Nottinghamshire, UK
Joined Dec 2009
It's a shame we can't get some feedback from Tarot on this... S
http://www.rcgroups.com/forums/showp...postcount=5301 Your second paragraph about pitch up in FFF must have been in responce too another post. For those who have a difficult time following my D/R FBL question may I suggest you take your Tx and set D/R at say 30% and observe the servo travel speeds at 100% and at 30% using the same Expo. setting . I am not refering to the Expo softening uip around center I am refering to the servo's speed when stick is at the extremes and switched for 100% and 30% Travel not Expo. Charles |
Oxfordshire, UK
Joined Jan 2007
I had been slightly sceptical about the notorious 3.5 issue - until I managed to re-create it earlier
. I flashed with the 3.5 software when it first came out and had not had any problems at all. I popped out earlier to fly a few batteries and managed to re-create it on my 3rd battery.It is windy here today - a constant strong wind (probably 15mph) with sudden gusts up to about 25mph - the little 450 was doing a sterling job in handling it - bobbing up and down a lot and a bit of nose-up into the wind, but fine, I was coming out of big loops into the wind no problem. To get the problem I was running very fast into the wind, heli angled nose-down about 30 degrees, lots of throttle (so already a fight between pitch and collective) and 3 times when I got a very heavy gust she went into a very suddenly upwards trajectory (with a distinct bogging sound) - it was as if there was a fight between the heli fighting to keep it's nose down (due to the angle of the cyclic) and then the suddenly gust of wind got under the front of the disk and flipped it up. I had to work hard to get it to happen and I can't say that it wouldn't have happened with the previous firmware - I think that I created the "perfect storm" for it to happen (high speed run into wind, sudden gust flipping the nose up). I will carry on using the 3.5 firmware as the other benefits that it gave are well worth having IMHO, and I will just avoid creating the perfect storm (it's not how I usually fly) - just doing big loops and flips plus circuits was fine. By the way - Tarot 450 Pro, with Savox 0257 servos (same as DS410M) and non-FBL blades |
Nottinghamshire, UK
Joined Dec 2009
Cyclic - Ino-Lab HGD-202HB Tail - Ino-Lab HGD-201HB You would not be disappointed with how well they perform with the zyx! Log in for the best prices (about $18 each). S
Nottinghamshire, UK
Joined Dec 2009
![]() What a great first take off and hover. Looks beautifully stable ![]() Sorry to see the landing with complications at the end ![]() S
NYC
Joined Aug 2010
Nottinghamshire, UK
Joined Dec 2009
![]() Ripe conditions for the FFF issue. I'm confident it would not have happened with firmware v1.01 & 2.5, but I agree that there are improvements in v3.5 that counterbalance the negatives. S
I'm still using the 3.02 version. Should I upgrade to the 3.50? I'm still learning to fly at faster speeds and working into loops. Didn't know if there would be any noticeable advantages in stability or tail hold. It currently flies fine as it is.
By the way Simon, thank you very much for your ZYX setup video's. They were a tremendous help for me with my first 450 build and first time having to program a gyro. You made it very easy to follow and understand. Excellent work! Off topic.....How close is Nottinghamshire to Lakenheath AB? I lived over there across the pond in a little town called Brandon for 3 years while I was in the USAF. Had a great time over there and wish I still had my 1968 Mini Clubman. Had to take the front seat out to drive it since I'm 6'5" tall and got all kinds of funny looks! |
| Thread Tools | |
| Discussion New ALZRC 3GYS Flybarless System | beenflying | Mini Helis | 644 | Dec 07, 2012 04:44 AM |
| Found Tarot 450 or like, long flybarless feather shafts | TubeBarHeli | Aircraft - Electric - Helis (FS/W) | 2 | Jul 25, 2011 01:13 PM |
| For Sale New Align 3G Flybarless System V2.1 | ptt81 | Aircraft - Electric - Helis (FS/W) | 1 | Jun 06, 2011 04:55 PM |
| For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system | blueindian | Aircraft - Electric - Helis (FS/W) | 0 | May 31, 2011 06:09 PM |
| Discussion Tarot Flybarless | avengedkevinfold | Electric Heli Talk | 1 | May 04, 2011 04:46 AM |
