Old Mar 09, 2013, 08:58 AM
Xermalk is offline
Find More Posts by Xermalk
Sweden, Helsingborg
Joined Jun 2012
Originally Posted by War Horse View Post
Well crap, I cant unzip the v4.0 RAR file and the online sites want money for that...
Apparently my FDM isnt capable with RAR
http://www.7-zip.org/ if your running windows.
or p7zip in linux package managers.
Edit: lol theres even a compile for amiga.
Xermalk is offline Find More Posts by Xermalk
Old Mar 09, 2013, 09:10 AM
War Horse is offline
Find More Posts by War Horse
War Horse's Avatar
United States, FL, Hernando
Joined Sep 2012
Ahh, thank you
War Horse is offline Find More Posts by War Horse
Old Mar 09, 2013, 09:29 AM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
7Zip
You should be able to download 7zip which is freeware and should be able to extract it.
2Doggs is offline Find More Posts by 2Doggs
Old Mar 09, 2013, 09:34 AM
bionicbone is offline
Find More Posts by bionicbone
Whoops was it always in 2 bits
bionicbone's Avatar
United Kingdom, England, Rotherham
Joined Oct 2008
Originally Posted by FyreSG View Post
I took the plunge and went ahead to fly it. It was ok, everything was fine. When the bird is in the air, I could feel the big difference between a rate of 100% vs a rate of 70%, even though there are no differences on the bench.
Thanks Mike for your explanation.
I think I've leaned a lot also over the last few days and think I get the logic of what Mike is saying about limiting the inputs and not what the ZYX can do to counteract the outside influences.
I'm about to go for a full reset along with a swap out my head conversion for a DFC. This time I'll try to set the ZYX up as stated in the previous discussions as now I have the feeling that I may be flying FBL but not making full use of the FBL controller.
Let's see if I can tell the difference with my flying ability
Kev
bionicbone is offline Find More Posts by bionicbone
Old Mar 09, 2013, 10:01 AM
MikeHRC is offline
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Just loaded V4 onto my 250 as well, quick couple of flights - very happy
MikeHRC is offline Find More Posts by MikeHRC
Old Mar 09, 2013, 10:22 AM
fpainter3 is offline
Find More Posts by fpainter3
fpainter3's Avatar
USA, KY, Florence
Joined Aug 2007
I just flew a pack out in the yard. gusty conditions. the heli held great in the wind.I did not get it going fast enough to test the nose up anomaly.
It jumps around less and the servos are a lot less twitchy. it might be my imagination, but the battery seemed to have a lot more left in it when I was done. The new algorithm may save power as well.
fpainter3 is offline Find More Posts by fpainter3
bionicbone's Avatar
Joined Oct 2008
Here's something that happens for me, maybe its the same for everyone and I've just never seen it mentioned before.
Using the programming version 1.22, when I "Tools - Copy Condition - Copy 2 to 1" - as always recommended - I have to follow by pressing the "Force Update" button before the conditions are written to the ZYX.
I've just moved from version 1.16 of the programming software and it seems that I must have been flying using the condition 2 settings as condition 1 were way out. I'm not sure why I was using the 2nd set of conditions? If I only had access to 1 set surely that would be set 1 LOL.
Kev
Old Mar 09, 2013, 10:25 AM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
Kev
No, I think that was the "dark secret" of the CX and ZYX - those condition 2 F3C defaults were always lurking there, obviously more easy to spot, but also more likely to cause a spill, if you happened to be using a negative collective range value. Some combination of plugging up the heli could boot the controller into condition 2. I've yet to figure out what, exactly.
Old Mar 09, 2013, 10:57 AM
bionicbone's Avatar
Joined Oct 2008
Yeah, very annoying actually, I've been playing with condition 1 before I started my re-config and using the copy 2 - 1 actually messed up settings in config 2. Defo sure that I never hit the copy button from 1 - 2 but was using the force update button on both 1 and 2 and somehow I managed to copy the bad servo settings from 1 to 2 LOL.
I can laugh as I was going to reset it all anyway to start again and i took screen shots of the settings before I started so if need be i should be able to put back.
Kev
Old Mar 09, 2013, 11:24 AM
jombo is offline
Find More Posts by jombo
Bad News Everyone
jombo's Avatar
United States, CT, Trumbull
Joined Dec 2007
Is there any way to make a desk top icon ? To get to the 4.0 software do i always need to go into the 7zip to extract it?
jombo is offline Find More Posts by jombo
Old Mar 09, 2013, 11:28 AM
jombo is offline
Bad News Everyone
jombo's Avatar
Joined Dec 2007
Never mind i got it
Old Mar 09, 2013, 12:54 PM
nascar1929 is offline
Find More Posts by nascar1929
Head in the clouds
nascar1929's Avatar
United States, NC, Gastonia
Joined Jan 2012
I'm sill using v3.0 since I have read about some of the issues with v3.5. Would there be any advantage to upgrading to v4.0 or should I just stick with v3.0 since it's doing fine right now?
nascar1929 is offline Find More Posts by nascar1929
Old Mar 09, 2013, 01:05 PM
fpainter3's Avatar
USA, KY, Florence
Joined Aug 2007
I would go to 4 if I were you. You may have to change a few things .When I went from 3 to 3.5 I had to increase the "d" gain.
I just flew another pack. The Cyclic response is much better too. It just ignores gusts of wind that used to upset it. I noticed that you have to take a little more care on the ground to make sure your swash is level prior to lift off.
Old Mar 09, 2013, 01:14 PM
sp00fman is offline
Find More Posts by sp00fman
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
Just received and installed a new Tarot swashplate for my nightheli. 10 minute job
Will check if it can stop raining for a minute and get another test-flight out.
sp00fman is offline Find More Posts by sp00fman
Old Mar 09, 2013, 01:29 PM
Head in the clouds
nascar1929's Avatar
Joined Jan 2012
I just downloaded v4.0 and put the (S-version).bin file in my upgrades folder. Do I need to upgrade to v3.5 first or can I jump from v3.0 straight to v4.0?
Discussion New ALZRC 3GYS Flybarless System beenflying Mini Helis 644 Dec 07, 2012 04:44 AM
Found Tarot 450 or like, long flybarless feather shafts TubeBarHeli Aircraft - Electric - Helis (FS/W) 2 Jul 25, 2011 01:13 PM
For Sale New Align 3G Flybarless System V2.1 ptt81 Aircraft - Electric - Helis (FS/W) 1 Jun 06, 2011 04:55 PM
For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system blueindian Aircraft - Electric - Helis (FS/W) 0 May 31, 2011 06:09 PM
Discussion Tarot Flybarless avengedkevinfold Electric Heli Talk 1 May 04, 2011 04:46 AM
