Old Oct 09, 2012, 03:19 AM
Sandancer is offline
Find More Posts by Sandancer
"Auntie Samantha"
Sandancer's Avatar
USA, MO, Clever
Joined Dec 2009
Originally Posted by raybaines View Post
Gary,
I have a set of 4713-16 16D 18.6" blades and a further set of 422-16 16D 16.6" blades.
Perhaps I will have to follow your lead and order the 17.2" blades to cover all bases !!
Ray.
Here the correspondence I had with Christian back in Feb.
Dear Mr. Gary,
thank you for contacting and interest in our
varioPROP propellersystem.
For your P-51 I would suggest the following parts:
1x 4-blade propellerhub, size "16D"
with 12mm hole for threaded motor shaft. Part-No.: 41216
1x Steel Collet Cuck, long size "16D"
for a smooth 10mm motor shaft. Part-No.: 1610
Note: When using this cuck you
can mount the back plate
of a spinner behind the
hub.
4x 16,6"- Propellerblade, type -HS- size "16D"
for 422mm prop-diameter and
max. RPM 9.000 1/min Part-No.: 422-16
Or Alternative:
4x 17,2"- Propellerblade, type -D- size "16D"
for 437mm prop-diameter and
max. RPM 9.500 1/min Part-No.: 437-16
Note:
When you turn this 4-blade, 16.6" and a adjusted pitch of 14"
with about 5000 1/min you would get a static trust of 40N (~4kg)
by a needed power of ca. 950W. On 5S-LiPo this meand a current of
53A. The 17,2" would deliver a little more static trust, by a need
of the same Amps.
Gary
Sandancer is offline Find More Posts by Sandancer
Old Oct 09, 2012, 03:20 AM
eroeder is offline
Find More Posts by eroeder
eroeder's Avatar
United States, TX, Frisco
Joined Jan 2004
Ray,
Where did you order your prop?
eroeder is offline Find More Posts by eroeder
Old Oct 09, 2012, 03:32 AM
raybaines is online now
Find More Posts by raybaines
Captain Kangaroo
raybaines's Avatar
Australia, QLD, Headington Hill
Joined May 2009
U.S. agent :
e-flightline.com
Ray.
raybaines is online now Find More Posts by raybaines
Old Oct 09, 2012, 03:40 AM
eroeder is offline
eroeder's Avatar
Joined Jan 2004
U.S. agent :
e-flightline.com
Ray.
Yikes! They are out of business. Hmmm, where now?
Old Oct 09, 2012, 03:53 AM
Captain Kangaroo
raybaines's Avatar
Joined May 2009
Sorry did not know that.
Perhaps Gary can help us out.
Ray.
Old Oct 09, 2012, 03:56 AM
brandonmoon is offline
Find More Posts by brandonmoon
Fly & Have Fun..Enjoy the Ride
brandonmoon's Avatar
United States, AZ, Gilbert
Joined Mar 2009
There aren't any other U.S. dealers I could find that carry anything over the 8B hub sizes...But on the links page on thier main page there are several Overseas possibilities available
http://www.ramoser.de/home_e/variopr...rioprop_e.html
brandonmoon is offline Find More Posts by brandonmoon
Old Oct 09, 2012, 04:04 AM
Captain Kangaroo
raybaines's Avatar
Joined May 2009
Thank you !!
Ray.
Old Oct 09, 2012, 04:08 AM
"Auntie Samantha"
Sandancer's Avatar
USA, MO, Clever
Joined Dec 2009
U.S. agent :
e-flightline.com
Ray.
Ray.
It does look like Mike and Jeff e-fllightline went out of business! Looks like Ramoser it is! They're located in Germany, and I've ordered direct from them on several occasions. Christian is a great guy and will answer any of your questions. Christian info@ramoser.de
Gary
Old Oct 09, 2012, 05:23 AM
Ldm is offline
Ldm
Find More Posts by Ldm
Ldm
Ldm's Avatar
United States, PA, Conestoga
Joined Jun 2006
+1 To Garys comments I look into the system for the LX P40 , they were great .
I could not use it for my application because my Prop was too thick for what they could offer .That will not be the case with the 1700 size FMS planes
Ldm is offline Find More Posts by Ldm
Old Oct 09, 2012, 08:10 AM
gnats82 is offline
Find More Posts by gnats82
Coy, peruser of worlds
gnats82's Avatar
Augusta, KS USA
Joined Dec 2007
Originally Posted by brandonmoon View Post
This is the little culprit along with the other variables we's all mentioned that is causeing the prop and hub failures and these catastrophic failures I've been talking about. It's basicaly the same setup on the P-47 and the F4U Corsair
For sure that could set up the failure. Wasn't that contact discernible during assembly by just rotating the prop through? I'd want to see images of a freshly assembled example to see just how it sits prior to running. I'd hope there is enough ventilation through the cowl and out the back of the plane to eliminate pressure within.
Still, better to find the prop weakness at this stage rather than down the road at the cost of what could be worse consequences.
Btw, Aros, it is truly a remarkable looking Corsair, even presents itself like the full scale while flying, really a satisfying offering from FMS in that regard. I know this has all been sort of traumatic and you follow through with clarity. Thanks.
gnats82 is offline Find More Posts by gnats82
Old Oct 09, 2012, 08:48 AM
Smoothcruizer3 is offline
Find More Posts by Smoothcruizer3
Smoothcruizer3's Avatar
United States, DE, Dover
Joined Oct 2011
I agree, especially for the newbie who likes to full throttle static test his or her models at home or on the bench and you know one of you watching these threads do.... yikes... and ouch just the sound of the pop makes my stomach turn and if this happens in someone's basement ....
Smoothcruizer3 is offline Find More Posts by Smoothcruizer3
Old Oct 09, 2012, 01:01 PM
struggleforlife is offline
Find More Posts by struggleforlife
struggleforlife's Avatar
The Netherlands, LI, Gennep
Joined Feb 2011
I was one of those full throttle static test guys hahahaha...
One blade seperated during static test, the plane was jumping around in the room, eating the cowl and the floor. I still have a scar in my face from the blade.
Since then, I don't thrust these hubs and blades anymore.
struggleforlife is offline Find More Posts by struggleforlife
Old Oct 09, 2012, 01:09 PM
seahawk1984 is offline
Find More Posts by seahawk1984
Experienced but not an Expert
seahawk1984's Avatar
United States, WA, Enumclaw
Joined May 2011
And I might be the newbie your referring to.
I'm lucky I didn't burn up my Starmax Gunfighter when I did my full throttle static test. I filed that under 'I'll Never Do That Again' experience.
But I'm sure we have all done stupid things until we learned better.
It's when we DON'T learn from our mistakes that's a problem.
seahawk1984 is offline Find More Posts by seahawk1984
Old Oct 09, 2012, 01:56 PM
Aros is online now
Find More Posts by Aros
Shameful Warbirdaholic.
Aros's Avatar
Maple Valley, WA
Joined Apr 2006
Hell, I do stupid things daily!
Aros is online now Find More Posts by Aros
easyrider604 is offline
Find More Posts by easyrider604
Canada, BC, Port Coquitlam
Joined Apr 2012
Sorry to hear of your Corsair incident. Do you think this can be a "warranty" claim? The 1700 Corsair is so new and bugs still need to be worked out.
The cause could have been a weak prop hub, weak prop blades or a cowling clearance problem...or a combination of the three.
Gorgeous model...nice flying....will be perfect for our little project, eh?
easyrider604 is offline Find More Posts by easyrider604
New Product FMS North American P-51 D Mustang 1700mm (67 inches!!!) Beltpilot Electric Warbirds 10598 Yesterday 08:34 PM
New Product FMS P-47 1700mm wingspan!!! HLC SHOP Electric Warbirds 2612 Yesterday 07:39 PM
Wanted Needed Airfield/FMS F4U Corsair Spare Parts godofthunder77 Aircraft - Electric - Airplanes (FS/W) 3 Sep 05, 2015 10:55 AM
Discussion FMS/Airfield 800mm F4U Corsair norco kid Electric Warbirds 3 Apr 30, 2011 07:22 PM
Help! airfield/FMS F4U Corsair help kayla95 Electric Warbirds 2 Mar 24, 2011 07:12 PM
