Has anyone seen the HK-732MG mini tail servo?
![]() http://www.hobbyking.com/hobbyking/s...dProduct=23220 ![]() ![]() I've been doing some research and it appears to be the new Henge MD732 rebadged. Henge has put a lot of effort into this servo. Here are the specifications: Quote:
This servo looks like it has great potential for the tail of the 450 Pro and 500 series of helis. I've even seen it selling for $35 as a Tarot tail servo, however HK only wants $15 for it. I have one coming to review, so I'll report back on what I think of it. Henge MD732 on eBay: http://cgi.ebay.com/ws/eBayISAPI.dll...m=150834240043 I also found this video of it being used with the ZYX:
I had a great run with the Henge 922 and 933. My 922's on cyclic did over a 150 flights before one of the servo's developed a jitter. I never had a problem with the cases, even though I had several crashes.
I'm keeping an open mind. HK don't make the servos and as stated, Henge have tried to make it a good servo, by using quality parts. |
Latest blog entry: RC Parts Suppliers - The Good and the...
Indonesia, Jakarta Capital Region
Joined Apr 2012
the gyro is always assume everything is 0 every time it initialize... no matter where your trims position are... as for gyro gain you dont need to have the same exact value as the manual and you dont need to set 1 in rate mode and 1 in hh mode, as usualy we dont fly in rate mode except if you fly scale... you can set both in hh mode as high gain and low gain value... the recomended value is just for your starting point, you will need to adjust it later... it's very dependent to your heli setup... Quote:
![]() i had a few blown out too when upgraded to 3.5, never had it with 2.5 fw... my tail got blown away even on slow inverted cw backward huricane... few days a go i rebulid the tail and didnt see anything wrong... so i tried the blade grip flip mod, thinking maybe the tail did not have enough pitch to counter the torque and add a few points on the gain... now the tail held prety good, havent got any blown out... but still, i dont fly as fast as yours...
Joined Aug 2012
zyx.s s.bus problem
Hello, help is needed
I've for a while now been trying to set up zyx.s with frsky TFR8 SB using the s.bus. But there is a problem when I'm testing in the software all the channels (exept for gain) are mixed, elevator is aileron, aileron is rudder and so on. When I seting up the conventional way withouth using the s.bus all the channels comes out ok. At the software receiver setup page it says: "Enter the 'FUNKTION' menu of your transmitter, define the sequense of the channels as below: 1 Rudder J4 T4 2 Aileron J1 T1 3 Elevator J2 T2 4 Pitch J3 -- 5 Gyro -- -- 6 Throttle J3 -- As I now there is no way to change the channels in the transmitter. l have a futaba 10c. Thanks, |
| Thread Tools | |
| Discussion New ALZRC 3GYS Flybarless System | beenflying | Mini Helis | 644 | Dec 07, 2012 04:44 AM |
| Found Tarot 450 or like, long flybarless feather shafts | TubeBarHeli | Aircraft - Electric - Helis (FS/W) | 2 | Jul 25, 2011 01:13 PM |
| For Sale New Align 3G Flybarless System V2.1 | ptt81 | Aircraft - Electric - Helis (FS/W) | 1 | Jun 06, 2011 04:55 PM |
| For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system | blueindian | Aircraft - Electric - Helis (FS/W) | 0 | May 31, 2011 06:09 PM |
| Discussion Tarot Flybarless | avengedkevinfold | Electric Heli Talk | 1 | May 04, 2011 04:46 AM |
