Old Sep 25, 2011, 11:54 PM
Pintac is offline
Find More Posts by Pintac
Pintac's Avatar
United States, PA, Apollo
Joined Sep 2011
HK has a new mini quad frame
HobbyKing Mini Quadcopter Frame V1 - 539mm
Pintac is offline Find More Posts by Pintac
Old Sep 26, 2011, 12:02 AM
Rishelman is offline
Find More Posts by Rishelman
Knobbs
Friday Harbor, WA -San Juan Island
Joined Aug 2008
awesome, now just need the HK KK board to be back in stock.
Rishelman is offline Find More Posts by Rishelman
Old Sep 26, 2011, 12:38 AM
rocketheli is offline
Find More Posts by rocketheli
Quad is the new black
Australia, NSW, Sydney
Joined Jun 2011
Wooden gaui 330x clone? Really cheap though.
rocketheli is offline Find More Posts by rocketheli
Old Sep 26, 2011, 01:33 AM
snokid is offline
Find More Posts by snokid
Troy, MI
Joined Sep 2007
well I ordered one for 8.00 can always start a fire with it....LOL
snokid is offline Find More Posts by snokid
Old Sep 26, 2011, 01:40 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
lol if this is anything like the wood terminator clone, it will disintegrate on first impact. I still have 2 of them new in box after opening one and realizing how worthless it was.
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Sep 26, 2011, 01:50 AM
Pintac is offline
Pintac's Avatar
Joined Sep 2011
Probably only good enough to use as a template to fabricate it out of different material.
Old Sep 26, 2011, 09:05 AM
n3m1s1s is offline
Find More Posts by n3m1s1s
UK, Buckinghamshire, High Wycombe
Joined Feb 2007
bigger than that hobbyking now has a Quadcopters & Parts section! they getting ready to flood the market trust me, cloned EVERYTHING
n3m1s1s is offline Find More Posts by n3m1s1s
Old Sep 26, 2011, 09:07 AM
timecop is offline
Joined Dec 2010
Their battery straps are amazing
Old Sep 26, 2011, 09:15 AM
Quad_Addict is offline
Find More Posts by Quad_Addict
United States, IL, Chicago
Joined Dec 2006
rc groups # 1 sponser
Quad_Addict is offline Find More Posts by Quad_Addict
Old Sep 27, 2011, 08:26 AM
KCV6 is offline
Find More Posts by KCV6
lurking in the HOLE :)
KCV6's Avatar
Australia, SA, Edinburgh
Joined Aug 2009
They just released the V2 controller (KK) with the 168PA. It's still in stock (for now).
Mark
KCV6 is offline Find More Posts by KCV6
Old Sep 27, 2011, 08:32 AM
Matt Chester is offline
Find More Posts by Matt Chester
Matt Chester's Avatar
Newnan, GA
Joined Oct 2002
That frame would not last one crash. I'll stick with my real Gaui frame, its VERY durable and worth every penny. Plus spares are not a problem to get for it.
If they would cut one like it out of G10 or Carbon and price it about $35, it would be a hit. Why must they go SOOOOooo cheap
Matt Chester is offline Find More Posts by Matt Chester
Old Sep 27, 2011, 09:02 AM
ben123 is offline
Find More Posts by ben123
NW England
Joined Jul 2005
Annnnnnnd it sold out... just as I added it to my basket
Ben.
ben123 is offline Find More Posts by ben123
Old Sep 28, 2011, 01:02 AM
SeismicCWave is online now
Find More Posts by SeismicCWave
AMA 46133
Hawaii
Joined Feb 2003
It is cheap and it actually looks pretty good. However please don't be mislead by the name. At 539 mm it is NOT a mini. That's 20" from motor to motor!
SeismicCWave is online now Find More Posts by SeismicCWave
Old Sep 28, 2011, 03:14 AM
n3m1s1s is offline
Joined Feb 2007
i cant wait to see the look on peoples faces when they open the box and build a quad that 2 inches smaller than the original quad they got from hobbyking then look in the box at the 6a esc's and 16g motors and their 850mah 2s lipo and 7/35 props thinking "ARE YOU SURE?"
:d
920kv should be perfect for this quad peeps get 10/6 dd props and cut half inch to an inch off each end should give you a very nice strong prop for the weight 15/18a esc will be enough but 18/20a esc (slightly heavier) also fine add a 2200 20c (i prefer lipo to gradually fade rather than loads of power then suddenly fall out of the sky) or 45c if your on a strict timer flight controller of your choice and you should be good to go
quick thought
wood is a natural resource much like our skin so my thinking is if you cut it you need to heal it! much like our skin so if you find the hobbyking frame too weak do the following
strip frame to all separate components (i am talking of v1 and v2 frames)
get a big bottle or many tubes of thin ca glue (superglue)
edge EVERY hole and cut surface with the superglue and let it seep into all the cuts
leave it to dry out of direct light and heat so you dont warp the wood
once dry assemble
will now be MUCH stronger not unbreakable BUT STRONGER!
V1frame add carbon rods to uprights of landing gear and add pool noodles to horizontal strips by cutting a slit in the noodle and stuffing the landing gear in it
JOB DONE
Old Sep 28, 2011, 03:15 AM
n3m1s1s is offline
Joined Feb 2007
The above applies to anything you cut out of wood
Sold New small quad frame. and another twin frame tc3wins Aircraft - Electric - Multirotor (FS/W) 6 Sep 29, 2011 11:11 AM
Discussion Maidened a new quad frame - Not sure what to call it... troynh Aerial Photography 15 Sep 28, 2011 03:04 AM
Sold FPVpilot 6061 Aluminum Quad Frame NEW Wing&aPrayer Aircraft - Electric - Multirotor (FS/W) 1 Sep 11, 2011 03:29 PM
Discussion my new quad frame joey1117 Multirotor Talk 1 Sep 10, 2011 04:26 PM
