Old Oct 01, 2012, 09:42 AM
sgbfly is offline
Find More Posts by sgbfly
Nottinghamshire, UK
Joined Dec 2009
Originally Posted by Busher View Post
In respect to the nose pitch up in FFF, I have just read on another forum a similar problem, where the ZYX equipped heli would become very pitch sensitive in FFF, however in a different situation, the two could be very well associated but may be a route to an answer.
His problem only occured in FFF but he did not report that the heli did the command itself. He reported that condition made the heli super sensitive to a pitch input i.e a small input made a large change of movement to the heli, So my question is are you by any chance putting small pressure on the elevator stick without realising it? Or have you got a dicky pot on the TX that puts in a slight elevator response around the centre. These are just suggestions by the way as I can tell you are pretty meticulous in your build and test procedures and would not want to upset you in any way.
I'm not upset in the slightest - it's a good point. The helicopter can be most easily pushed over the edge when transitioning from nose-down FFF to level flight. Then the dis-symmetry of lift (dol) causes the heli to nose-up abruptly. So, yes, in this case the slightest touch on the ele is involved to level the helicopter and the sudden nose-up then happens. However, it can also do this all by itself in FFF if a gust of wind is involved giving the same result. The gyro has no answer to this in FW 3.5 whereas earlier versions do (I have test flown the same helicopter back to back with different firmware versions and only v3.5 has the FFF problem).
S
sgbfly is offline Find More Posts by sgbfly
Old Oct 01, 2012, 11:28 AM
fpainter3 is offline
Find More Posts by fpainter3
fpainter3's Avatar
USA, KY, Florence
Joined Aug 2007
I will just fly slowly until V3.6 or so comes out .
fpainter3 is offline Find More Posts by fpainter3
Old Oct 01, 2012, 12:44 PM
Busher is online now
Find More Posts by Busher
Joined Apr 2011
S
No probs I realised that it was 3.5 based but did not know it was exclusive to 3.5, we will have to hope that tarot come out with an upgrade soon.
Busher is online now Find More Posts by Busher
Old Oct 01, 2012, 01:59 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
FBL and Transmitter Duel Rates
While going back and doing a proper complete setup of the Tarot ZYX-S and my DX7 I made an observation which was news to me.
The servos will move the same amount (full set travel range ) if the Tx is set to 100% or with D/R set as low as 30% . The difference is that with very low D/R settings the servos move in slow motion.
I have read cautions about not using Expo. with some FBL units . Something about causing Expo. on top of Expo. This to me sounds like some FBL units either have Expo. or perhaps the poster was refering the FBL gains to being same as Expo..
Any FBL experts care to clear this up for me.
I do now that with Tx. Ail. and Elev. settings of 100% and 40% Expo. and
D/R 75% and 40% Expo that the D/R settings feel softer. I assumed it was due to reduced Servo throw but now it would seem it ( D/R) slows servo travel down.
Edit:
Went back a ways a found this post by 2Doggs on D/R
http://www.rcgroups.com/forums/showp...postcount=5253
I agree lowered D/R makes it feel softer but has anyone in fact checked to see if they infact reduce total servo travel or merely slow the servos responce down?
Charles
Old Oct 01, 2012, 04:08 PM
2Doggs is offline
Find More Posts by 2Doggs
Ask Mike
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
Using D/R on your cyclic will definitely soften the feel of the heli. On the bench, you won't see smaller cyclic deflection with reduced D/R - but you may notice the swash move more slowly. The servo limits remain the same in the FBL controller, but with D/R enabled, it is seeing a demand for a lower rate of change. That is in contrast to the way D/R would work with servos hooked up directly to the RX, where you simply see reduced servo travel.
Even if the controller has some built-in expo, you can use expo in your TX to get the feel you prefer around neutral.
It's very easy to check all of this out in reality. For example, you could set up your stunt 1 and 2 modes with exactly the same pitch and throttle curves, but add lower D/R in one mode, and then repeat the exercise setting higher expo in that mode.
You would typically have D/R less than 100% in normal mode, and maybe use more expo in that mode too.
2Doggs is offline Find More Posts by 2Doggs
Old Oct 01, 2012, 04:22 PM
Southern Pride
Thanks for clearing that up for me. I knew that is what I was seeing on the bench.
Also knew that responce was much softer with D/R at 75% even though I had the same Expo set for both 100 % and 75%.
Learning the ends and outs of a FBL unit has been an interesting journey and this past week i feel I have learned a great deal but still have only scratched the surface.
Charles
Old Oct 01, 2012, 04:44 PM
KTMDirtFace is offline
Find More Posts by KTMDirtFace
Joined Aug 2012
Thanks for all the help! Sgbfly your videos were very helpful.
My heli flew like a champ on my first attempt, un-fortunately was I so shakey and nervous I freaked out and botched a landing. ( wasn't smart to try to land where I was also ). Oh well its all fixed up in about 10minutes just waiting on some new landing skids.
Edit: Oh on dual rates, I turned mine down to 70% for my first 450 flight and hated it. felt really laggy? felt like I had to move the sticks a lot was freaking me out how much I was moving them.
Tarot 450 PRO V2 FBL (4 min 0 sec)
KTMDirtFace is offline Find More Posts by KTMDirtFace
Old Oct 01, 2012, 04:53 PM
MikeHRC is online now
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
The "expo on expo" comment is based upon dire warnings from Stefan from Beastx, he has said that their FBL unit has expo built into most of the different models (all except Transmitter) and if you add expo in the tranmitter settings you can end up with very strange behaviours when you get "expo on expo" and the movements can be very strange.
This is not the case for the ZYX where Tarot recommend using expo
MikeHRC is online now Find More Posts by MikeHRC
Old Oct 01, 2012, 06:22 PM
Sebi97 is offline
Find More Posts by Sebi97
Joined Sep 2012
Can I plug this directly into a orange Satellite from Hobbyking? Thats what the product description says, so i would think ot would work... Thanks!
Sebi97 is offline Find More Posts by Sebi97
Old Oct 01, 2012, 08:01 PM
Southern Pride
see post here
http://www.rcgroups.com/forums/showp...postcount=5239
Old Oct 01, 2012, 11:42 PM
choopi is online now
Find More Posts by choopi
choopi's Avatar
New Brunswick
Joined Feb 2006
From 2:40. you can see at 3 occasions the pitch up uncontrolled. FFF into strong wing. Definitely something wrong with v3.5
Tarot ZYX-S ver.3.5 (4 min 26 sec)
choopi is online now Find More Posts by choopi
Old Oct 02, 2012, 12:13 AM
Joined Aug 2012
Choopie that violent climb up is not from you? its doing it on its own? dang..
Old Oct 02, 2012, 12:23 AM
eagle777 is offline
Find More Posts by eagle777
Closed Account
Joined Aug 2007
Never really had anything like that happen with two 450 & two 500s all with ZYX, ZYX-S and 3.50. I have seen 450s get twitchy in elevator at very high speeds, say at the top speed of a 450 after a dive with lots of collective, but nothing like the video. It's more of an overcorrection on my part I think.
eagle777 is offline Find More Posts by eagle777
Old Oct 02, 2012, 01:35 AM
PHMX is offline
Find More Posts by PHMX
Never trust laughing dolphins
Joined Feb 2011
Edit:
Charles
It won't cause servos to slow down for sure, just less max throws when using D/R. The bench testing without spinning the head is not a good test for all of this. Expo might make the initial response a bit slower before movement really kicks in but with fbl we can use as much agility as possible, something best achieved through 100% throws and proper mechanical setup.
The pitching up issue could easily have to do with a jump in pitch creating too much torque to handle. But it still sounds like something that should be fixable. Not sure about v3.5 though, so far I've not felt the need to update. And the FFF issue is not something I'd want (not saying there's no issue).
PHMX is offline Find More Posts by PHMX
Old Oct 02, 2012, 03:18 AM
BonBonU is offline
Find More Posts by BonBonU
Joined Aug 2011
firmware version
just got used zyx-s gyro /w usb cable from club member. I want to know how to find out what firmware being used.
load John's software and tarot 3.0 software but still cannot figure out.
BonBonU is offline Find More Posts by BonBonU
Discussion New ALZRC 3GYS Flybarless System beenflying Mini Helis 644 Dec 07, 2012 05:44 AM
Found Tarot 450 or like, long flybarless feather shafts TubeBarHeli Aircraft - Electric - Helis (FS/W) 2 Jul 25, 2011 02:13 PM
For Sale New Align 3G Flybarless System V2.1 ptt81 Aircraft - Electric - Helis (FS/W) 1 Jun 06, 2011 05:55 PM
For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system blueindian Aircraft - Electric - Helis (FS/W) 0 May 31, 2011 07:09 PM
Discussion Tarot Flybarless avengedkevinfold Electric Heli Talk 1 May 04, 2011 05:46 AM
