Old Dec 04, 2012, 02:28 PM
paracanary is online now
Find More Posts by paracanary
paracanary's Avatar
La Habra, California
Joined May 2004
Had a good 2 flights flights this morning. 2 comments. The recommended elevator throws are very sensitive. I moved the servo arm connector 1 hole in. The servo used for steering moves in its mount because they did not use grommets so the servo moves side to side because the hole is too large. If you look the tail wheel retract servo is the same but they epoxied it in. So I epoxied the steering servo in. Something to check because when I landed I had only right tail wheel which is lucky for me because the fence is on the left. Other than that, a very nice flying warbird with acceptable top end.
paracanary is online now Find More Posts by paracanary
Old Dec 04, 2012, 02:32 PM
Dangaras is offline
Find More Posts by Dangaras
Dont be divided from the truth
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
Ahhhhh, great! We need to wait for spring!!!!
Dangaras is offline Find More Posts by Dangaras
Old Dec 04, 2012, 03:17 PM
FlyingGolem is offline
Find More Posts by FlyingGolem
Subsurface flying expert
FlyingGolem's Avatar
United States, CA, Santa Clarita
Joined Oct 2012
Maybe you do, but the weather here is awesome for flying.
FlyingGolem is offline Find More Posts by FlyingGolem
Old Dec 04, 2012, 03:27 PM
Dangaras is offline
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
Damn, dont rub it in....
Old Dec 04, 2012, 03:34 PM
Aros.MotionRC is offline
Find More Posts by Aros.MotionRC
Shameful Warbirdaholic.
Aros.MotionRC's Avatar
Maple Valley, WA
Joined Apr 2006
Nice!
Aros.MotionRC is offline Find More Posts by Aros.MotionRC
Site Sponsor
Old Dec 04, 2012, 03:50 PM
paracanary's Avatar
Joined May 2004
Aros,
I do not need to now but how easy is it to take the tail wheel assembly out for service. It looks like you remove the 2 elevator screws. The rest is glued in. On your model that was destroyed, was the assembly tack glued for easy removal or permanently glued in.
Old Dec 04, 2012, 03:54 PM
Ldm is offline
Ldm
Find More Posts by Ldm
Ldm
Ldm's Avatar
United States, PA, Conestoga
Joined Jun 2006
Para or Aros do you have a link to the battery's you are useing ?
Ldm is offline Find More Posts by Ldm
Old Dec 04, 2012, 03:55 PM
Maple Valley, WA
Joined Apr 2006
To be honest I have not really looked at the tail wheel assembly that closely. (I'm one of those "If it is working, no need to study the part" kinda guys, lol). I know the two elevator screws are part of the equation but the rest looks glued in. I could take a closer look and let you know if you like.
Site Sponsor
Old Dec 04, 2012, 03:57 PM
Maple Valley, WA
Joined Apr 2006
Ldm, I'm using the Turnigy Nanotech 6S 5000 mAh 45C battery. It's what I had for my other 1700 planes. I had to do some digging in the battery compartment to fit (due to the 45C rating I imagine) but after that, once it's pushed full forward it's perfect for the CG.
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
Site Sponsor
Old Dec 04, 2012, 05:48 PM
Ldm is offline
Ldm
Ldm
Ldm's Avatar
Joined Jun 2006
Thanks Aros , that is what I needed. thanks again !
Old Dec 04, 2012, 06:55 PM
paracanary's Avatar
Joined May 2004
Quote didn't work. This is my answer for LDM
I used the spyderbattery 6s 5300 mah 30c has 5c charge rate. I charge it in 10 min. Comes with ec5 connector
http://www.progressiverc.com/lipo-batteries
I have a pretty clean battery install with very little carving. Will post pictures if interested.
Suggest you get a box of m3 socket head screws. m3 Phillips are used through out the aircraft. The head doesn't strip like the Philips that are supplied. Specifically for the motor mount.
something like this
http://www.amazon.com/20mm-Button-Sc...+x+20+mm+screw
Old Dec 04, 2012, 07:18 PM
Galand is online now
Find More Posts by Galand
Galand's Avatar
Long Island, NY
Joined May 2010
Originally Posted by paracanary View Post
Don't buy @ Amazon. Horrible price. Look at this site:
http://www.microfasteners.com/catalo...ny_profile.cfm
Galand is online now Find More Posts by Galand
Old Dec 04, 2012, 07:24 PM
paracanary's Avatar
Joined May 2004
I like microfasteners but could not find 20 mm lengths in m3.
Old Dec 04, 2012, 07:33 PM
Dangaras is offline
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
I was able to find M3 x 20 at Lowes.....
PS, there is also RTL Fasteners..... http://rtlfasteners.com/RC/cm3020.html
Old Dec 04, 2012, 07:47 PM
Mikey 68 is online now
Find More Posts by Mikey 68
Joined Sep 2004
Originally Posted by easyrider604 View Post
Guys,
ROC Hobby is manufactured by FMS.
ROC is not intended to compete with, nor replace FMS.
ROC will have a different product line than FMS.
The big advantage of ROC is that it will benefit from the hard-learned lessons of FMS, so it will not suffer the same growing pains.
MotionRC is the exclusive ROC Hobby U.S. distributor. FMS have learned from the BH deal, and hopefully, FMS has set conditions for MotionRC to provide better service.
As well, ROC has been granted rights to distribute some specific FMS models. There will be no conflict between Motion and BH.
The above comments are based on direct comms with the FMS factory.
In addition, FMS is not connected in any way with Nitroplanes, so the new Nitroplanes warbirds, i.e. 800mm T28/P51/Skyraider and 1450mmT28, are not FMS-made.
Those new warbirds from NP are made by A-RC
Mikey 68 is online now Find More Posts by Mikey 68
New Product FMS North American P-51 D Mustang 1700mm (67 inches!!!) Beltpilot Electric Warbirds 11288 Today 11:00 AM
New Product FMS P-47 1700mm wingspan!!! HLC SHOP Electric Warbirds 2844 Sep 23, 2016 05:44 PM
Wanted Needed Airfield/FMS F4U Corsair Spare Parts godofthunder77 Aircraft - Electric - Airplanes (FS/W) 3 Sep 05, 2015 09:55 AM
Discussion FMS/Airfield 800mm F4U Corsair norco kid Electric Warbirds 3 Apr 30, 2011 06:22 PM
Help! airfield/FMS F4U Corsair help kayla95 Electric Warbirds 2 Mar 24, 2011 06:12 PM
