Old Dec 11, 2012, 12:19 AM
bionicbone is offline
Find More Posts by bionicbone
Whoops was it always in 2 bits
bionicbone's Avatar
United Kingdom, England, Rotherham
Joined Oct 2008
Troy / Mike, can we just recap on your version numbers and working configuration? It does seem strange that after huge success with this unit we are seeing reports of control loss.
First, i think you should ensure your fail safe settings are correct, as pointed out above this would then identify any signal issues by cutting the motor, reducing the risk of injury and reducing any damage should you find the ground before regaining control.
What zyx firmware are you running?
What programming software are you using, version number, PC version or mobile? Incidentally on this subject hard you using the Bluetooth connection module?
What method of connection are you using? I.e. standard full rx solution or satellite only?
I'm just wondering if it's more about the settings than the actual heli setup.
Kev
bionicbone is offline Find More Posts by bionicbone
Old Dec 11, 2012, 12:41 AM
gs550t1981 is offline
Find More Posts by gs550t1981
Beginner Pilot
United States, NY, Coram
Joined Jul 2012
Hey mike, you have the same issues as me for sure. I chsnged out the receiver (i'm using a full receiver), the servos, and installed a ground wire. Its a 450. I am using the zyx-s with 3.5 & johns latest software programming it with the laptop. I just installed another rx and opened the hood of the zyx but didnt c n e thing new. Im going to take it out one more time to c what happens. I am flying a 450 pro clone with orange rx and dx6i. Ill let you know if I find anything new. Please do the same. Did you guys make any adjustments right before this happens? Once I adjusted the tail decel and the flught after it did it but that was only once. Thanks for all and any help guys.
Jeff
gs550t1981 is offline Find More Posts by gs550t1981
Old Dec 11, 2012, 06:28 AM
peter24 is offline
Find More Posts by peter24
kings lynn, norfolk uk
Joined Sep 2007
just been out for a proper flight, cant fault how it handles, did some flips and rolls, and backwards loops, it great nice and stable. Ther only issue i had was with a very slow wag no the tail, tried increasing gain on my transmitter from 31% to 40% made it a bit better. prob need to go more but its only 2 degrees c outside, so a bit cold, didnt stay out to long. Piros were a little slow, so will speed those up,
Im still having a little issue with the bluetooth app. i keep getting a file empty error, whats the correct procedure for using it. i originally set the heli up via computer. then i got the bluetooth adaptor, connected it up, then saved the file via app. so when i next connect the app to make changes do i just make changes and resave or do i need to load the file first? dont want to loose all my settings like last time.
peter24 is offline Find More Posts by peter24
Old Dec 11, 2012, 04:55 PM
Troy S is online now
Find More Posts by Troy S
USA, FL, Hudson
Joined Dec 2009
Hi Bionicbone,
I am using both the Tarot Pc software 3.0 and the handheld programmer with the clear case. My Zyx-s software is version 3.50. I did the original setup on the software and then make little changes at the field with the handheld. I think this is the unit I originally tried to setup on the 250 with the orange satellite but couldn't figure it out. I ended up just using an aurora 6 receiver after that. If it wasn't the used one it was new. I didn't have a lot of flights on the 250 but it was a belt tail and never had this issue.
If it get some time tomorrow I will look at setting up the fail safe and I think I have enough spare parts to switch back to a tt tail just to see if it makes a difference.
Troy S is online now Find More Posts by Troy S
Old Dec 11, 2012, 09:19 PM
USA, FL, Hudson
Joined Dec 2009
I didn't have the parts for the torque tube so I have grounded the boom for now. I have also opened the zyx and best I can see everything is ok. I'll know more this weekend when I can get out to the field again.
Old Dec 11, 2012, 11:09 PM
Beginner Pilot
Joined Jul 2012
I got about five flight on my zyx today and all flights were flawless...... I am going to put some more flight on thurs. Will let you know what happens.... thanks
Old Dec 12, 2012, 06:13 AM
War Horse is offline
Find More Posts by War Horse
War Horse's Avatar
United States, FL, Hernando
Joined Sep 2012
Question, I'm building a 450 FBL and scale body, do I need all digital servos with the ZYX or can I go with metal gear analogs on cyclic and a digital for the tail ?
I was thinking of going with the Tower Pro MG90s (cyclic) and a InoLab HGD-261-HB for tail.
War Horse is offline Find More Posts by War Horse
Old Dec 12, 2012, 06:18 AM
ahamay is offline
Find More Posts by ahamay
ahamay's Avatar
Australia, QLD, Gold Coast
Joined Jun 2012
I personally would not risk a scale fuse and heli with mg90's on an fbl setup. If you going to spend on a decent servo for the tail then just get the inolab 202hb's or a set of hitec analog hs65mg's for the cyclic as they are know to work great.
ahamay is offline Find More Posts by ahamay
Old Dec 12, 2012, 06:34 AM
War Horse's Avatar
Joined Sep 2012
Thank you, theres so many choices and I wasnt sure. I'm still a noob at building from the ground up, lots of fun tho.
Old Dec 12, 2012, 09:42 AM
MikeHRC is offline
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
You can use it with cheapo Analogues - but it won't fly as nicely as it would with decent servos - you would have to drop the gains to stop wobbles which will lead to a heli that won't hold as well. You don't need to go mad on high-end servos though - some thing like Savox 0257s are fine
MikeHRC is offline Find More Posts by MikeHRC
Old Dec 12, 2012, 09:45 AM
fpainter3 is offline
Find More Posts by fpainter3
fpainter3's Avatar
USA, KY, Florence
Joined Aug 2007
I have both the more powerful MG90 on my flybarless 450 and they work great. I have the MG90S on another helicopter and they work great too. The Hitech 65 is a much better servo,however.
I have some white Hobbyking digital metal gear servos That look promising, but I dont have them on a helicopter yet.
http://www.hobbyking.com/hobbyking/s...5kg_0_08s.html
fpainter3 is offline Find More Posts by fpainter3
Old Dec 12, 2012, 09:52 AM
grmis is offline
Find More Posts by grmis
grmis's Avatar
France, IDF, 91
Joined May 2011
What about the TGY-306G ?
Hi.
I do not know how they perform in the real life, but from their specs (torque & speed, ball bearing) the Turnigy 306G look almost ideal to me (except perhaps for their weight:21g). They cost ~ 23$ at HK (~18$ with a buddycode). I am considering buying some for the cyclic of my HK450Pro/FBL/ZYX.
grmis is offline Find More Posts by grmis
Old Dec 12, 2012, 09:59 AM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
Originally Posted by grmis View Post
Hi.
Quite a few people are using them with good results. As you mention, the weight is maybe their only downside.
2Doggs is offline Find More Posts by 2Doggs
Old Dec 12, 2012, 10:33 AM
War Horse's Avatar
Joined Sep 2012
Thank you all for the input, I didnt mean to hijack this thread into servos, I just needed to know if the ZYX would work with both digital and analogs together.
I will start a thread for the build I'm trying to get together and list up some items I've found to get opinions, remember too that this is with a scale body.
Old Dec 12, 2012, 04:00 PM
91awdTalon is offline
Find More Posts by 91awdTalon
Wisconsin
Joined Aug 2005
Me and a buddy ordered these for the cyclic on our 450's.
http://epbuddy.com/index.php?main_pa...roducts_id=242
I decided to try the copterx gyro this time, I had really good luck with the cx-1x1000 and figured I'd give their 3 axis a shot.
Will report back with some feedback whenever the rest of my stuff shows up from the slooowww boat. Still waiting on the gyro and a tarot DFC head.
91awdTalon is offline Find More Posts by 91awdTalon
Discussion New ALZRC 3GYS Flybarless System beenflying Mini Helis 644 Dec 07, 2012 04:44 AM
Found Tarot 450 or like, long flybarless feather shafts TubeBarHeli Aircraft - Electric - Helis (FS/W) 2 Jul 25, 2011 01:13 PM
For Sale New Align 3G Flybarless System V2.1 ptt81 Aircraft - Electric - Helis (FS/W) 1 Jun 06, 2011 04:55 PM
For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system blueindian Aircraft - Electric - Helis (FS/W) 0 May 31, 2011 06:09 PM
Discussion Tarot Flybarless avengedkevinfold Electric Heli Talk 1 May 04, 2011 04:46 AM
