Old Aug 21, 2012, 04:31 PM
Dr.M is offline
Find More Posts by Dr.M
Dr.M's Avatar
United States, WA, Issaquah
Joined May 2011
Originally Posted by f.a.r.m.e.r View Post
Are you guys running a seperate BEC with your 450 size helis? Or running the bec off the esc?
If your ESC has a 3+Amp BEC, there's really no need (or space) for an external BEC in a 450.
Dr.M is offline Find More Posts by Dr.M
Old Aug 21, 2012, 04:57 PM
Jwmflying14 is offline
Find More Posts by Jwmflying14
United States, CA, Lompoc
Joined Nov 2010
Plenty of space. And I prefer 6v output. By the way, nice digi servos can easily pull 3 amps. 4 hs5085mg servos pull more than I would trust with a 3a BEC
Jwmflying14 is offline Find More Posts by Jwmflying14
Old Aug 21, 2012, 05:25 PM
f.a.r.m.e.r is offline
Find More Posts by f.a.r.m.e.r
Farmer
f.a.r.m.e.r's Avatar
United States, CA, San Mateo
Joined Oct 2011
I'm running savox digital servos, and savox tail servo, I was told they are power hungry thats why I asked about the bec lol..
f.a.r.m.e.r is offline Find More Posts by f.a.r.m.e.r
Old Aug 21, 2012, 05:39 PM
Farmer
Joined Oct 2011
Originally Posted by nascar1929 View Post
This is my first build. I bought a Tarot 450 Pro (belt drive) barebone kit http://www.oomodel.com/tarot-450-pro...e-p-60744.html and have been piecing it together for the last 3 months. I finally got my batteries today and was able to power everything up and finish putting it together only to have that servo go bad. Bummer!
This is what I installed in it:
Tarot 450FL FBL rotor head
Tarot ZYX-S gyro
Tarot 3800kv motor w/ 14T pinion gear
KST DS115MG tail servo
Solar D654 cyclic servo's
Hobbywing Flyfun 40A ESC
Walkera RX802 receiver
Walkera Devo 8S transmitter
The kit came with wooden blades so I'll use those for now and get some CF's later.
Looks alot different than the picture on the web site. I have changed a few things on it. Here are some older pics from a month or so ago.
Attachment 5098881 Attachment 5098883 Attachment 5098888 Attachment 5098895
Cool canopy love green, I to am building a tarot
Tarot 450 pro v2 fbl
Ice 50 ESC
Scorpion 2221-2010 v2 motor
13T pinion
Gensace 1300mAh 6S lipo
Savox SH-0257MG cyclic
Savox SH-1357 tail
ZYX-S
Its my first mini heli been flying micros for a little while now lol
Old Aug 21, 2012, 05:45 PM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
Hey farmer hows the walkera flying? Mine is put away till winter.
mhills51 is offline Find More Posts by mhills51
Old Aug 21, 2012, 05:46 PM
mmracecars is offline
Find More Posts by mmracecars
mmracecars's Avatar
United States, MI, Harrison Township
Joined Jan 2012
fbl
as a beginner,im using the begginer settings on the zyx-s.id like to tame this 500 down a little if poss.any suggestions on what to change.
mmracecars is offline Find More Posts by mmracecars
Old Aug 21, 2012, 06:30 PM
nascar1929 is offline
Find More Posts by nascar1929
Head in the clouds
nascar1929's Avatar
United States, NC, Gastonia
Joined Jan 2012
Ice 50 ESC
13T pinion
Savox SH-1357 tail
ZYX-S
Sounds like a nice setup! Post some pics when you can. Would like to see it.
nascar1929 is offline Find More Posts by nascar1929
Old Aug 21, 2012, 06:51 PM
Joined Nov 2010
Guys I ALMOST have this thing working. However my pitch is on my throttle stick and collective is some how on my elevator?!?!
Everythign Is wired correctly after just double checking.
I am also having trouble setting endpoints with my JR x9503
Farmer
Joined Oct 2011
my gcp is collecting dust for now, been flying my brushless blade mcpx v2 alot lately, just getting into mini's now..
here is my mcpx v2 with CO5M
Blade mCPx V2 Twin Tail NanoTech 300 (1 min 32 sec)
and the other with hp05s..
mCPx Brushless v2 Rewound HP05s With Twin Tail (1 min 35 sec)
one these days I'll pop my gcp out again lol
its going to be fun flying this new 450 I'm building is much bigger then my others and i will able to see the thing lol
what helis you flying now?
Old Aug 21, 2012, 06:56 PM
Farmer
Joined Oct 2011
Hey thanks 0k will take some pic's of it.. will be doing a maiden soon all i'm waiting for is a satellite reciever
Old Aug 21, 2012, 07:00 PM
Joined Nov 2010
Also, I forgot to add that My ZYX-s has a solid red light. I thought solid red was for heading hold mode? Currently it is acting as a 3 axis gyro and corrects for all levels of input.
It also corrects in the right direction, yet for some reason my TX is switch, elevator controlling collective and collective is controlling pitch?!
Edit. So much for that...
Can you only plug this thing in one time before having to restart the heli? I was messing around on johns setup, got everything level, but still my channels were swapped. Then I unplugged it to test some things, plugged it back in and it just sits there. Now it doesnt receive any signal and is acting like it wont bind to my TX. When it turns on the Gyro just sits there with all three lights on, no input from anything at all...
Edit #2. Now I Tried binding without anything hooked up (besides ESC and bind plug) and the rx wont bind.... I think the RX fried... Hopefully Gyro is still okay, but I wont know until I get a new rx.
Now, Any ideas about the swapped channels? Other than them being swapped everything is good to go! its almost like mode 1 programming.... on a Mode 2 tx. so weird!
Old Aug 21, 2012, 08:47 PM
Dr.M is offline
Dr.M's Avatar
Joined May 2011
reverse the elevator servo (servo 3) in the pc software.
Old Aug 21, 2012, 09:07 PM
ahamay is offline
Find More Posts by ahamay
ahamay's Avatar
Australia, QLD, Gold Coast
Joined Jun 2012
Ice 50 ESC
13T pinion
Savox SH-1357 tail
ZYX-S
Does that ICE 50 ESC fit inside the frame up the front with the stock battery tray ?
ahamay is offline Find More Posts by ahamay
Old Aug 21, 2012, 09:16 PM
Joined Nov 2010
Sounds good!
as mentioned I am now waiting on a new RX but will try it asap when I get one in hand. Until then, If that reverses the elevator servo then will my Collective be all messed up like it was eariler? servos going every which way? If so then do I go reverse it in my tx?
Old Aug 21, 2012, 10:56 PM
Farmer
Joined Oct 2011
my ice 50 lite does fit..
Discussion New ALZRC 3GYS Flybarless System beenflying Mini Helis 644 Dec 07, 2012 04:44 AM
Found Tarot 450 or like, long flybarless feather shafts TubeBarHeli Aircraft - Electric - Helis (FS/W) 2 Jul 25, 2011 01:13 PM
For Sale New Align 3G Flybarless System V2.1 ptt81 Aircraft - Electric - Helis (FS/W) 1 Jun 06, 2011 04:55 PM
For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system blueindian Aircraft - Electric - Helis (FS/W) 0 May 31, 2011 06:09 PM
Discussion Tarot Flybarless avengedkevinfold Electric Heli Talk 1 May 04, 2011 04:46 AM
