Old Mar 08, 2013, 11:08 AM
lcc014 is online now
Find More Posts by lcc014
AMA Member # 458448
lcc014's Avatar
United States, MA, ALLSTON
Joined May 2011
Originally Posted by Busher View Post
Do you or anybody else know if this software can be used on all gyro,s zyx-s and zyx, the only reference I can find is for the zyx-s
So have they stopped supporting the zyx? Or has anybody just flashed all their gyro,s with the new software?
This 4.0 software contains 2 images, one for zyx and one for zyx-s.
lcc014 is online now Find More Posts by lcc014
Old Mar 08, 2013, 11:09 AM
AMA Member # 458448
lcc014's Avatar
Joined May 2011
Originally Posted by DJO View Post
I got the v4.0 software from online, the link before.. I extracted it and opened the folder but I don't have the zyx40_en.exe program to run the software..
Can you do a print screen to show what files are in the zyx4.0 folder ?
Old Mar 08, 2013, 11:10 AM
DJO is offline
DJO
Find More Posts by DJO
DJO
Deriving Equations
DJO's Avatar
Joined Oct 2011
Found it
It was NOT there before, but that works for me
Dan
DJO is offline Find More Posts by DJO
Old Mar 08, 2013, 11:12 AM
DJO is offline
DJO
DJO
Deriving Equations
DJO's Avatar
Joined Oct 2011
...still can't get it connected though.. LOL
Old Mar 08, 2013, 11:13 AM
Busher is offline
Find More Posts by Busher
Joined Apr 2011
Thanks for the prompt reply..
Busher is offline Find More Posts by Busher
Old Mar 08, 2013, 11:41 AM
Dr.M is offline
Find More Posts by Dr.M
Dr.M's Avatar
United States, WA, Issaquah
Joined May 2011
Looks like they've added a governor function to the v4 firmware. There's also a new "Burst Coefficient" which is explained as "enhance the response speed of the stick" (referring to cyclic control).
Dr.M is offline Find More Posts by Dr.M
Old Mar 08, 2013, 11:42 AM
AMA Member # 458448
lcc014's Avatar
Joined May 2011
I just updated both zyx and zyx-s to v4.0 using the zyx40_en.exe. Very straight forward and had no connection problem.
Old Mar 08, 2013, 11:43 AM
AMA Member # 458448
lcc014's Avatar
Joined May 2011
Yeah, Governor mode is nice to have but we need a extension module (zyx20) for this feature to work.
In the zyx4.0EN folder, there are update instructions for zyx and zyx-s in doc and pdf formats. In zyx-s update instruction, it shows the pins out to connect a rpm sensor, dual s-bus and the detail explanation of setting up governor mode using the extended module (zyx20). So, zyx-s Governor mode may be similar to Skookum and vbar.
Old Mar 08, 2013, 12:06 PM
Xermalk is online now
Find More Posts by Xermalk
Sweden, Helsingborg
Joined Jun 2012
Any point in running gov mode on the gyro when you can have it through the esc?
Wouldn't it just consume cpu cycles uselessly?
Xermalk is online now Find More Posts by Xermalk
Old Mar 08, 2013, 12:28 PM
AMA Member # 458448
lcc014's Avatar
Joined May 2011
From what I saw in Helifreak.com, people prefer gyro governor than ESC governor. Gyro governor is active and ESC governor is passive. ESC just concentrates on motor speed while gyro will take both heli condition and motor speed into account to maintain the head speed.
Old Mar 08, 2013, 01:05 PM
Dr.M is offline
Dr.M's Avatar
Joined May 2011
First test flight with ZYX firmware 4.0
Hi guys,
I've recently upgraded one of my CX-ZYX frankengyros to firmware 4.0 and took it for a short test flight in the driveway. Overall impression is that the differences in flight behavior are subtle:
- piro compensation seems to be a bit better. I was able to get about 4 full piros before needing any correction input on cyclic. For some reason my 450 seems to piro much more level CW (5-6 full revs before correction) than CCW (4 full revs before correction).
- without changing anything since v3.5, I'm getting a faint (high-gain) wobble on cyclic roll after the upgrade.
- cyclic feel seems a bit crisper and more connected.
- collective feel unchanged (still vague).
I'm planning a trip to the field later today to do some more testing, including the looking into whether they solved the pitch-up tendency in FFF. Stay tuned for more...
Old Mar 08, 2013, 01:27 PM
sp00fman is offline
Find More Posts by sp00fman
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
Omg omg omg, so excited about the new firmware I really like to see if piros are truly improved. Even adding a gov function, NICE..... Tarot is putting out some superb work.
I might just test it on my night heli this evening....
sp00fman is offline Find More Posts by sp00fman
Old Mar 08, 2013, 02:00 PM
jombo is offline
Find More Posts by jombo
Bad News Everyone
jombo's Avatar
United States, CT, Trumbull
Joined Dec 2007
I downloaded it too but it said i already installed it . So I guess I had the new software all along
jombo is offline Find More Posts by jombo
Old Mar 08, 2013, 03:09 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Originally Posted by FyreSG View Post
The official v4.0 firmware binary is different from the v4.0 that Tarot sent me. I flashed it and... the violent servos came back! So, I'm back to the customized v4.0 now.
That's a real pity. Did you advise Tarot that your special firmware also fixed my servo kick and lockout problem with the Align DS410M. If they know there are more issues of this, then they might add it to the official release.
beenflying is offline Find More Posts by beenflying
Old Mar 08, 2013, 03:12 PM
vs0587 is offline
Find More Posts by vs0587
Joined Dec 2010
The fw v4 fix the single sat binding with dx8?
vs0587 is offline Find More Posts by vs0587
Discussion New ALZRC 3GYS Flybarless System beenflying Mini Helis 644 Dec 07, 2012 04:44 AM
Found Tarot 450 or like, long flybarless feather shafts TubeBarHeli Aircraft - Electric - Helis (FS/W) 2 Jul 25, 2011 01:13 PM
For Sale New Align 3G Flybarless System V2.1 ptt81 Aircraft - Electric - Helis (FS/W) 1 Jun 06, 2011 04:55 PM
For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system blueindian Aircraft - Electric - Helis (FS/W) 0 May 31, 2011 06:09 PM
Discussion Tarot Flybarless avengedkevinfold Electric Heli Talk 1 May 04, 2011 04:46 AM
