Old Nov 25, 2012, 01:41 PM
sp00fman is offline
Find More Posts by sp00fman
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
Bad luck but preventable.
When converting to FBL I learned to just hit TH ~20cm above the ground, still in idle-up. As soon as it touches the ground quickly but smoothly feed in full negative-collective. It just makes it stick to the ground and spool down a lot faster. After that flip to normal mode for safety before approaching the heli. (dont want a chickendance if i ever bump throttlehold by accident)
sp00fman is offline Find More Posts by sp00fman
Old Nov 25, 2012, 01:42 PM
Busher is offline
Find More Posts by Busher
Joined Apr 2011
Originally Posted by peter24 View Post
My zyx should be here tomorrow. At last.. Just wondering what i can expect from going flybarless . Longer flight times? Etc?
More tuneable head settings, more wind tolerance, and longer flight times are all available to exploit.
Busher is offline Find More Posts by Busher
Old Nov 25, 2012, 01:52 PM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
You might just see slightly longer flight times, but for me the biggest improvement was in penetration - I was able to do bigger loops, for example, and the heli can fly a bit faster. Depending on how you set up the controller, the heli can be super stable or as twitchy as you want. Many people might say that a heli flies "a bit bigger" on FBL. I find the mechanical simplicity really appealing.
2Doggs is offline Find More Posts by 2Doggs
Old Nov 25, 2012, 02:26 PM
blevesque is offline
Find More Posts by blevesque
blevesque's Avatar
United States, GA, Cleveland
Joined Jan 2011
Thanks for the tip spoofman. I will try again when I get the parts.
just so i'm clear on this. It will try to eat the ground every time I land if I dont auto.
blevesque is offline Find More Posts by blevesque
Old Nov 25, 2012, 03:10 PM
Dr.M is offline
Find More Posts by Dr.M
Dr.M's Avatar
United States, WA, Issaquah
Joined May 2011
Ground rollovers are more likely with FBL than FB, but still rare actually. I've had it happen once or twice, then learned to leave the cyclic stick alone on the ground, and apply some negative pitch as soon as the skids touch down.
Dr.M is offline Find More Posts by Dr.M
Old Nov 25, 2012, 04:40 PM
blevesque's Avatar
Joined Jan 2011
Thank Dr. M ... I am surprised that my fethering and main shaft are not bent. :-)
Old Nov 25, 2012, 05:19 PM
gs550t1981 is offline
Find More Posts by gs550t1981
Beginner Pilot
United States, NY, Coram
Joined Jul 2012
Ikon on the way.... had enough of the zyx... hopefully this one will work out better....
gs550t1981 is offline Find More Posts by gs550t1981
Old Nov 25, 2012, 06:50 PM
piledrive is offline
Find More Posts by piledrive
United States, LA, Rayne
Joined Apr 2012
i got my trex 500 up and flying again after the crash from the elevator servo malfunction but there are two problems first when tried first flight the tail servo was reversed in the zyx program so i fixed that 2nd i have wobbles when the heli hovers if i pump the pitch it goes away but returns when i try to bring the heli down
piledrive is offline Find More Posts by piledrive
Old Nov 25, 2012, 09:56 PM
91awdTalon is offline
Find More Posts by 91awdTalon
Wisconsin
Joined Aug 2005
Just finished my 500 after my crash. Wish me luck, I'm heading out to test it as soon as my battery is finished charging!
91awdTalon is offline Find More Posts by 91awdTalon
Old Nov 25, 2012, 10:05 PM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
Drop the cyclic gains from their default value of 40. Or just live with the momentary shakes when coming to the hover.
Old Nov 25, 2012, 10:09 PM
eagle777 is offline
Find More Posts by eagle777
Closed Account
Joined Aug 2007
I'm replacing my 450 EXI FB head (my only fb head left) with the 10 dollar HK FBL head. I was thinking of putting the (spare) fifth ZYX-S on a quad, but I don't care for quads or tricopters for some reason. Just sharing that it is never ending; you can make up a reason for a new project. I'll use this heli for low inverted FRF I guess.
eagle777 is offline Find More Posts by eagle777
Old Nov 25, 2012, 10:14 PM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
That's a shame, the $15 HK RJX head is not much more but really good....
Old Nov 25, 2012, 10:18 PM
Dr.M is offline
Dr.M's Avatar
Joined May 2011
The Ikon/Brain is much more beginner-friendly than the ZYX, but it can still pose a challenge to get the tail set up perfectly. I'm still working on mine...
Old Nov 25, 2012, 10:20 PM
Wisconsin
Joined Aug 2005
A big thanks to everyone who has contributed to this thread and for the advice/suggestions earlier when I asked questions. My "re-maiden" went extremely well!
I will say I ditched the TT tail and switched over to belt driven and this thing was just singing! The blades gargling the night air was awesome! Now I'll move the gains up a bit and hopefully have a polished setup!!
Thanks again everyone!
Old Nov 25, 2012, 10:26 PM
eagle777 is offline
Closed Account
Joined Aug 2007
I have another new RJX head, but want to save it as a spare for the 6S 450 RJX. I have too many helis. I don't see any downsides to the HK $10 head yet. I bought it some time ago to on impulse. I also have a couple more CopterX FBL heads that aren't being used
Discussion New ALZRC 3GYS Flybarless System beenflying Mini Helis 644 Dec 07, 2012 04:44 AM
Found Tarot 450 or like, long flybarless feather shafts TubeBarHeli Aircraft - Electric - Helis (FS/W) 2 Jul 25, 2011 01:13 PM
For Sale New Align 3G Flybarless System V2.1 ptt81 Aircraft - Electric - Helis (FS/W) 1 Jun 06, 2011 04:55 PM
For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system blueindian Aircraft - Electric - Helis (FS/W) 0 May 31, 2011 06:09 PM
Discussion Tarot Flybarless avengedkevinfold Electric Heli Talk 1 May 04, 2011 04:46 AM
