kings lynn, norfolk uk
Joined Sep 2007
http://pages.ebay.com/link/?nav=item...d=271062162602 does anyone know if this will work to do the programming via Bluetooth. Tar
Edit: Heh, yeah what Busher said
Cool! Thanks for reporting back, and a big thanks to Zr_Flyer for working it out.
![]() FYI, I now have the method for changing the pin code and name of the eBay BT modules. When I get time, I'll see if they can be reprogrammed to work with the Android app. |
Latest blog entry: RC Parts Suppliers - The Good and the...
Does the US Tarot guy have it? If not, Infinity Hobby if you want fast reliable service, or oomodel if you want it a little cheaper (but double check including shipping).
Canada, ON, Muskoka
Joined Jul 2011
Got mine from here..... http://www.hobby-wing.com/zyx12.html
I know , I have no clue what I'm doing. I got really comfortable using program box, just not able to use sat only with my ZYX-s. Is there any other gyro that I can just plug the sat in and have it work? |
Using 7Zip, extract the firmware. For the ZYX-s, the file is ZYX-S-3.50.bin. Open the FBL software, and connect your controller, which will either need to be powered up by a suitable RX battery or BEC, or just power up the heli with the TX in throttle hold, and maybe a couple of motor leads disconnected if you like. Same as you would when using the program box. The screenshot below shows the John_NZ software V1.21, but the Tarot software is similar. I'm still using windows XP, but it's similar in later versions. At the bottom right of the screen, under "Firmware Upgrade" click on the "Open" button. This will open another window where you need to navigate to the firmware file. In the list shown, you need to click on the ZYX-S 3.50 folder When you click on the folder, you should see the ZYX-S-3.50.bin file, and you should click on that to highlight it and click the "Open" button. You should then see the filename appear in the box at the bottom right of the FBL software screen as shown below Then click on the "Upgrade" button. you should then see the following window In my case, I was just doing a dummy run without the controller connected, but you should see the progress bar fill up and then you will get a message telling you the firmware upgrade is complete. Hope that helps! |
| Thread Tools | |
| Discussion New ALZRC 3GYS Flybarless System | beenflying | Mini Helis | 644 | Dec 07, 2012 04:44 AM |
| Found Tarot 450 or like, long flybarless feather shafts | TubeBarHeli | Aircraft - Electric - Helis (FS/W) | 2 | Jul 25, 2011 01:13 PM |
| For Sale New Align 3G Flybarless System V2.1 | ptt81 | Aircraft - Electric - Helis (FS/W) | 1 | Jun 06, 2011 04:55 PM |
| For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system | blueindian | Aircraft - Electric - Helis (FS/W) | 0 | May 31, 2011 06:09 PM |
| Discussion Tarot Flybarless | avengedkevinfold | Electric Heli Talk | 1 | May 04, 2011 04:46 AM |
