Old Feb 07, 2013, 03:11 PM
Mitchie is offline
Find More Posts by Mitchie
Mitchie's Avatar
Canada, QC, Gatineau
Joined Jan 2011
Sounds like he knows what he's talking about
Mitchie is offline Find More Posts by Mitchie
Old Feb 07, 2013, 03:25 PM
eroeder is offline
Find More Posts by eroeder
eroeder's Avatar
United States, TX, Frisco
Joined Jan 2004
I was told by a guy with experience with FMS, their electronics to include servos is rock solid. The only issue with the elevator servos on these big birds seem to eventually fail due to having to a large surface under such loading. I was told only that one needs to be swapped out for a beefier one.
Just passing on what I heard...
eroeder is offline Find More Posts by eroeder
Old Feb 07, 2013, 04:15 PM
Mitchie is offline
Mitchie's Avatar
Joined Jan 2011
That's nice to hear, I still have all original servos. (10 or so flights so far, and all servos look tight)
Old Feb 07, 2013, 04:25 PM
eroeder is offline
eroeder's Avatar
Joined Jan 2004
He almost lost his FW190 when the servo failed on T/O, luckily it was frozen with a slight pitch up. As such he just used power to control his descent to landing. He had another FMS model do the same thing. This plane is big and heavy, so that small servo is working double duty. On gas'rs this size, the elevator would one servo per side to manage load.
Has anyone else swapped the elevator servo for a beefier one?
Old Feb 07, 2013, 04:26 PM
Kev71H is offline
Find More Posts by Kev71H
Kev71H's Avatar
San Jose, California, United States
Joined Apr 2002
Is there "reallly" all that much load on the elevator servo? I mean, these birds are not going blazing fast. These servos are rated at decent ounces of Torque arent they? How much resistance is the elevator really having?
I can't see how it would stress out the elevator servo as there is not a whole lot of "fast" air moving over the elevator. These 1700mm planes go pretty decent "scale" speed and not a speed demon by no means.
How would someone know exactly how much "stress" it takes to move one of these slower 1700mm birds? When I grab the servo, that baby pushes VERY well on my fingers...the torque is pretty substantial enough that I would not want to try to "hold" the elevator while moving the servo for fear it would RIP the elevator servo horn out.
Just my thoughts.
Kev71H is offline Find More Posts by Kev71H
Old Feb 07, 2013, 04:39 PM
Galand is offline
Find More Posts by Galand
Galand's Avatar
Long Island, NY
Joined May 2010
Just my thoughts.
Also the elevator "horns at the extremities" are quite big. That is part of the "light" controls on the FS.
Galand is offline Find More Posts by Galand
Old Feb 07, 2013, 04:52 PM
gnats82 is offline
Find More Posts by gnats82
Coy, peruser of worlds
gnats82's Avatar
Augusta, KS USA
Joined Dec 2007
Kev, Post #2600 -
I have the H-K P-40N 1700. I think the flight loads are modest enough on these planes but it's the snatching and whiplash they get from the larger and heavier control surfaces while moving across the ground that eats the plastic gears up, as much as anything else. I went to metal geared servos on the tail surfaces for that reason.
gnats82 is offline Find More Posts by gnats82
Old Feb 07, 2013, 05:01 PM
Kev71H is offline
Kev71H's Avatar
Joined Apr 2002
Originally Posted by gnats82 View Post
Kev, Post #2600 -
I have the H-K P-40N 1700. I think the flight loads are modest enough on these planes but it's the snatching and whiplash they get while moving across the ground that eats the plastic gears up. I went to metal geared servos on the tail surfaces for that reason.
Sounds sensible enough to me.
Old Feb 07, 2013, 05:03 PM
struggleforlife is offline
Find More Posts by struggleforlife
struggleforlife's Avatar
The Netherlands, LI, Gennep
Joined Feb 2011
Just my thoughts.
I believe the actual load on a servo, caused by control surfaces, can be calculated quite easily.
Unfortunately, I do not know how to do this. But you have to know speed and surface in squire cm/inch.
struggleforlife is offline Find More Posts by struggleforlife
Old Feb 07, 2013, 05:04 PM
Dangaras is offline
Find More Posts by Dangaras
Dont be divided from the truth
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
Not so. The H9 models use one standrd size servo to run both elevators connected by a U wire.
Dangaras is offline Find More Posts by Dangaras
cerralvo78 is offline
Find More Posts by cerralvo78
cerralvo78's Avatar
United States, TX, La Porte
Joined Sep 2005
The only reaso I need the servos is because I accidentally put 22v on all servos and they are all burn out.........
I can find nobody that have the replacement servos(originals) unless someone tell me who is selling them!
I might just buy hitecs!
Thanks for the hitec replacement options "struggleforlife"
cerralvo78 is offline Find More Posts by cerralvo78
Old Feb 07, 2013, 05:06 PM
Dangaras is offline
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
rc-castle.com
Old Feb 07, 2013, 05:30 PM
gnats82 is offline
gnats82's Avatar
Augusta, KS USA
Joined Dec 2007
Yeah, I could've added to that any fluttering of the surfaces in flight would have the same effect because of the size of the surfaces. I know this goes to theory a bit but I suspect they get jiggled a bit due to that even though the surfaces might have a tight gap. Someone might come along and set up a camera to watch them for a study.
Old Feb 07, 2013, 05:48 PM
Aros.MotionRC is offline
Find More Posts by Aros.MotionRC
Shameful Warbirdaholic.
Aros.MotionRC's Avatar
Maple Valley, WA
Joined Apr 2006
Originally Posted by 400xp View Post
Finally done! Well not really, I have small detail stuff to do but what a great looking scale plane!! I will have better pics soon.
Looks great!!
Aros.MotionRC is offline Find More Posts by Aros.MotionRC
Site Sponsor
Old Feb 07, 2013, 05:54 PM
Wargassm is offline
Find More Posts by Wargassm
Wargassm's Avatar
United States, CA, Lake Forest
Joined Nov 2010
not elevator but rudder on the P51 1.7m yes. Replaced it with HiTech 625mg.
So far haven't had any issues after 10 flights, only servos im worried about are flaps. Oddly on my wing the flaps dont like to go all the way up, i had to adjust them.
As far as FMS electronics. Id say compared to everyone else they are really good, in fact better than them all with one exception. LX, on the new A10 and SU47 they come with all metal gear digital servos. Beefed up motors and ESC's.
I have some servos, and ESC from several FMS planes, some of them from two years ago and they are still in use today. That's saying something.
Wargassm is offline Find More Posts by Wargassm
New Product FMS North American P-51 D Mustang 1700mm (67 inches!!!) Beltpilot Electric Warbirds 10991 Today 08:25 PM
New Product FMS P-47 1700mm wingspan!!! HLC SHOP Electric Warbirds 2749 Jun 20, 2016 06:40 PM
Wanted Needed Airfield/FMS F4U Corsair Spare Parts godofthunder77 Aircraft - Electric - Airplanes (FS/W) 3 Sep 05, 2015 09:55 AM
Discussion FMS/Airfield 800mm F4U Corsair norco kid Electric Warbirds 3 Apr 30, 2011 06:22 PM
Help! airfield/FMS F4U Corsair help kayla95 Electric Warbirds 2 Mar 24, 2011 06:12 PM
