold with the sonar is useless. Just keeps on climbing or shooting straight up. Position Hold is none existing. Goes north or south as it pleases.
One thing I have noticed is that the magtrometer is ultra sensitive. Ive move the speaker, used a separate battery through a UBEC raised the board added a screed between the ECU supply and the rest of the electronics. I feel the same as G2LOG.
I hope Minsoo comes up with new firmware soon.
Regards Wessie.
wessiercgroups is offline Find More Posts by wessiercgroups
Old Oct 16, 2011, 12:07 PM
nxm310 is offline
Find More Posts by nxm310
Joined Oct 2011
good morning everyone.
beta 1.2
2.3 bleu board
It's been a while since I test the navibord.ce I found:
- If I do not do the calibration of the magnetometer, GPS does not initialize.
- I have to gauge each time you restart if gps not ok
Once this is done, the GPS flashes for a while and then arming.
- For sonar, it is effectively coupled with track 5 of the barometer. Once switched on the altitude, the Tricoptere this stabilsateur reaccelerates and if too low descent. it works for me
nxm310 is offline Find More Posts by nxm310
