Old Sep 29, 2012, 05:38 AM
nascar1929 is offline
Find More Posts by nascar1929
Head in the clouds
nascar1929's Avatar
United States, NC, Gastonia
Joined Jan 2012
Anyone know where I can get a main gear case and one-way bearing spacer for my Tarot 450 Pro V2? I can't find them anywhere.
nascar1929 is offline Find More Posts by nascar1929
Old Sep 29, 2012, 06:01 AM
KTMDirtFace is offline
Find More Posts by KTMDirtFace
Joined Aug 2012
Does it have to be tarot brand?
Amain hobbies has them for the Align which should work I would think.
KTMDirtFace is offline Find More Posts by KTMDirtFace
Old Sep 29, 2012, 07:06 AM
lcc014 is offline
Find More Posts by lcc014
AMA Member # 458448
lcc014's Avatar
United States, MA, ALLSTON
Joined May 2011
Yes, they are compatible with each others.
lcc014 is offline Find More Posts by lcc014
Old Sep 29, 2012, 07:12 AM
Arey is offline
Find More Posts by Arey
Arey's Avatar
Philippines, NCR, Taguig
Joined Aug 2011
One-way Bearing Shaft Collar (Ring)
It's available at Infinity Hobby, link here.
EDIT: Missed the main gear case.
Arey is offline Find More Posts by Arey
Old Sep 29, 2012, 01:19 PM
Head in the clouds
nascar1929's Avatar
Joined Jan 2012
Thanks for the help. I had a tough time searching those 2 parts for some reason. Sure would be nice if the one way bearing collar would come with the main gear case as a set.
Old Sep 29, 2012, 01:49 PM
2Doggs is online now
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
The one way bearing cover is one of the pieces I always swap out for an Align part in my clones. I seem to get a better fit onto the (Align) mainshaft that way, and in governor mode, the clone mainshaft covers wear out pretty quickly too.
2Doggs is online now Find More Posts by 2Doggs
Old Sep 30, 2012, 12:57 AM
Joined Aug 2012
I was looking for these as backups and found the entire assembly with gears on ebay... I never ordered one ( china ) They were align brand when I looked
Old Sep 30, 2012, 06:06 AM
Busher is offline
Find More Posts by Busher
Joined Apr 2011
Originally Posted by sgbfly View Post
A quick update on the FFF nose-up problem
I've not had much chance to fly due to bad weather but today it relented.
I'm trying high cyclic gains. 70 overall and 80-100-30 PID. I completed a backflip, roll and some simple circuits with no issues. Onto FFF into the wind and this was interesting. At the point where the helicopter may well have previously done it's magic abrupt nose-up trick a mild shake set in. This was not the wet dog shakes across the aileron axis but very similar across the elevator axis. It was not hard to control and the heli was returned safely to ground.
I'm going to try lowering the overall gain to 60 and see what happens. If that is a bust then I'll raise the gains and experiment with reducing the D-gain.
Simon
Edit: Scratch all that - it's a bust. The shakes and pitch-up can occur one without the other or both at the same time in vFFF into the wind. Video later
In respect to the nose pitch up in FFF, I have just read on another forum a similar problem, where the ZYX equipped heli would become very pitch sensitive in FFF, however in a different situation, the two could be very well associated but may be a route to an answer.
His problem only occured in FFF but he did not report that the heli did the command itself. He reported that condition made the heli super sensitive to a pitch input i.e a small input made a large change of movement to the heli, So my question is are you by any chance putting small pressure on the elevator stick without realising it? Or have you got a dicky pot on the TX that puts in a slight elevator response around the centre. These are just suggestions by the way as I can tell you are pretty meticulous in your build and test procedures and would not want to upset you in any way.
Busher is offline Find More Posts by Busher
Old Sep 30, 2012, 06:27 AM
ahamay is offline
Find More Posts by ahamay
ahamay's Avatar
Australia, QLD, Gold Coast
Joined Jun 2012
Given the same heli with previous firmware does not have the issue I can't see how any of your suggestions might apply in this case.
I have 2 tarot 450 pro v2's with zyx and same cyclic servos... one with 3.5 and one with the previous version. 3.5 heli has the problem the other one does not, flying them back to back with the same settings.
Jonesy
ahamay is offline Find More Posts by ahamay
Old Sep 30, 2012, 08:44 AM
Two helis flying
2Doggs's Avatar
Joined Nov 2009
Mechanical?
My HK450 Pro was flying great, with no pitch up in FFF. (with a CX3x1000, original firmware) After a crash and rebuild, however, it started to pitch up. That really spoiled the feel of the heli, making stall turns with hard pull-outs much trickier. After the next crash, I installed new servos (Align DS410's) and the pitch up was gone.
So I believe there are also mechanical factors involved.
Old Sep 30, 2012, 09:00 AM
Busher is offline
Joined Apr 2011
Jonesy
Just a suggestion, I am pretty pleased with mine it flies ok and doesn't pitch up, so it may be worth looking for other paths but anyway hope you get yours sorted either by changing the firmware or by other means.
Old Sep 30, 2012, 03:07 PM
ricoalonso is offline
Find More Posts by ricoalonso
ricoalonso's Avatar
USA, KS, Derby
Joined Mar 2003
What's the rule of thumb regarding cyclic gains? Are these normally set lower for bigger birds compared to smaller ones; or, is it the opposite? Just wondering if there is any difference.
I have one setup in my 450-size and doing well. Now, I am setting up one for my 640-size.
Any input will be appreciated.
ricoalonso is offline Find More Posts by ricoalonso
Old Sep 30, 2012, 03:25 PM
PHMX is offline
Find More Posts by PHMX
Never trust laughing dolphins
Joined Feb 2011
There's definitely a little bit more to it as bigger birds also involve much higher torque which generally require a higher mechanical gain actually, but with headspeeds that are generally much lower on the bigger birds, you should get away with somewhat higher gyro gains. Ideally the gyro values really should still be in the same ballpark though.
And regardless, all this still doesn't mean you should dial in something high straight away. :-)
As a true rule of thumb, always start low and increase the gains from there. The bigger the bird, the less you should want to risk any kind of too high gain related issues. A lot also depends on what type or brand of gyro we're talking about.
PHMX is offline Find More Posts by PHMX
Old Sep 30, 2012, 04:18 PM
ricoalonso's Avatar
USA, KS, Derby
Joined Mar 2003
I am refering to the ZYX-S gyro. My tail is good except for the swash which seems to be a little slippery feel than it is in my 450.
Thanks for the input. I'll try so increase the PID settings little at time. Yes I would imagine that a gyro gain related shake will be riskier in bigger birds.
Old Sep 30, 2012, 05:08 PM
lordsirob is offline
Find More Posts by lordsirob
lordsirob's Avatar
United States, FL, North Palm Beach
Joined Jul 2004
My value hobby B grade Tarot is finished. Unfortunately, I could not get the Futaba S-Bus working, so I am using a HK Frsky non S-Bus FASST compatible receiver. It would have been a sweet setup with only the S-Bus cable between the receiver and fbl unit instead of the mass of wires going everywhere .
The ZYX-S is set up with the beginner defaults. I only hovered to see how it did. It did not crash so I think the beginning of this journey is off to a good start. Now I need to tidy up the wiring and I guess I need to read up on PIDs...
lordsirob is offline Find More Posts by lordsirob
Discussion New ALZRC 3GYS Flybarless System beenflying Mini Helis 644 Dec 07, 2012 04:44 AM
Found Tarot 450 or like, long flybarless feather shafts TubeBarHeli Aircraft - Electric - Helis (FS/W) 2 Jul 25, 2011 01:13 PM
For Sale New Align 3G Flybarless System V2.1 ptt81 Aircraft - Electric - Helis (FS/W) 1 Jun 06, 2011 04:55 PM
For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system blueindian Aircraft - Electric - Helis (FS/W) 0 May 31, 2011 06:09 PM
Discussion Tarot Flybarless avengedkevinfold Electric Heli Talk 1 May 04, 2011 04:46 AM
