Old Feb 03, 2012, 09:04 PM
pitchp is offline
Find More Posts by pitchp
Retired
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
The Tarot ZYX FBL unit, definately a true performer and value for money!
T-rex 250 with Tarot ZYZ FBL system (2 min 17 sec)
pitchp is offline Find More Posts by pitchp
Old Feb 03, 2012, 10:14 PM
barnstorm100 is offline
Find More Posts by barnstorm100
barnstorm100's Avatar
United States, CA, Rancho Cordova
Joined Jan 2011
Originally Posted by pitchp View Post
the tarot zyx fbl unit, definately a true performer and value for money!
http://www.youtube.com/watch?v=n6ixx-uap2q
show off!
barnstorm100 is offline Find More Posts by barnstorm100
Old Feb 03, 2012, 11:53 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
My next build is the Gaui 255 converted to an X2 FES. I'll be using a Tarot ZYX in it. I've started a thread about it here:
http://www.rcgroups.com/forums/showthread.php?t=1587564
beenflying is offline Find More Posts by beenflying
Old Feb 04, 2012, 12:21 AM
Dr.M is offline
Find More Posts by Dr.M
Dr.M's Avatar
United States, WA, Issaquah
Joined May 2011
nice, Beenflying.
Dr.M is offline Find More Posts by Dr.M
Old Feb 05, 2012, 02:58 AM
aldav33 is offline
Find More Posts by aldav33
Joined Feb 2012
Hello
I have a problem with the Tarot ZYX. I have hard coded tail servo 960us digital. After you turn on gyro does not work the tail to one side, starts to work after connection via USB to the software. And AVCS Mode works as in Normal Mode, return to the Center. Do you know where to get the Firmware?
Thank you very much
Alda
aldav33 is offline Find More Posts by aldav33
Old Feb 05, 2012, 03:09 AM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
looking good BF, looking good.
Old Feb 05, 2012, 06:53 AM
andrea is offline
Find More Posts by andrea
Udine, Italy
Joined Mar 2001
today new 3 flights with raptor 550e.
Finally i received the usb dongle, so i was able to setup all parameters. And i correct deadstick first to 10 (but to every pitch movement hely climb immediately) later to 20 and finally to 32.
I reduced a little gyro in all directions. But as i tried to made my first loop, the ely stopped in inverted and started to go down.
The problem was too little end point movement for elevator.
Solved increasing form 32 to 45. But now the problem is that is agin very sensible on elevtor! so.. no soution for the moment to my sensibility to elevator.
And every time i try to land the last part of approaching is really difficolut cause when i m near to the lower stick, the ely loose height very fast and bumb on the ground. Well, probably this depends form incorect motor curve (i Think). but is not a big problem. The first one instead is not so good and i need to solve it.
in every case i m happy again cause at the end is the 12th fight i do and is reaaly simple to manage.
andrea is offline Find More Posts by andrea
Old Feb 05, 2012, 06:58 AM
andrea is offline
Udine, Italy
Joined Mar 2001
oh and another question for you all: i noticed that my lipos has less flyght time with respect before using the tarot.
I m using 6s packs with 5000mA 30C.
Before FBL my flight time was 7-8 min. Now is less than 5min. Is strange cause when i charge batteries they are efficient and charge completely to over 5000.
So is the unit that drain a lot of amperes?
Old Feb 05, 2012, 01:49 PM
PHMX is offline
Find More Posts by PHMX
Never trust laughing dolphins
Joined Feb 2011
It does drain slightly more mah, but it shouldn't matter minutes. It's like running an extra servo, it doesn't come for free but it surely doesn't cut flight time in half.
Perhaps you've become simply more confident and fly a bit more aggressively now?
PHMX is offline Find More Posts by PHMX
Old Feb 05, 2012, 01:56 PM
PHMX is offline
Joined Feb 2011
What are your settings exactly? 45% for end points sounds by far not enough for normal control if that's limiting the actual movement of your servos.
It could be that the gain has to be lowered. Don't think in numbers, but think in what values turn out to work in practice.
Old Feb 05, 2012, 10:28 PM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
Tarot 450 with the Tarot ZYX FBL unit
康觉之飞Tarot450 & ZYX Gyro II (2 min 57 sec)
Old Feb 06, 2012, 12:56 AM
andrea is offline
Udine, Italy
Joined Mar 2001
My settings are:
PitchAgility=40
PitchGain=32
RollAgility=40
RollGain=32
YawAgility=30
YawRight=30
YawGain=70
[section2]
FixMode=1
ServoType=2
SwashPlateType=5
ServoDirCH1=-1
ServoDirCH2=1
ServoDirCH3=1
ServoDirCH4=-1
ServoAdjustCH1=0
ServoAdjustCH2=14
ServoAdjustCH3=21
AileronLimit=32
ElevatorLimit=45
TotalCoefficient=-53
PitchDir=-1
RollDir=-1
YawDir=-1
TailPoint=-19
TailLimitA=62
TailLimitB=20
OptimizationDir=-1
[section3]
Acc1=120
Acc2=40
Acc3=125
Acc4=125
Acc5=20
Acc6=20
DeadBand1=32
DeadBand2=4
DeadBand3=20
DeadBand4=4
PitchGainD=20
PitchGainI=100
PitchGainP=80
RollGainD=20
RollGainI=100
RollGainP=80
SpinSpeed1=30
SpinSpeed2=30
SpinSpeed3=40
SpinSpeed4=40
TailCompsate1=0
TailCompsate2=0
TailGainD=25
TailGainI=40
TailGainP=80
But probably i Really need to lower gain. Next time i ll try.
Old Feb 06, 2012, 09:40 AM
PHMX is offline
Joined Feb 2011
I would also try to confirm what those Acc values are supposed to do according to the manual, because that might be an 'acceleration' value per servo channel.
Also take a very good look at the ElevatorLimit and AileronLimit. Those values seem far too low to me.
Old Feb 07, 2012, 08:37 AM
lcc014 is online now
Find More Posts by lcc014
AMA Member # 458448
lcc014's Avatar
United States, MA, ALLSTON
Joined May 2011
Pitch Curve and Throttle Curve
I am going to setup the ZYX soon. I have one question though: after setting up the ZYX controller, am I going to setup the pitch curve and throttle curve using the same steps as for the Flybar heli ?
Ching-Ho Cheng
lcc014 is online now Find More Posts by lcc014
Old Feb 07, 2012, 09:55 AM
MikeHRC is offline
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Ching-Ho Cheng
Yes - exactly the same
MikeHRC is offline Find More Posts by MikeHRC
Discussion New ALZRC 3GYS Flybarless System beenflying Mini Helis 644 Dec 07, 2012 04:44 AM
Found Tarot 450 or like, long flybarless feather shafts TubeBarHeli Aircraft - Electric - Helis (FS/W) 2 Jul 25, 2011 01:13 PM
For Sale New Align 3G Flybarless System V2.1 ptt81 Aircraft - Electric - Helis (FS/W) 1 Jun 06, 2011 04:55 PM
For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system blueindian Aircraft - Electric - Helis (FS/W) 0 May 31, 2011 06:09 PM
Discussion Tarot Flybarless avengedkevinfold Electric Heli Talk 1 May 04, 2011 04:46 AM
