Old Jan 23, 2012, 12:30 PM
PHMX is offline
Find More Posts by PHMX
Never trust laughing dolphins
Joined Feb 2011
Yes, that's my understanding as well.
I don't quite know the difference between 80 and 40 in real-life with faster servos, but I'd reckon it's huge.
PHMX is offline Find More Posts by PHMX
Old Jan 23, 2012, 02:11 PM
nieves50 is offline
Find More Posts by nieves50
nananabooboo!!
nieves50's Avatar
United States, OK, Oklahoma City
Joined Mar 2003
So....can anybody explain this: Missing text and unabled to maximize screen...
IDK...update video drivers?
nieves50 is offline Find More Posts by nieves50
Old Jan 23, 2012, 02:32 PM
Dr.M is offline
Find More Posts by Dr.M
Dr.M's Avatar
United States, WA, Issaquah
Joined May 2011
There's 2 dead bands (DB):
RC DB is the one applicable to the stick - big number ignores stick movement around center; small number can result in unintended input on the wrong axis<< taylor this to how precise your stick movements are.
Gyro DB ignores small gyro corrections - big number results in poor stability and drift; too small a number can overwork your servos<<taylor this to your servo DB.
Dr.M is offline Find More Posts by Dr.M
Old Jan 23, 2012, 02:48 PM
ZeroPitch is offline
Find More Posts by ZeroPitch
What goes up, must come down..
ZeroPitch's Avatar
United States, CA, Mission Viejo
Joined Sep 2011
Ahhhhh... that makes sense and explains why there are 2 settings, lol...
ZeroPitch is offline Find More Posts by ZeroPitch
Old Jan 23, 2012, 02:53 PM
VArchT is offline
Find More Posts by VArchT
SoCal
VArchT's Avatar
Joined Oct 2011
I believe this is the issue.
Originally Posted by beenflying View Post
The Tarot app is expecting a DPI setting of 96. If you've increased the Windows font size (which changes the DPI setting) the app will not fit in the frame.
VArchT is offline Find More Posts by VArchT
Old Jan 23, 2012, 03:31 PM
nieves50 is offline
nananabooboo!!
nieves50's Avatar
Joined Mar 2003
You are correct....Fixed my issue by going to (WIN 7)
CONTROL PANEL / APPEARANCE & PERSONALIZATION / DISPLAY / MAKE EASIER TO READ WHATS ON YOUR SCREEN.
It was @ 125%....changed to 100% and all is good....
Software still crashes if I immediately start messing with settings???
Old Jan 23, 2012, 05:44 PM
barnstorm100 is offline
Find More Posts by barnstorm100
barnstorm100's Avatar
United States, CA, Rancho Cordova
Joined Jan 2011
Had a chance to take my Mini Titan to the park after installing new HiTec HS5065 MG digital servos. I lowered the RC dead band on tail. This now is the best heli I've ever flown. I also have a Blueray Trex clone with the ZYX gyro on it. I going to try the #3 model with that one on the ZYX and do some more flips. This gyro has changed the way I think about these helis. That's why I got a Tarot FBL head and gyro for the Tarot 500 ESP that I'm getting. Can't wait to put that one together.
barnstorm100 is offline Find More Posts by barnstorm100
Old Jan 23, 2012, 07:11 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
I got the Tarot 500 FBL head the other day as well. Looks like a nice piece of kit. I'd like to have seen the blade arms a little bit longer but it shouldn't be a problem.
I was surprised it wasn't as low as the Align 500EFL Pro head. Tarot were quick to lower the 450 head to flybar height but seem to have keep this head at the 500 3G FBL height.
Perhaps they'll release another rotor housing in the future like they have with the 450 head.
I see Align have just released a new 550/600 low head (like the recently released 700DFC head):
http://www.helipross.com/600dfc-main...et-h60239.html
Let's hope a 500 and 450 DFC head is yet to follow.
beenflying is offline Find More Posts by beenflying
Old Jan 23, 2012, 09:48 PM
ZeroPitch's Avatar
Joined Sep 2011
Got my 3rd ZYX Gyro today and another 450FL head, this one all silver and just dying to get dropped in my HK450TT Pro
Old Jan 23, 2012, 09:58 PM
Dr.M is offline
Dr.M's Avatar
Joined May 2011
Nice new head from Align. Looks a lot like the compass FBL head design, which I've always liked.
Old Jan 23, 2012, 10:46 PM
Joined Jan 2011
I probably won't notice the height difference but if they come out with a different one, I'm sure to get it.
Have you been able to use the links that come with the Tarot 500FBL head? I know the one end is reverse thread but I can't get them to screw together. I got a set of links for a Trex 500FL and hoping they fit.
Old Jan 23, 2012, 10:53 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Yes, I've always liked the compass FBL head, also. I wonder how well it stands up in a crash. If it's stronger than a wire pushrod and less likely to pop off, then the servo gears are going to suffer. They need to start thinking about servo arms that will shear off under a very high load.
Old Jan 23, 2012, 10:58 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
I haven't opened the packet yet. You have to hold the rod and screw each ball link on separately (noting which one is reverse) and pushing firmly.
I use these ones now:
http://www.infinity-hobby.com/main/p...oducts_id=5317
Old Jan 23, 2012, 11:18 PM
Dr.M is offline
Dr.M's Avatar
Joined May 2011
Aren't those too long for a 450? 48mm? Mine are 33 mm on the CopterX Black Angel FBL head...
Old Jan 23, 2012, 11:21 PM
Dr.M is offline
Dr.M's Avatar
Joined May 2011
I agree. The new Aligns and the ones on Compass don't look like they pop off at all. This might translate to pulverized servos in a crash... Especially on bigger birds.
Discussion New ALZRC 3GYS Flybarless System beenflying Mini Helis 644 Dec 07, 2012 04:44 AM
Found Tarot 450 or like, long flybarless feather shafts TubeBarHeli Aircraft - Electric - Helis (FS/W) 2 Jul 25, 2011 01:13 PM
For Sale New Align 3G Flybarless System V2.1 ptt81 Aircraft - Electric - Helis (FS/W) 1 Jun 06, 2011 04:55 PM
For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system blueindian Aircraft - Electric - Helis (FS/W) 0 May 31, 2011 06:09 PM
Discussion Tarot Flybarless avengedkevinfold Electric Heli Talk 1 May 04, 2011 04:46 AM
