BTW, the box says "Flybarless for 200 to 700 helicopters". |
Latest blog entry: RC Parts Suppliers - The Good and the...
Just finished 4 more ~6 minute flights. Tail gain is now at 32. It's just so much fun to fly. I can't find any strange cyclic effects like you get with the 3GX, just smooth flying. The only thing I notice is a small tail twitch when you're in the hover and you put in a very small amount of tail input.
I should also have mentioned that I'm using the suggested 40% expo on cyclic and 30% on the tail. People learning would be better off using less or no expo and a much lower dual rate setting, say 60% to start. |
Tokyo
Joined Sep 2009
Hi beenflying,
I have checked work of GYRO by the bench test in the following setup. Combined Orange RX 6ch and TARO ZYX 3 AXIS GYRO for HK250. TX is DX6i. Swashplate type:1servo NORM Reverse:AILE-R, ELEV-R, PITC-R The system menu: 1 flash direction gyro--- Direction 1* 2 flashes Parameter group selection--- Yellow ,2 flashes: 3Dmode 3 flashes Dervo type--- Yellow ,3 flashes: all 1520us digital. 4 flashes Swashplate type--- Yellow ,2 flashes: 120 degree CCPM* 5 flashes Pirouete optmization--- Blue ,1 flash: negative* setup menu: All Factory default setting. (Probably it seems that these setup can be performed by TX.) However, although it is a setup of Direction 1, the manual is differed from, and if the LEDs panel side is not mounted as the undersurface, GYRO compensation of ELEV does not work correctly You are also the same mount...Thanks, |
United States, MD
Joined Jan 2010
Hi beenflying,
Thank you for the great info on the ZYX! I have been hoping for an inexpensive 3-axis unit ever since I got my BeastX last year. I just ordered the a ZYX with the 250 head, can't wait to try in on my rigid 4 blade 450 pro. I was about to order another beastX, but seems like a waste for a scale body. After I figure it out, will probably get another for the 250. It is flying pretty well right now. BTW, I have given up on the GA250 for now. Great to see all these new mems units coming along. Thanks again. Terry |
Make sure Pirouette optimization is correct. When you spin the helicopter the tilted swash plate should appear to stay still (point to the same place in the room). Don't be fooled by this option timing out and reverting back to level. |
Yes it's great that these new low cost 3-axis gyros are working so well. They will help people to learn quicker and cost them less when they crash. All the best David |
United States, CA, Glendale
Joined Jan 2009
Just ordered mine up.....If its as good as Im reading its hard to beat 118 shipped to the door for a 3 axis gyro, metal tail control holders fine tune adjustable pitch linkages, fancy red frame washer and a couple other pointless items.....Super stoked to get my chaos 600 fbl in the air...
Since you already have the programmer, until this one has a programming box, I'd stick with the 3GYS.
He's some shoots of my 250 after just flying it's 10th flight with the ZYX. Backwards, sliding flips, inverted, rolls, sweet!
I was going to change the pinion to a 16T but I'm not going to bother now, as the extra power from going FBL has given it the extra power I wanted. |
| Thread Tools | |
| Discussion New ALZRC 3GYS Flybarless System | beenflying | Mini Helis | 644 | Dec 07, 2012 04:44 AM |
| Found Tarot 450 or like, long flybarless feather shafts | TubeBarHeli | Aircraft - Electric - Helis (FS/W) | 2 | Jul 25, 2011 01:13 PM |
| For Sale New Align 3G Flybarless System V2.1 | ptt81 | Aircraft - Electric - Helis (FS/W) | 1 | Jun 06, 2011 04:55 PM |
| For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system | blueindian | Aircraft - Electric - Helis (FS/W) | 0 | May 31, 2011 06:09 PM |
| Discussion Tarot Flybarless | avengedkevinfold | Electric Heli Talk | 1 | May 04, 2011 04:46 AM |
