Old Sep 25, 2011, 10:08 PM
p901P901 is online now
Find More Posts by p901P901
p901P901's Avatar
United States, CA, Lancaster
Joined Jan 2009
Spur gears as pinion gears
Most spur gears for cars are used for slipper clutches. Are there any hubs for 1/4 inch shafts with set screws? I want to use a spur gear as a pinion gear for a drive system for an airplane. I need a hub that bolts onto a #1972 Super Spur 48 Pitch 72T machined spur gear from Robertson.
p901P901 is online now Find More Posts by p901P901
Old Sep 26, 2011, 07:27 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
I would think you would have more luck finding the right combination of gears from an airplane gearbox supplier than from car parts?
What overall ratio are you aiming for with a 72T pinion?
wparsons is offline Find More Posts by wparsons
Old Sep 26, 2011, 04:30 PM
p901P901's Avatar
Joined Jan 2009
I was looking for 1-1 ratio but limited to about 1.56" between gear shafts. What will work is a 75T 48p to a 72T 48p for the distance I need. But none of these gears have hub that can be secured to a shaft. That is why I need a hub to secure the gear to the shaft.
Also what is the pressure angle on 48P. Is it 14.5 or 20 degrees? Also what is the face width of spur gears?
Old Sep 26, 2011, 05:03 PM
Aethertek is offline
Find More Posts by Aethertek
Creations Aberration
Aethertek's Avatar
United States, OR, Newport
Joined Jan 2004
48P gears can come in both P/angle.
Face Width is the width of the gear teeth.
A primer
http://en.wikipedia.org/wiki/Gear
SDPI makes hubs for 48p you can try there.
http://www.sdp-si.com/web/html/products.htm
Kevin~
Aethertek is offline Find More Posts by Aethertek
Discussion duratrax vendetta sc pinion and spur gears problem rickcallender Micro Cars 2 Jul 15, 2011 02:48 PM
Discussion pinion gears spur gears? what's what? Stuart Linfoot Power Systems 7 Aug 20, 2008 01:46 PM
Himax pinion & spur gears thenetpoet Power Systems 3 Aug 09, 2005 03:58 PM
spur gears and pinion gears NoS Off-road Cars 5 Dec 19, 2004 08:24 PM
Pinion and spur gears gearhartflyer Power Systems 1 Oct 28, 2004 11:12 AM
