Athens
Joined Sep 2006
kings lynn, norfolk uk
Joined Sep 2007
getting ready to convert my 500 to fbl. just wondered if any one is using the tarot split lock head and did it come with the little head button on the top, because mine didn't, not that it matters i suppose. just wondered if it should have one as it has the hole.
Anyway, to slow the blades down just push the pitch to maximum, when the head speed has dropped enough, that it won't lift off. They will slow down pretty quick by doing this. |
Latest blog entry: RC Parts Suppliers - The Good and the...
Help with ZYX initialization!
When my heli powers up, ZYX will initialize by moving the 3 cyclic servo arms at their full range of motion. The servo arms move so far that it hits the frame hard. The movements are so fast and forceful that the ball links are snapped out of the swash plate.
![]() How do I fix this? I have setup the heli such that there are no bindings at full collective and full cyclic. But the servos do not seem to obey the limits during initialization.
Hi Guys, just a heads up (no pun intended) on anyone that purchased the Tarot FBL non DFC head from Miracle Mart when they were on special for $11.90 (and had stock). I bought 2 of them and they arrived a few weeks ago.
I've worked out why they are on such a good special.... the feathering shaft has not been made correctly. The screws that go in the end to hold the grips and thrust bearings in does not screw into the feathing shaft all the way. It's about 2 turns too short. Looks like when they tapped the thread in the end it has not gone in far enough. Both of my units are the same so I'm guessing they are all like that. The rest of it looks great and I just swapped out the feathering shaft with a spare. This is the link to the Tarot head on special: http://www.miracle-mart.com/store/in...oducts_id=8741 ![]() Cheers Jonesy |
I may make a video later if it helps explain the issue but here's a simplified diagram of the extreme servo arm movements. ![]() Code:
+45 deg
+-----+ x
| | x
| | x
|ser x (Small range during stick movements)
| vo | x
| | x
+-----+ x
-45 deg
+60 deg
+-----+ x
| | x
| |x
|ser x (Huge range during initialization)
| vo |x
| | x
+-----+ x
-60 deg
Thanks guys!
If you take the feathering shaft apart and take the thrust bearing off then just screw the bolt with the little brass washer into the feathering shaft, the washer should meet the end of the feathering shaft. If you can still see thread between the end of the FS and the brass washer it's dodgy as there will be too much play in the thrust bearing. Hope that helps. |
Disconnect all servo and redo the setup for servo first. After you done, connect the servo. It's really unusual behavior. |
Oxfordshire, UK
Joined Jan 2007
below:
What's wrong?
| Thread Tools | |
| Discussion New ALZRC 3GYS Flybarless System | beenflying | Mini Helis | 644 | Dec 07, 2012 04:44 AM |
| Found Tarot 450 or like, long flybarless feather shafts | TubeBarHeli | Aircraft - Electric - Helis (FS/W) | 2 | Jul 25, 2011 01:13 PM |
| For Sale New Align 3G Flybarless System V2.1 | ptt81 | Aircraft - Electric - Helis (FS/W) | 1 | Jun 06, 2011 04:55 PM |
| For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system | blueindian | Aircraft - Electric - Helis (FS/W) | 0 | May 31, 2011 06:09 PM |
| Discussion Tarot Flybarless | avengedkevinfold | Electric Heli Talk | 1 | May 04, 2011 04:46 AM |
