Old Feb 01, 2012, 06:23 PM
barnstorm100 is offline
Find More Posts by barnstorm100
barnstorm100's Avatar
United States, CA, Rancho Cordova
Joined Jan 2011
Originally Posted by PHMX View Post
What exactly is wrong? Don't they only sell the Tarot 500ESP? If not, then there's clearly a typo on their website seeing how there's two of them.
They show a Tarot 500 ESP but I don't think they have any. After not sending anything for a month, I sent a message to credit my paypal account. They replied they would send it out that day. Well, I got it today and its the plastic model EP500.
barnstorm100 is offline Find More Posts by barnstorm100
Old Feb 01, 2012, 06:53 PM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
Yea I think leader had the plastic 500 for like $40
mhills51 is offline Find More Posts by mhills51
Old Feb 01, 2012, 09:46 PM
ebartolome is offline
Find More Posts by ebartolome
ebartolome's Avatar
United States, CA, San Diego
Joined Dec 2010
A very good write up from TOYRECYCLER on tuning the ZYX.
Check it out
http://www.toyrecycler.net/?p=23279
This site may answer many questions regarding the values in the advance menu.
ebartolome is offline Find More Posts by ebartolome
Old Feb 01, 2012, 10:58 PM
Dr.M is offline
Find More Posts by Dr.M
Dr.M's Avatar
United States, WA, Issaquah
Joined May 2011
Very good write-up indeed. Sounds a lit like the AC-3X manual...
Dr.M is offline Find More Posts by Dr.M
Old Feb 02, 2012, 12:36 AM
jaahaavi is offline
Find More Posts by jaahaavi
Joined Oct 2011
Check it out
It seems to be direct copy paste from http://www.rcgroups.com/forums/showthread.php?t=1579703
I wrote that manual and asked if people from this forum, if anyone has something to add there or find errors from that.
Manual is still missing information for swash acceleration and deceleration. Can anybody tell what happens if swash acceleration/deceleration is too low or high?
jaahaavi is offline Find More Posts by jaahaavi
Old Feb 02, 2012, 12:49 AM
John_NZ is offline
Find More Posts by John_NZ
New Zealand, Taranaki, New Plymouth
Joined Jan 2012
Hi,
Would you mind if I integrated the information on your 'manual' into my FBL software.
I am thinking that I could add a ? to each parameter and pop up a dialog with the relevant information in it.
- John
John_NZ is offline Find More Posts by John_NZ
Old Feb 02, 2012, 02:36 AM
jaahaavi is offline
Joined Oct 2011
Originally Posted by John_NZ View Post
Hi,
- John
Sure you can use it. It would be great that the PC software has explanations for those settings.
Old Feb 02, 2012, 03:59 AM
Dr.M is offline
Dr.M's Avatar
Joined May 2011
good job jaahaavi! Thanks.
For the swash accel/decel, I'm guessing they act the same as for the tail.
Also I disagree with your manual on the point that Pitch and Roll settings ought to be the same. A helicopter is an asymmetric machine. It's far easier to roll than flip over the tail boom. It's also easier to roll right for that matter as well as yaw left. Just my $0.02...
Old Feb 02, 2012, 07:44 AM
ebartolome's Avatar
Joined Dec 2010
Great write up jaahaavi
Thanks for taking the time to do this.
Old Feb 02, 2012, 02:44 PM
PHMX is offline
Find More Posts by PHMX
Never trust laughing dolphins
Joined Feb 2011
Either that or one of the ESPs is actually an EP version. Makes sense too as they are both belt versions.
I'd ask them for an exchange and send it back, if doing that is worth anything to you.
PHMX is offline Find More Posts by PHMX
Old Feb 02, 2012, 09:11 PM
RobK is offline
Find More Posts by RobK
RobK's Avatar
State College, PA USA
Joined Oct 2005
+1 installed and flying...
Finally had the time to install my ZYX and Tarot head on the used 250 clone I got a few months back. I did not not really want to even bother with the 250 Tarot head until I got a hold of some green bearing retainer compound to take the head slop out of those blade grips. With that sorted out, the rest was all pretty simple. I did the standard setup via the radio (tips from ZeroPitch helped! -- Thanks!) and things went smooth. Once I got most of the mechanical slop out of my tail, and got the tail gain dialed in, I was pretty happy with it. I have about 20+ flights on it, and it's more fun each time I fly it! A few pics are on my blog.
Eventually, I may order a cable and try out the software to fine tune things, but I pretty much like it the way it is so far.
RobK is offline Find More Posts by RobK
Old Feb 02, 2012, 11:04 PM
Joined Jan 2011
Thanks PHMX, the guy said he would give me a full refund if I send it back but its $30 to $40
Old Feb 03, 2012, 05:46 AM
jaahaavi is offline
Joined Oct 2011
Yeah, I think you got point there. My explanation is misleading.
e.g. I had wrote:
("Roll D gain" and "Pitch D gain" values should be always the same.)
But I meant to wrote something like this:
(In all five default profiles "Roll D gain" value is identical to "Pitch D gain" value.)
Is that now better?
Old Feb 03, 2012, 06:46 AM
PHMX is offline
Joined Feb 2011
Alright. That's to bad man. Yeah, sounds like you'd better keep it and upgrade some of the plastic stuff then, right? For a return of around 100$, I'd probably keep the model.
What strikes me though is that they also have two different prices. One is 206.33$ , the other is 148.88$.
I think they should clarify why there's such a difference there, regardless of a full refund.
Old Feb 03, 2012, 08:19 AM
Joined Jan 2011
Yeah, the $148 one wasn't there the other day. I think they got a shipment of the cheaper one in and didn't realize they were different. They are going to send out the metal parts to replace the plastic ones.
Thanks for noticing. I don't think they were trying to pull a fast one. They just didn't know.
Discussion New ALZRC 3GYS Flybarless System beenflying Mini Helis 644 Dec 07, 2012 04:44 AM
Found Tarot 450 or like, long flybarless feather shafts TubeBarHeli Aircraft - Electric - Helis (FS/W) 2 Jul 25, 2011 01:13 PM
For Sale New Align 3G Flybarless System V2.1 ptt81 Aircraft - Electric - Helis (FS/W) 1 Jun 06, 2011 04:55 PM
For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system blueindian Aircraft - Electric - Helis (FS/W) 0 May 31, 2011 06:09 PM
Discussion Tarot Flybarless avengedkevinfold Electric Heli Talk 1 May 04, 2011 04:46 AM
