West Monroe NY
Joined Feb 2009
yeah, I actually did get it to work with my DX7.....but I just want to fly with my DX8
![]() Anyway, after wasting another evening I am throwing in the towel. I mounted it with a full RX, dosen't look so bad
West Monroe NY
Joined Feb 2009
![]() At first I used a Orange RX 9 ch but my rudder didn't work, everything else did but not the rudder. So here is what I did: Used an AR6200 (DMS2 RX, NOT DSMX), connect your satellite to the 6200, or orange 6 ch but it appears to require a 6 chan RX so the rudder maps correctly in the ZYX-s. Once you bind the satellite to the AR6200, plug it into the RUDDER channel of the ZYX-s with your ESC in the AIL channel. Power up the ZYX-s and hit the reset button untl you get a solid red or blue light, connect your PC or programmer and select DSM2-2 for the interface. Save exit and reboot the ZYX-s and everything should work..... proceed with setup ![]() BTW, it should work with a DSMX satellite but you must use a DSM2 RX to bind, the ZYX-s does not understand DSMX....
West Monroe NY
Joined Feb 2009
so final note before flight testing, I spent quite a bit of tonight bench testing this heli, got everything all set. Twice tonight the tail locked up, I switched modes, the gyro switch and the light changed and the tail unlocked. I have no idea why the tail locked and I could not replicate it, I mean other that the first 2 times it happened.
I also noticed that they cyclic servos twitch when I switch between HH and RATE mode. Now, in real life I never use RATE mode and typically only switch between the two during initial setup flights, but it concerns me. When I see things like that I wonder about other design quality issues might be buried in the box Anyway, everything is setup, moves in the correct direction and I have not been able to lock up the tail so it looks like as soon as the weather breaks ....she flies
| Thread Tools | |
| Discussion New ALZRC 3GYS Flybarless System | beenflying | Mini Helis | 644 | Dec 07, 2012 04:44 AM |
| Found Tarot 450 or like, long flybarless feather shafts | TubeBarHeli | Aircraft - Electric - Helis (FS/W) | 2 | Jul 25, 2011 01:13 PM |
| For Sale New Align 3G Flybarless System V2.1 | ptt81 | Aircraft - Electric - Helis (FS/W) | 1 | Jun 06, 2011 04:55 PM |
| For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system | blueindian | Aircraft - Electric - Helis (FS/W) | 0 | May 31, 2011 06:09 PM |
| Discussion Tarot Flybarless | avengedkevinfold | Electric Heli Talk | 1 | May 04, 2011 04:46 AM |
