Old Oct 12, 2012, 01:15 AM
brandonmoon is online now
Find More Posts by brandonmoon
Fly & Have Fun..Enjoy the Ride
brandonmoon's Avatar
United States, AZ, Gilbert
Joined Mar 2009
This is what I've been refering to. Todd, send these to your contact @ FMS
brandonmoon is online now Find More Posts by brandonmoon
Old Oct 12, 2012, 02:11 AM
HLC SHOP is offline
Find More Posts by HLC SHOP
HLC SHOP's Avatar
LE MANS, France
Joined Oct 2010
New strong Hub will be ship to FMS dealers in 10 days.
That's a good news.
Chris
HLC SHOP is offline Find More Posts by HLC SHOP
Old Oct 12, 2012, 02:58 AM
struggleforlife is offline
Find More Posts by struggleforlife
struggleforlife's Avatar
The Netherlands, LI, Gennep
Joined Feb 2011
They are not going to solve this for the existing models.
So, just file off the leftover thread.
And as I said earlier: put a spacer on the threaded shaft, just before the hub, that will give you 3mm extra.
struggleforlife is offline Find More Posts by struggleforlife
Old Oct 12, 2012, 04:09 AM
Joined Mar 2009
If you do that, you can not get the spinner on. As I also said earlier, the shaft adapter needs to be longer in order for that to work, but it is a good thought and idea.
Old Oct 12, 2012, 04:19 AM
Joined Feb 2011
Ah, sorry, missed that. Well in that case the only option is to extend at the other end.
Old Oct 12, 2012, 07:50 AM
gnats82 is offline
Find More Posts by gnats82
Coy, peruser of worlds
gnats82's Avatar
Augusta, KS USA
Joined Dec 2007
Brandon - Post #1216
The image posted with the arrow pointing to the notch in the protruding molding was misleading to me. The actual point of contact is further down it toward or adjacent to the opening for the motor shaft. That is correct isn't it?
Godofthunder posted the only shots I've seen so far that show the relationship there with the unit assembled. There was some clearance there before altering, looked like maybe .050" - .070", maybe a bit more. I'm having a hard time believing something 'grew' out out spec that much to make contact. It may have but the order it occurred in is most important. I'm only posting this so that if FMS is to see these things, they don't have to contend with assessments that aren't clear or mistaken. If I owned one of these, I may want to move the motor forward a bit too but only after a pretty thorough run up to check if things really are hitting.
Also, I find myself questioning the blade material. The nature of the breaks I've seen in the images seems to suggest a brittle material with poor tensile strength, something akin to bakelite which would be a super poor choice for a prop blade. These blades must weigh in the vicinity of 1.3 ozs. each, heck of a lot of centrifugal force in that and working against the hub structure.
gnats82 is offline Find More Posts by gnats82
Old Oct 12, 2012, 10:47 AM
Aros.MotionRC is online now
Find More Posts by Aros.MotionRC
Shameful Warbirdaholic.
Aros.MotionRC's Avatar
Maple Valley, WA
Joined Apr 2006
Sent them today. Thanks!
Aros.MotionRC is online now Find More Posts by Aros.MotionRC
Site Sponsor
Old Oct 12, 2012, 10:56 AM
Maple Valley, WA
Joined Apr 2006
A note from FMS...
Hi Todd, Thank you very much for your great suggestions to us, I think it will help us more or less to solve the problem, we also received the same suggestions from other nice FMS supporters and friends, I am sure we will solve this problem soon.
I'm excited to get this fixed. I want to fly that gorgeous 1700 Corsair and P-47 again!
Site Sponsor
Old Oct 12, 2012, 12:36 PM
Maple Valley, WA
Joined Apr 2006
Here's a couple more photos of the prop damage. I unscrewed the top of the hub so the prop breaks are more easily seen. gnats82 may be spot on with his comments about prop material and strength.
Site Sponsor
Old Oct 12, 2012, 01:22 PM
Joined Feb 2011
exactly what my broken blade showed.... brittle material, little air bubbles in the material.
Old Oct 12, 2012, 01:50 PM
Kaikokid is offline
Find More Posts by Kaikokid
Kaikokid's Avatar
New Zealand, Northland, Kaikohe
Joined Aug 2011
I have no doubt whatsoever that Gnats is spot on. He's a gem. If FMS are not aware of his opinion they need to be.
Kaikokid is offline Find More Posts by Kaikokid
Old Oct 12, 2012, 02:19 PM
Maple Valley, WA
Joined Apr 2006
I've been forwarding the best comments on to FMS the past few days and gnats has definitely been part of that group. They are definitely well aware of the issues and thanks to the support and help from many here like Brandon and gnats, I believe FMS is going to get the next evolution/version correct.
Site Sponsor
Old Oct 12, 2012, 02:34 PM
Joined Feb 2011
I managed to find a pic from the broken blade (that I sent to FMS when I had a accident with my 1400 corsair).
As you can see: airbubbles.
Old Oct 12, 2012, 02:45 PM
gnats82 is offline
gnats82's Avatar
Augusta, KS USA
Joined Dec 2007
I have a fear this is a pattern with some of these. Failure from a out and out heavy blade strike is one thing but if these are fatiguing from general use and minor bumps, it really is cause for concern. Most users, including myself, would not be inspecting them after such incidents for damage. Add to that the difficulty in seeing fractures, the issue is compounded. The material looks worse than I thought.
Last edited by gnats82; Oct 12, 2012 at 08:11 PM. Reason: grammar, spelling correction
Old Oct 12, 2012, 06:41 PM
Joined Mar 2009
Originally Posted by gnats82 View Post
I have a fear this is a pattern with some of these. Failure from a out and out heavy blade strike is one thing but if these are fatiguing from general use and minor bumps, it really is cause for concern. Most users, including myself, would not be inspecting them after such incidences for damage. Add to that the difficulty in seeing fractures, the issue is compounded. The material looks worse than I thought.
Very good point and I agree with you on that one
New Product FMS P-47 1700mm wingspan!!! HLC SHOP Electric Warbirds 2751 Jun 27, 2016 08:16 PM
New Product FMS North American P-51 D Mustang 1700mm (67 inches!!!) Beltpilot Electric Warbirds 10991 Jun 24, 2016 08:25 PM
Wanted Needed Airfield/FMS F4U Corsair Spare Parts godofthunder77 Aircraft - Electric - Airplanes (FS/W) 3 Sep 05, 2015 09:55 AM
Discussion FMS/Airfield 800mm F4U Corsair norco kid Electric Warbirds 3 Apr 30, 2011 06:22 PM
Help! airfield/FMS F4U Corsair help kayla95 Electric Warbirds 2 Mar 24, 2011 06:12 PM
