Old Dec 07, 2012, 09:19 AM
krisnov is offline
Find More Posts by krisnov
krisnov's Avatar
Indonesia, Jakarta Capital Region
Joined Apr 2012
Originally Posted by peter24 View Post
just a couple of quick questions, looking from the back of the heli, for tail compensate, collective to tail, when i move throttle off of centre the tail slider moves right, is this correct.
same when i move cyclic in the corners, tail slider moves right.
Cheers test flight tommorrow if the wind drops a bit.
Normaly it should move to the left....
Except if you're using bob's tail blade grip mod.
krisnov is offline Find More Posts by krisnov
Old Dec 07, 2012, 09:27 AM
peter24 is offline
Find More Posts by peter24
kings lynn, norfolk uk
Joined Sep 2007
Haven't done the grip flip, better change it so it moves the other way then. Thanks
peter24 is offline Find More Posts by peter24
Old Dec 07, 2012, 01:06 PM
Dr.M is offline
Find More Posts by Dr.M
Dr.M's Avatar
United States, WA, Issaquah
Joined May 2011
Forget the slider, look at the blades, as they control the thrust. As you move collective up from center to max, the leading edge of the tail blades should swing towards the boom.
Dr.M is offline Find More Posts by Dr.M
Old Dec 07, 2012, 02:57 PM
peter24 is offline
Joined Sep 2007
thamk you, also is it necessary to set the tail blades at 8 when the tail servo is at 90, or is it best just to centre them.
Old Dec 07, 2012, 03:05 PM
sp00fman is offline
Find More Posts by sp00fman
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
Try 4 or 5 degrees. 8 is to much imho.
sp00fman is offline Find More Posts by sp00fman
Old Dec 08, 2012, 06:30 AM
peter24 is offline
Joined Sep 2007
Well i got it hovering in the back garden, but then the little garden wall jumped out and grabbed the main blades. New blades on, now going up the field to do it properly like i should have in first place. Will report back later
Old Dec 08, 2012, 08:12 AM
peter24 is offline
Joined Sep 2007
took it to the field, hovers fine in normal mode, everything working the way it should.
Flick to idle up, starts shaking from side to side, so back to normal mode and land, get the bluetooth attached, and try lowering the roll and pitch gains, but some how end up deleting all the setting in the gyro. came home used the pc to lower the gain setting from 35 to 25, i only have analogue servos on the swash at the minute, will be replacing asap.
so back into the garden being carefull not to hit the wall this time! seems i have a very slight backwards drift, so i guess my swash wasnt exactly level,
will do a proper flight test next week at work, do some flips and stuff so i can get it all sorted out, apart from that very pleased so far.
When you set the aileron and elevator limits, are you setting the limit to give you eg 6 on the elevator and aileron, or is it set to get as much throw as you can with out it binding.
Old Dec 08, 2012, 08:47 AM
2Doggs is online now
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
Happy FBL!
Congratulations on your first flights!
Other people with analogue servos have needed to drop the cyclic gain to about 20.
Re the cyclic pitch - there is no 6 degree limit, you can go for as much as you can get without binding, though whilst you're getting used to it, you might tame it down by using D/R in your TX. Most people have about 8 degrees or so of cyclic.
2Doggs is online now Find More Posts by 2Doggs
Old Dec 08, 2012, 09:01 AM
peter24 is offline
Joined Sep 2007
Thanks 2doggs, can't wait to fly it properly. Wasnt sure if i was setting up for max throw with out binding or to a certain amount. I take it the agility setting takes care of the amount of aileron and elevator throw u get. I need to cheapish digital servos now. I have 2 corona 939 servos. So would only need to buy one more. Was also looking at the servos from HK UK but want sure which were half decent.
Old Dec 08, 2012, 11:08 AM
Two helis flying
2Doggs's Avatar
Joined Nov 2009
I've used Corona 929's, and they worked pretty well. I think the 939's are a bit slower, with more torque. In fact if you happen to have another, different digital servo, you could use it on elevator - I flew my #2 450 with Henge 922's on aileron and a Corona 929 on elevator, and it was fine - the controller compensates for speed differences.
Old Dec 08, 2012, 01:10 PM
blevesque is offline
Find More Posts by blevesque
blevesque's Avatar
United States, GA, Cleveland
Joined Jan 2011
Thank you guys for all the help. My 500 is flying like it's on rails. One quick question.
My gyro gain setting is 100 in the software and 66% in the tx. So if i set the gyro switch to change the condition i would have to set the gyro gain in the software to 66. Is this right?
blevesque is offline Find More Posts by blevesque
Old Dec 08, 2012, 02:56 PM
Two helis flying
2Doggs's Avatar
Joined Nov 2009
Not necessarily! Go into the monitor screen in the software, with your controller hooked up, and see what your TX setting of 66% translates to in the gyro. If you have a Futaba style TX, if memory serves, anything above 50% is HH mode, and below 50% is rate mode. So 66% might actually translate to 32%, which is just a little lower than the 35% or so you commonly use in the ZYX.
But in principle - yes, you will need to set the gain in the software for the two conditions.
Old Dec 09, 2012, 10:01 AM
bionicbone is online now
Find More Posts by bionicbone
Whoops was it always in 2 bits
bionicbone's Avatar
United Kingdom, England, Rotherham
Joined Oct 2008
Bluetooth Adapter in UK
Hi just to let you guys know that it looks like fastlads in the UK have started stocking the Bluetooth adapter now.
http://www.fast-lad.co.uk/store/taro...2-p-21694.html
Kev
bionicbone is online now Find More Posts by bionicbone
Old Dec 09, 2012, 11:11 AM
blevesque's Avatar
Joined Jan 2011
Ok thanks 2dogs. Will try it when it stops raing.
Old Dec 09, 2012, 11:37 AM
peter24 is offline
Joined Sep 2007
Kev
Yeah i saw this the other day. Currently out of stock at the mo. Was gonna get one, but a very nice person on here said they had a spare i could have.
I emailed fastlads they said they should have some before xmas.
Discussion New ALZRC 3GYS Flybarless System beenflying Mini Helis 644 Dec 07, 2012 04:44 AM
Found Tarot 450 or like, long flybarless feather shafts TubeBarHeli Aircraft - Electric - Helis (FS/W) 2 Jul 25, 2011 01:13 PM
For Sale New Align 3G Flybarless System V2.1 ptt81 Aircraft - Electric - Helis (FS/W) 1 Jun 06, 2011 04:55 PM
For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system blueindian Aircraft - Electric - Helis (FS/W) 0 May 31, 2011 06:09 PM
Discussion Tarot Flybarless avengedkevinfold Electric Heli Talk 1 May 04, 2011 04:46 AM
