Old Dec 19, 2012, 04:12 PM
sp00fman is offline
Find More Posts by sp00fman
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
I notice somehow it is hard to land softly when the heli is in a slow descend. I was writing it off to servo slop but these reports caught my interest..
Collective servo throw should be the same on the bench as in flight correct?
Perhaps we can plot servo travel and compare it to a beastX controlling that servo. see if it is non-linear at spots in its travel.
Also would setting collective limit to 100 in the Gyro and reduce endpoints in the Tx have any effect?
Will adding negative expo on the collective stick improve it any?
Things like that i might try some day...crappy weather allowing. :/
sp00fman is offline Find More Posts by sp00fman
Old Dec 19, 2012, 05:14 PM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
Interesting experiment - though I suspect it will result in similar response. I'm going to try it.
Not sure which TX's will allow expo on collective - my JR 9XII doesn't.
Crappy weather is a good time for maintenance!
2Doggs is offline Find More Posts by 2Doggs
Old Dec 19, 2012, 08:04 PM
Dowquest is offline
Find More Posts by Dowquest
RCHN #202
Dowquest's Avatar
United States, CA, El Cajon
Joined Nov 2007
pc connection issues
So now I cannot even get the driver/ comm port adapter to work. Any body else get this message? I am running windows 8, in test mode, so I can run any drivers, My IKON software adapter works perfectly.
Dowquest is offline Find More Posts by Dowquest
Old Dec 19, 2012, 09:53 PM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
I would try unplugging and re-plugging the adaptor. If that dosn't fix it, try rebooting. If that doesn't sort it, uninstall and reinstall the adaptor driver.
The "location" shown in the attached image seems to show a virtual port, not sure if that has anything to do with it. Does the Ikon adaptor also use a virtual port - i.e. with a similar address, as opposed to a simple number?
Old Dec 19, 2012, 09:59 PM
ewoodcox is online now
Find More Posts by ewoodcox
Axes & Blades-Cutlery & Helis
West Monroe NY
Joined Feb 2009
Wow, no expo on a JR9X11, all my Spectrum TXs, DX6i, DX7 and DX8s have expo. I doubt I would like flying without expo....
ewoodcox is online now Find More Posts by ewoodcox
Old Dec 19, 2012, 10:27 PM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
There's expo on rudder, elevator and aileron, just not on pitch! The 9XII is a great TX, so easy and quick to program. I picked mine up used, with a 35MHz module, and converted it to 2.4G with an FrSky module and RX, for $35. Mind you, if you really did have a radio without expo, some of the gyros have expo.
Old Dec 20, 2012, 03:02 AM
MikeHRC is offline
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
With the DX7 you can have expo on the collective to give more of an "S" curve - if for e.g. you want to have more or less movement aound mid-stick some have used it for that ...
MikeHRC is offline Find More Posts by MikeHRC
Old Dec 20, 2012, 03:20 AM
bionicbone is offline
Find More Posts by bionicbone
Whoops was it always in 2 bits
bionicbone's Avatar
United Kingdom, England, Rotherham
Joined Oct 2008
DX8 has the same function.
Kev
bionicbone is offline Find More Posts by bionicbone
Old Dec 20, 2012, 04:02 AM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
On the JR, they do have a feature they call "expo" for the pitch curves, but all it does is curve-fit the points on your pitch curve, maybe useful if you have some odd, spiky kind of curve in the first place, and maybe a throwback to nitro helis.
Old Dec 20, 2012, 04:42 AM
MikeHRC is offline
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
DX7 may be similar - never used it. Does the JR have 7 point curves as that could help as well ...
Old Dec 20, 2012, 07:07 AM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
Yes, the JR has 7 point curves, probably why I never bothered with smoothing my curves with the "expo" feature.
Old Dec 20, 2012, 01:47 PM
Dr.M is offline
Find More Posts by Dr.M
Dr.M's Avatar
United States, WA, Issaquah
Joined May 2011
FWIW, I've tried non-linear pitch curves (making them steeper around center) to mitigate this sloppy collective feel. The results were equivocal - the collective still felt sloppy around center, and I had a feeling of complete lack of precision. So I'm back to linear PCs, and just learned to deal with the quirky feel of this particular FBL system.
Dr.M is offline Find More Posts by Dr.M
Old Dec 20, 2012, 01:55 PM
fpainter3 is offline
Find More Posts by fpainter3
fpainter3's Avatar
USA, KY, Florence
Joined Aug 2007
I hope the rain clears up so I can get one last flight in before the end of the world tomorrow.
I herd they dont allow RC Helicopters in Heaven, and they always crash on takeoff in hell.
fpainter3 is offline Find More Posts by fpainter3
Old Dec 20, 2012, 02:09 PM
Paul 1968 is offline
Find More Posts by Paul 1968
Mildly Confused
Paul 1968's Avatar
UK
Joined Oct 2008
This world ending thing has put a real crimp on my weekend, there was just so much I wanted to do.
Paul 1968 is offline Find More Posts by Paul 1968
Old Dec 20, 2012, 02:36 PM
fpainter3's Avatar
USA, KY, Florence
Joined Aug 2007
Since you guys in the UK are on GMT-0 do you get "IT" first? (the winter Solstice)
Discussion New ALZRC 3GYS Flybarless System beenflying Mini Helis 644 Dec 07, 2012 04:44 AM
Found Tarot 450 or like, long flybarless feather shafts TubeBarHeli Aircraft - Electric - Helis (FS/W) 2 Jul 25, 2011 01:13 PM
For Sale New Align 3G Flybarless System V2.1 ptt81 Aircraft - Electric - Helis (FS/W) 1 Jun 06, 2011 04:55 PM
For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system blueindian Aircraft - Electric - Helis (FS/W) 0 May 31, 2011 06:09 PM
Discussion Tarot Flybarless avengedkevinfold Electric Heli Talk 1 May 04, 2011 04:46 AM
