Old Feb 08, 2012, 09:22 PM
pitchp is offline
Find More Posts by pitchp
No Longer Active
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
Originally Posted by exblade View Post
Chill guys.
Terry
+1 Terry. This is the reason why i took a looong break from helis for awhile. I needed to chill. I took up my other hobby, which i neglected for awhile (dating women). That has really helped me out a lot! It helped me release all that tension from crashing!!
pitchp is offline Find More Posts by pitchp
Old Feb 08, 2012, 09:40 PM
pitchp is offline
No Longer Active
pitchp's Avatar
Joined Aug 2010
On another note.. I definately can't wait to get my ZYX in the mail. I see more and more videos of the Tarot ZYX FBL unit performing almost just as good as a beastx. For the price the Tarot ZYX FBL unit is a bang for buck.
trex 450 pro v2 by tarot zyx@best (5 min 14 sec)
Old Feb 08, 2012, 09:52 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
http://www.youtube.com/watch?v=54Pj2QAbdBo
Yes, lots of good hard 3D videos like that one for the ZYX. It sure is the best indication of a good gyro. It's still hard to find one for the ASSAN GA250.
beenflying is offline Find More Posts by beenflying
Old Feb 08, 2012, 10:15 PM
pitchp is offline
No Longer Active
pitchp's Avatar
Joined Aug 2010
oh the assan what do you do with that meng. let's just move on my brother
Old Feb 08, 2012, 10:30 PM
barnstorm100 is offline
Find More Posts by barnstorm100
barnstorm100's Avatar
United States, CA, Rancho Cordova
Joined Jan 2011
ZYX unit is stuck in loading data
Hi, just got done assembling my Tarot 500 with Tarot FBL head and gyro. Started last night when I got home from work and stayed up late putting it together. I finished tonight when I got home. I still have to install tail blades and test it for a couple of batteries before I spin it up with main blades.
I'm not sure why but it won't load data to program box from unit? It worked fine last night setting up head gyro. I just need to get more travel out of the tail servo.
Thanks for any help
barnstorm100 is offline Find More Posts by barnstorm100
Old Feb 08, 2012, 11:06 PM
dhc8guru is offline
Find More Posts by dhc8guru
Joined Apr 2006
I just set mine up. All went smooth except I have no pitch and no elevator. The elevator servo functions under gyro compensation. I.E. The elevator servo moves when you pitch the nose forward and aft. All other servos function normally.
I have a jr 9303 and this is on a Trex 450. I think the unit may be bad. I I missing something?
dhc8guru is offline Find More Posts by dhc8guru
Old Feb 08, 2012, 11:29 PM
Joined Jan 2011
The unit isn't bad. Yeah, you missed something, just cant tell you what I had the same problem for a few minutes and the I saw satellite receiver was unplugged. But I think its something with receiver. Try rebinding it. Just my guess.
Old Feb 08, 2012, 11:46 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
When you say pitch and elevator do you mean the pitch and elevator servo. If you don't have pitch (collective) all three servos moving up and down then it's a cable or Rx issue. Try plugging a servo directly into the Rx and see if they do what you expect for that channel (pitch and elevator).
Also make sure your TX is configured for Helicopter 1 servo 90 degree (no mixing). When you look at your monitor screen only one channel should change with each stick axis, except throttle which should move two (pitch and throttle (unless throttle hold is on)).
Old Feb 09, 2012, 01:47 AM
Joined Jan 2011
Thanks for any help
It was the cable. Just happened to have another
Old Feb 09, 2012, 02:17 AM
MikeHRC is online now
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Check that you have your elevator cable from the FBL unit to the Rx the correct way up - it has black / red / black connectors and can easily be fitted upside-down.
MikeHRC is online now Find More Posts by MikeHRC
Old Feb 09, 2012, 10:03 AM
ZeroPitch is offline
Find More Posts by ZeroPitch
What goes up, must come down..
ZeroPitch's Avatar
United States, CA, Mission Viejo
Joined Sep 2011
HK450TT Pro finally lost her flybar...
Got my HK-450TT Pro put back together with the all-silver Tarot 450FL flybarless head and ZYX 3-axis gyro this last week. Boy is she lookin' sexy ;-)
Here's a pre-maiden checkout-flight, showing just how easy it is to use the Tarot ZYX programming card to make adjustments at the field. Tweaked pitch range, cyclic gain, and agility to get a much better feel and response.
It's a bit on the boring side, but hope you get a laugh out of the opening...
HK-450TT Pro FBL Pre-Maiden Tuning w/ZYX Gyro Programmer (11 min 12 sec)
By the way, I suggest you do NOT try to mount the gyro on top of the receiver and squeeze them both inside the frame... not enough room and vibes will totally screw things up: tried to put her in a hover and she was pitching and yawing spitting angrely about 30 degrees at a time... very lucky I put her down in one piece! Anyway, mounted both gyro and rx outside the frame, and life is now good ;-)
ZeroPitch is offline Find More Posts by ZeroPitch
Old Feb 09, 2012, 10:47 AM
ricoalonso is offline
Find More Posts by ricoalonso
ricoalonso's Avatar
USA, KS, Derby
Joined Mar 2003
very impressive. Both the pilot and the equipments. I never thought HK-450 heli can fly like that and I think I'm sold on that ZYX FBL controller. Nice flying.
ricoalonso is offline Find More Posts by ricoalonso
Old Feb 09, 2012, 11:02 AM
PHMX is offline
Find More Posts by PHMX
Never trust laughing dolphins
Joined Feb 2011
Not to interrupt, but the last time I looked, my flybarless head DOES NOT HAVE ANY MIXING ARMS! So not much to the mechanical setup beyound getting the servo horns on correctly and setting the swash servo links and up links.
I agree. Lets all take it easy.
Flybarless heads do have lower mixing arms though which need to be level.
http://www.helifreak.com/showthread.php?t=333963
And yes, they are mixing arms, that's what Align calls them.
PHMX is offline Find More Posts by PHMX
Old Feb 09, 2012, 12:11 PM
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
No need for them to be level - all they are doing is locking the head in relation to the swash.
They needed to be level previously, when they were mixing arms, to give symetrical up / down movements, all they do now is fix the swash / head relationship. So long as they have enough movement to allow full swash movement, no need for them to be flat - though they do look smarter that way
Old Feb 09, 2012, 12:19 PM
PHMX is offline
Joined Feb 2011
Not quite true, you'll see that not having them level at mid-stick will always give you unequal pitch range for positive and negative pitch directions. It simply means the three servo push rods do not get the swash plate high or low enough for a truly mechanically neutral setup.
They may not look like they are doing much, but they are in fact quite essential.
Discussion New ALZRC 3GYS Flybarless System beenflying Mini Helis 644 Dec 07, 2012 05:44 AM
Found Tarot 450 or like, long flybarless feather shafts TubeBarHeli Aircraft - Electric - Helis (FS/W) 2 Jul 25, 2011 02:13 PM
For Sale New Align 3G Flybarless System V2.1 ptt81 Aircraft - Electric - Helis (FS/W) 1 Jun 06, 2011 05:55 PM
For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system blueindian Aircraft - Electric - Helis (FS/W) 0 May 31, 2011 07:09 PM
Discussion Tarot Flybarless avengedkevinfold Electric Heli Talk 1 May 04, 2011 05:46 AM
