Old Jul 09, 2012, 08:46 PM
asolof is offline
Find More Posts by asolof
United States, NJ, Vineland
Joined Aug 2011
RedOctobyr,
Thanks for responding. When I said I checked it on the ground, I did exactly what you described. I did it again tonight to triple check it and I even compared the tail movements to another flybarred, single axis gyro 450 that I have which flys well. All movements, both stick and gyro compensation are in the correct directions. The only difference I observed in the tail movements of the 2 helicopters was that the flybarred/single axis gyro helicopter made a full rapid compensation to piveting the tail, compared to a partial compensation with the Tarot gyro equipped flybarless helicopter.
But there is something drastically wrong with it because it is totally unflyable. I can't even get it to lift off the ground without it toppling over.
Originally Posted by RedOctobyr View Post
How are you checking the compensation directions on the ground? It's not just checking that the swashplate moves in the correction direction when you move the sticks, of course.
Hold the heli in your hand, the swashplate should be parallel to the floor. Now quickly tilt it forward, the swashplate should tilt backwards, and remain parallel to the floor. It will then gradually bring itself back to "neutral", if you keep the heli tilted forward.
Hold the heli upright again, and quickly tilt it to the right, the swashplate should tilt left, and stay parallel to the floor.
Also double-check your tail correction direction. Put it in Heading Hold, and move the tail to one side. The tail pitch should change in the correct direction. Personally, I rotate the tail so that the tail blades are out straight, and vertical. If you swing the tail to the right, the upper tail blade's leading edge (which faces off the back of the heli) should tilt towards where the tail was originally located, trying to bring the tail back in that direction. Swing the tail off to the left, and the pitch should change in the other direction, but still have the leading edge pointing towards the original tail location, trying to bring itself back there.
asolof is offline Find More Posts by asolof
Old Jul 09, 2012, 08:47 PM
Dr.M is offline
Find More Posts by Dr.M
Dr.M's Avatar
United States, WA, Issaquah
Joined May 2011
I just noticed... Congrats on your promotion, bf!
Dr.M is offline Find More Posts by Dr.M
Old Jul 09, 2012, 09:28 PM
Daddy. is offline
Find More Posts by Daddy.
Everyone is an idiot (or I am)
Daddy.'s Avatar
United States, TX, Red Oak
Joined Jun 2012
Originally Posted by dr.m View Post
i just noticed... Congrats on your promotion, bf!
+ 1
Daddy. is offline Find More Posts by Daddy.
Old Jul 09, 2012, 10:18 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Thanks, guys. I was really thrilled to be nominated by pitchp and to be accepted by RCG's admin. It made my day when I logged in this morning and saw that I was now a plus member.
Hopefully a lot more will be given the same status, when the system kicks off fully in the future, because there are many more here that deserve it.
beenflying is offline Find More Posts by beenflying
Old Jul 10, 2012, 12:18 AM
Arey is offline
Find More Posts by Arey
Arey's Avatar
Philippines, NCR, Taguig
Joined Aug 2011
As colorful as it is, who would not notice . I'm happy for you too David Congrats!
Arey is offline Find More Posts by Arey
Old Jul 10, 2012, 01:10 AM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Thanks, Arey. Hehe, gold and carbon fiber, they call it. I was expecting a little box, like the bronze, silver and gold subscriptions.
Old Jul 10, 2012, 06:13 AM
noddyflyer is offline
Find More Posts by noddyflyer
United Kingdom, England, Gillingham
Joined Feb 2010
sat problem
hi folks finally found the solution to the sat binding i have tried for ages to get the zyx-s to work with a dsm2 sat (no luck) then i got a second hand AR6210 DSMX rx/sat and everything now works (i wonder how many people have had results with dsm2 sats. does the zyx only work with dsmx....mick b/f nice to see some recognition of your hard work
noddyflyer is offline Find More Posts by noddyflyer
Old Jul 10, 2012, 06:50 AM
ChopperJack is offline
Find More Posts by ChopperJack
Moving Parts
ChopperJack's Avatar
United States, AR, Texarkana
Joined May 2011
I'm using AR6210 with sat and all works great so far!
ChopperJack is offline Find More Posts by ChopperJack
Old Jul 10, 2012, 07:14 AM
Joined Feb 2010
im just using the sat in a 250pro,the ar6210 will go in the 450devil pro with the zyx...mick
Old Jul 10, 2012, 07:51 AM
lcc014 is offline
Find More Posts by lcc014
AMA Member # 458448
lcc014's Avatar
United States, MA, ALLSTON
Joined May 2011
Originally Posted by daddy. View Post
+ 1
+ 1
lcc014 is offline Find More Posts by lcc014
Old Jul 10, 2012, 10:30 PM
keris is offline
Find More Posts by keris
keris's Avatar
Malaysia, Perak, Taiping
Joined Jan 2012
Cool BF......perfact choice for PLUS
cheers
keris is offline Find More Posts by keris
Old Jul 10, 2012, 11:12 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Thank you! It's very kind of you all to say.
Old Jul 10, 2012, 11:19 PM
MicroJago is offline
Find More Posts by MicroJago
Wausau, WI
Joined Mar 2009
I have ordered a ZYX-S from hobby king. How can I tell what software/firmware it has? What is the latest to upgrade to or should I keep it stock?
MicroJago is offline Find More Posts by MicroJago
Old Jul 10, 2012, 11:33 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
The ZYX-S from Hobbyking should have v3.02, which is the lastest, but it's very easy and safe to flash it with the supplied PC USB link, anyway. The firmware and other software links are here:
http://www.rcgroups.com/forums/showthread.php?t=1568592
Old Jul 10, 2012, 11:56 PM
fretman is offline
Find More Posts by fretman
fretman's Avatar
United States, CA, Lake Forest
Joined Dec 2007
I think I may have defective unit from HK
Hope I"m doing something wrong and won't have to deal with HK return/exchange.
I purchased a Tarot ZYX-S from HK and received it a couple of days ago. But the unit seems to be defective. I do have experience with other FBL controllers(BeastX, CX-3X1000, GU365) and am familiar with setting them up.
I am using the ZYX-S on a Align Trex 250. It is on firmware 3.02 as shown on the ZYX3.0 software.
Align 410 digital Cyclic servos
Futaba 9257 digital tail servo
RCM-BL250 motor
RCE-BL15X ESC( programmed for 5v )
Spektrum DSM2 satellite. ZYX-S is programmed for DSM2-1
First short test hover went ok, cyclics gains were too high at default 40. Reduced to 30 and hovered much better but tail was not acting quite right. Brought it in to re-set the tail end point and look over the tail. While testing on the bench noticed some abnormal behavior.
1. When it initializes sometimes it takes a very long time, like over a minute. When it finally finishes, I have to power it off and start again as it does not initialize correctly.
2. When it starts correctly, the rudder servo jitters around erratically. In HH mode sometimes its ok, but most of the time it jitters. Rate mode is unusable as it does not stop jittering. While this is happening the cyclics are ok.
3. Sometimes when the rudder servo jitters/shakes by it self, the light on the ZYX-S flashes randomly.
** Cyclic servos are connected to ch1, ch2 and ch3
tail servo is connected to ch4
Spektrum satellite is connected to Rud
ESC is connected AIL
All the servos, ESC and motor all check out fine when connected straight to another Spek RX I have on hand.
Do you think I drew the short straw and got a defect or can you tell if I did something wrong from the above info?
TIA
ps - Although my ZYX-S was on firmware 3.02 out of the box, I tried reflashing it with 3.02 downloaded from these boards here... didn't seem to change anything.
fretman is offline Find More Posts by fretman
Discussion New ALZRC 3GYS Flybarless System beenflying Mini Helis 644 Dec 07, 2012 04:44 AM
Found Tarot 450 or like, long flybarless feather shafts TubeBarHeli Aircraft - Electric - Helis (FS/W) 2 Jul 25, 2011 01:13 PM
For Sale New Align 3G Flybarless System V2.1 ptt81 Aircraft - Electric - Helis (FS/W) 1 Jun 06, 2011 04:55 PM
For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system blueindian Aircraft - Electric - Helis (FS/W) 0 May 31, 2011 06:09 PM
Discussion Tarot Flybarless avengedkevinfold Electric Heli Talk 1 May 04, 2011 04:46 AM
