Old Jan 21, 2013, 02:17 PM
War Horse is offline
Find More Posts by War Horse
War Horse's Avatar
United States, FL, Hernando
Joined Sep 2012
Originally Posted by Blade Crasher View Post
ZYX-s or Robird G31?
I'm getting ready to order a controller. These two seem like the ones to go with. But which one?
I'm going to use it on a 450pro clone with HS-65 cyclics and Futaba s9257 tail. I'm just a sport flyer, no 3D.
Thoughts?
I cant compare the two, but my money would be on the ZYX-s , seems more support for it. I have it on a HK450 with HK922MG on cyclic and tail and a 40A Mystery ESC, and I couldnt be happier.
But then again, what I dont know wont hurt me either
War Horse is offline Find More Posts by War Horse
Old Jan 21, 2013, 03:49 PM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
Thoughts?
I only have a couple of 3x1000's, one of which is a CX-ZYX 3.5, and they're great value for money. If satellite RX support is important to you, the ZYX-s is the one to go for, but the Robird offers a vibe log, which can be handy, and also features a governor if you use a sensor. Both fly well, with possibly more people who own both preferring the G31 by a small margin, though some of those preferences are based on ease of setup rather than actual flight performance.
2Doggs is offline Find More Posts by 2Doggs
Old Jan 21, 2013, 05:24 PM
ewoodcox is online now
Find More Posts by ewoodcox
Axes & Blades-Cutlery & Helis
West Monroe NY
Joined Feb 2009
I read the robird g31 manual, it has support for satellite RXs as well. Does anyone know if that is accurate? I have 2 ZYX-s but am thinking about picking up the Robird for another project....
ewoodcox is online now Find More Posts by ewoodcox
Old Jan 21, 2013, 10:12 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Yes the robird supports two satellites if you purchase an additional adapter (one comes with the gyro). The ZYX-S supports one satellite, if you purchase the adapter.
beenflying is offline Find More Posts by beenflying
Old Jan 21, 2013, 10:13 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Originally Posted by JetPlaneFlyer View Post
Fixed!
Here's how I did it should anyone else have the same problem:
  • Plug in USB lead, power up Tx and gyro/Rx.
  • All three lights stay solid indicating no communication, PC software wont connect in this state.
  • Press set button once - only yellow light comes on
  • Press set button again -only blue light comes on
  • Now connect PC software, it should connect ok while the blue light is on.
  • Re-set 'receiver type' to 'conventional', update settings and that's it fixed
Thanks, JetPlaneFlyer. Added a link to this in the first post, under PC connection issues.
Old Jan 22, 2013, 08:36 PM
ingleburn is offline
Find More Posts by ingleburn
Australia, NSW, Ingleburn
Joined Dec 2009
Test pilots needed
Looks like test pilots are needed for a new Gyro.
http://www.bglmodel.com/news_read.asp?id=159
ingleburn is offline Find More Posts by ingleburn
Old Jan 23, 2013, 06:46 AM
fpainter3 is offline
Find More Posts by fpainter3
fpainter3's Avatar
USA, KY, Florence
Joined Aug 2007
Is that a joke? Bigaole - Big A hole
fpainter3 is offline Find More Posts by fpainter3
Old Jan 23, 2013, 07:49 AM
West Monroe NY
Joined Feb 2009
everytime I see that name I see the same thing.....
Old Jan 23, 2013, 12:38 PM
sp00fman is offline
Find More Posts by sp00fman
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
Dig A Hole
BigHole
sp00fman is offline Find More Posts by sp00fman
Old Jan 23, 2013, 07:52 PM
CSI is offline
CSI
Find More Posts by CSI
CSI
I promise, just ONE more order
CSI's Avatar
Del Rio Intl, Texas, United States
Joined Feb 2004
Hi guys...another new user of the ZYX system.
I have 2 of the ZYXs and 1 ZYX units. I also have the USB adapter and the larger control input programmer box.
Guys, I am sorry to ask such newbe questions about this thing. I fly planes and dabble with helis. I have a 250, HBK2, 450, 500, and a 600 in it's box. I am building the 500 right now. I can fly basic sport, but no 3d.
I am converting all my helis over to the ZYX system.
I am reading the ZYX threads as fast as I can, but still quite confused on some things.
Just to help me get started with the hookups.
--when/where do you use the USB adapter?
--what is the programmer box for? When is it used or how is it different than the USB adapter?
--the single plug splitting into 3 leads/plugs......single goes into the ZYX but where do the 3 single leads go? I assume into my Spektrum RX? (I'm using a Spektrum DX7)
--is the above hookups only for the one ZYX I have and not for the 2 ZYXs?
--is there a ZYXs specific manual or do they all use the same one? I cannot find a seperate one.
Again, I apologize now for the basic questions but I would like to get a grasp on what the heck I am trying to hookup. The programming seems a lot like my 520 MEMS gyros I have on the helis right now so hopefully I will grasp that a bit better.
Thanks so much for any help,
Ken
CSI is offline Find More Posts by CSI
Old Jan 24, 2013, 03:35 AM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
Programming with the USB adaptor hooked up to your pc, running either the Tarot software or John_NZ's FBL software is quicker and easier than programming with the program box - unless you have an aversion to pc's.
The program box is handy for tweaking things at the field, and can also function as a servo tester, so it complements the usb adaptor.
The three plugs from the split lead connect to your RX - the plug with the black wire is tail gain, usually Ch5, the one with the red lead is to elevator and the one with the white lead is pitch, usually Ch6. There's a diagram on page 2 of the ZYX pdf manual, not sure about the ZYX-s manual.
There are two separate leads used to connect the aileron and rudder outputs of the ZYX to your RX.
Your cyclic servos will plug directly into the ZYX inputs marked #1, #2 and #3. Usually the right aileron servo is #1, the left one is #2 and the elevator servo is #3 - the servo numbering for various swash types is shown in the diagram on page 2 of the manual.
If you can't get the servos moving correctly, double check and triple check your connections, and make sure everything is plugged in with the correct polarity.
Have fun!
Old Jan 24, 2013, 06:57 AM
War Horse's Avatar
Joined Sep 2012
CSI, this will help you with the program box and wiring;
http://www.raptortechnique.com/tarot/setup-prg_box.html
The link to John NZ software;
http://fbl.net.nz/
And a 3 part video from Simon that helped me more than I can say;
http://www.youtube.com/watch?feature...&v=9HViG2Xe1Ik
http://www.youtube.com/watch?feature...&v=08Vkbco6b8A
HK-450GT Flybarless Conversion - pt 5 - Final Setup (33 min 22 sec)
Old Jan 24, 2013, 03:06 PM
kenbad is offline
Find More Posts by kenbad
kenbad's Avatar
Joined Dec 2011
Hey I have a brand new Tarot zyx w/usb I have no use for, the bag of leads has been open to borrow one, I have put it back in the bag. will sell for 50 bucks free shipping to the northern 48. Must use PayPal
PM me if interested
***SOLD***
kenbad is offline Find More Posts by kenbad
Old Jan 25, 2013, 10:04 AM
Whiskey Whiskey is offline
Find More Posts by Whiskey Whiskey
United States, CA, Fairfield
Joined Jul 2004
Pardon me for not reading through this entire thread, but a search for "zyx gas" wasn't very productive.
I have a ZYX-S sitting on the shelf and was wondering, could I use it in a 30cc sized gas airplane?
I am aware that it can be programmed for aircraft, and to use two pads of mounting foam for gas applications.
Whiskey Whiskey is offline Find More Posts by Whiskey Whiskey
Old Jan 25, 2013, 11:01 AM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
If what you want the ZYX to control is covered by it's functions, as you imply, then I believe the only thing of concern might be vibration - and that can be resolved by using different configurations of foam mounting, possibly incorporating a metal plate as a damper. I actually find my CX (virtually identical to ZYX) to be very tolerant of vibration, far more so than other tail gyros I've used.
Discussion New ALZRC 3GYS Flybarless System beenflying Mini Helis 644 Dec 07, 2012 04:44 AM
Found Tarot 450 or like, long flybarless feather shafts TubeBarHeli Aircraft - Electric - Helis (FS/W) 2 Jul 25, 2011 01:13 PM
For Sale New Align 3G Flybarless System V2.1 ptt81 Aircraft - Electric - Helis (FS/W) 1 Jun 06, 2011 04:55 PM
For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system blueindian Aircraft - Electric - Helis (FS/W) 0 May 31, 2011 06:09 PM
Discussion Tarot Flybarless avengedkevinfold Electric Heli Talk 1 May 04, 2011 04:46 AM
