Old Aug 24, 2012, 05:19 AM
eriskio's Avatar
Joined Mar 2010
Originally Posted by Dr.M View Post
@eriskio
FW 3.5 seems to heat up my tail servos too. I traced the problem to vibes. As soon as I fixed the tail bearings and rebalanced the whole thing, tail servo stays much cooler.
Uhm, interesting. I'll re-check it. Tnx for the clue.
eriskio is offline Find More Posts by eriskio
Old Aug 24, 2012, 05:46 AM
Head in the clouds
nascar1929's Avatar
United States, NC, Gastonia
Joined Jan 2012
I am in the process of programming my ZYX-S and have a few questions if anyone can help. I am following along with Simons video and using the same numbers he used for his Tail gain.
On the first screen (Monitor) of the setup, step 3, adjust signals to be 0 using sub-trim when sticks centered. I noticed that when Simon does this, his Tail gain numbers are 0 in Rate mode and 41 in HH mode. I can't seem to get mine adjusted to get the same numbers. How do I do that?
My Gyro Sensor settings in my Devo TX are: position 0 (HH mode) = 70% / position 1 (Rate Mode) = 30%
On step 5 under Monitor, I was able to get 36 HH mode and -36 Rate mode using Travel adjust. Is that the correct way to do that?
I only made it to the (Servo Trim) tab and saved before making any further adjustments.
I may be jumping ahead but noticed when I move my throttle stick up, the swash moves down and when I moved the stick down, the swash goes up. This seems backwards to me. I went back and checked the first setup tab (Monitor) and checked the direction the Collective Pitch slider moved when I move the throttle stick. When I move the stick up, the slider goes up. When I move the stick down, the slider goes down. Is there something wrong here or will that fix itself as I continue to program the gyro?
Can anyone help me out with this?
nascar1929 is offline Find More Posts by nascar1929
Old Aug 24, 2012, 07:01 AM
Joined Mar 2006
How do you tell what FW your unit has?
Zoobie is offline Find More Posts by Zoobie
Old Aug 24, 2012, 08:49 AM
mmracecars's Avatar
United States, MI, Harrison Township
Joined Jan 2012
Zyx-s
if there all moving corectly,but just backwards,when you get to the total pitch screen,move the slider negative and the swash will change direction.
mmracecars is offline Find More Posts by mmracecars
Old Aug 24, 2012, 01:52 PM
Head in the clouds
nascar1929's Avatar
Joined Jan 2012
I'll give that a try. Thank you.
Old Aug 24, 2012, 08:35 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Thanks again, for all the kind words.
I replaced the plastic bottom on the ZYX today (the one that had the silcone rubber all at one end), with the metal bottom. Just an FYI the weight of the unit goes from 10.5g to 15.5g. Possibly it will handle vibrations better, especially on the bigger helis.
beenflying is offline Find More Posts by beenflying
Old Aug 24, 2012, 08:48 PM
AMA Member # 458448
lcc014's Avatar
United States, MA, ALLSTON
Joined May 2011
I replaced the bottom plate with metal from day 1 in my zyx. So far so good....
Ching-Ho Cheng
lcc014 is offline Find More Posts by lcc014
Old Aug 24, 2012, 08:55 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Ching-Ho Cheng
Was your plastic bottom like my one above, or was the silcone rubber flat in the bottom?
Old Aug 24, 2012, 08:56 PM
AMA Member # 458448
lcc014's Avatar
Joined May 2011
Mine did not have that much of silicon rubber as yours. It did has some around 4 corners.
Ching-Ho Cheng
Old Aug 25, 2012, 02:16 AM
Head in the clouds
nascar1929's Avatar
Joined Jan 2012
Finally done building my 450 and setting up the ZYX-S. Gonna spool it up with no blades in the morning and check everything over. If all looks good, it should be in the air for her maiden in the afternoon!!!
Old Aug 25, 2012, 05:44 AM
DerClown's Avatar
Lithuania
Joined Mar 2009
I'm planing to build HK500 as spare heli, and what decent servo you can recommend to use with ZYX as tail servo ?
Thanx a lot !
DerClown is offline Find More Posts by DerClown
Old Aug 25, 2012, 06:19 AM
AMA Member # 458448
lcc014's Avatar
Joined May 2011
Thanx a lot !
The best would be MKS DS95i, fairly expensive. The cheap alternative would be KST DS115MG or DS125MG servo.
Ching-Ho Cheng
Old Aug 25, 2012, 07:46 AM
DerClown's Avatar
Lithuania
Joined Mar 2009
Ching-Ho Cheng
I'm wondering, could be this Turnigy servo rebranded KST DS115MG ?
http://www.hobbyking.com/hobbyking/s...06sec_21g.html
Specs, case excepts sticker everything looks the same.
Old Aug 25, 2012, 08:19 AM
AMA Member # 458448
lcc014's Avatar
Joined May 2011
I have no idea either, everyone just copy each others. Similarly, Apple and Samsung, both of them should be fined to copy each others idea/design .... USA becomes a law suit country, everyone suit each others for $$$$$, sigh.
Ching-Ho Cheng
Old Aug 25, 2012, 10:55 AM
Paycheck flyer
mhills51's Avatar
kansas city
Joined Feb 2007
It's funny how in all the other country's these two have been suing each other apple always looses, but in a California US court apple wins. I wonder were they found 12 people in California that didn't have a ipod product?
mhills51 is offline Find More Posts by mhills51
Latest blog entry: Logo build
Discussion New ALZRC 3GYS Flybarless System beenflying Mini Helis 644 Dec 07, 2012 04:44 AM
Found Tarot 450 or like, long flybarless feather shafts TubeBarHeli Aircraft - Electric - Helis (FS/W) 2 Jul 25, 2011 01:13 PM
For Sale New Align 3G Flybarless System V2.1 ptt81 Aircraft - Electric - Helis (FS/W) 1 Jun 06, 2011 04:55 PM
For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system blueindian Aircraft - Electric - Helis (FS/W) 0 May 31, 2011 06:09 PM
Discussion Tarot Flybarless avengedkevinfold Electric Heli Talk 1 May 04, 2011 04:46 AM
