Old Dec 14, 2011, 05:24 AM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Originally Posted by MikeHRC View Post
OK - I was having problems getting to download the file, then I had a (rare) brainwave ... I was in Firefox and getting an error message, now using Internet Exporer it has downloaded fine.
Just need to get the cable now ... do you know where to buy one ?
Thanks again for your help
Thanks Mike. That was the solution. I haven't seen a programmer yet. An ebay seller or oomodel will probably be the first to have it.
Interesting to see the default parameters are different to the ones in the gyro. The collective has D gain in all modes except beginner and F3C, and the tail has varying D gain for all modes.
Also interesting to see it's version 2.0 but there is no gyro upgrade in the file.
beenflying is offline Find More Posts by beenflying
Old Dec 14, 2011, 05:26 AM
unochen is offline
Find More Posts by unochen
Joined Sep 2005
I think it is the damo software.
After they prepared maybe one or two week you could buy cable from internet.
unochen is offline Find More Posts by unochen
Old Dec 14, 2011, 05:30 AM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
The setup section looks very good also.
Old Dec 14, 2011, 05:45 AM
MikeHRC is offline
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Yeah - I like the look of the software. Three major advantages for me ...
1. The ability to upgrade the firmware - I also have a couple of Beastx's and they current V3 software is much better than the original V1, hopefully we will see similar improvements in the Tarot software.
2. Using the software (and prog box admitedly) we don't need to count flashes etc. and it will be much easier to keep a record of settings.
3. There is the option to Open, Save and Transmit a config file. I am hoping that this will allow us to keep numerous versions of config files to quickly try changes and go back to a known good set-up if it does not improve things.
MikeHRC is offline Find More Posts by MikeHRC
Old Dec 14, 2011, 06:25 AM
unochen is offline
Joined Sep 2005
Me too
Old Dec 14, 2011, 08:36 AM
bobbyshafter is offline
Find More Posts by bobbyshafter
bobbyshafter's Avatar
Joined Sep 2008
Very nice ,you can now tweak the system instead of using predefine settings.
That will improve the performance .
bobbyshafter is offline Find More Posts by bobbyshafter
Old Dec 14, 2011, 08:44 AM
lcc014 is offline
Find More Posts by lcc014
AMA Member # 458448
lcc014's Avatar
United States, MA, ALLSTON
Joined May 2011
I used Firefox to download the software without any problem.
Ching-Ho Cheng
lcc014 is offline Find More Posts by lcc014
Old Dec 14, 2011, 08:51 AM
barnstorm100 is offline
Find More Posts by barnstorm100
barnstorm100's Avatar
United States, CA, Rancho Cordova
Joined Jan 2011
Originally Posted by beenflying View Post
The Tarot 450 FBL head uses the 450 Pro feathering shaft.
Thanks beenflying, I think I have some of those in my spares box.
barnstorm100 is offline Find More Posts by barnstorm100
Old Dec 14, 2011, 10:19 AM
Joined Sep 2008
DL with firefox NP ,have it running on my desktop
Old Dec 14, 2011, 12:53 PM
sp00fman is offline
Find More Posts by sp00fman
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
In the advanced menu, what does the 0 pitch option do?
sp00fman is offline Find More Posts by sp00fman
Old Dec 14, 2011, 05:20 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Vbar has it also. Something to do with tail torque compensation at 0 pitch. It's not recommended to be anything other than 0 for stunt/3D flying.
Old Dec 14, 2011, 10:00 PM
stwolf is offline
Find More Posts by stwolf
stwolf's Avatar
Midlothian, Texas
Disconnected feel?
My maiden hovers were successful but I have this disconnected feeling with the helicopter. When I move the cyclic it seems like a half second or so before the heli responds. Not enough to cause me to crash but enough lag I'm concerned about trying forward flight.
Has anyone had to increase the gain on aileron and elevator?
Any other ideas?
stwolf is offline Find More Posts by stwolf
Old Dec 15, 2011, 01:58 AM
MikeHRC is offline
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Any other ideas?
How much expo do you have ? Too much expo can cause these types of pr0oblem
Old Dec 15, 2011, 06:12 AM
Joined Sep 2008
If you are setup in F3 mode try 3d ,try reducing the expo first as suggested .
The software interface will allow us to adjust agility and other tweaks
Old Dec 15, 2011, 07:29 AM
stwolf is offline
stwolf's Avatar
Midlothian, Texas
Thanks for the replies.
I chose 3D mode during the initial setup per the recommendations here and in the HF thread. Also set 40% expo as a starting point.
I backed expo off to 30% then 25%. Stick sensitivity increased, as you would expect, but it had no effect on the time lag sensation.
I'll try and figure out how to increase E and A gain and report back. I think his is where a programming box would come in handy....
Discussion New ALZRC 3GYS Flybarless System beenflying Mini Helis 644 Dec 07, 2012 04:44 AM
Found Tarot 450 or like, long flybarless feather shafts TubeBarHeli Aircraft - Electric - Helis (FS/W) 2 Jul 25, 2011 01:13 PM
For Sale New Align 3G Flybarless System V2.1 ptt81 Aircraft - Electric - Helis (FS/W) 1 Jun 06, 2011 04:55 PM
For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system blueindian Aircraft - Electric - Helis (FS/W) 0 May 31, 2011 06:09 PM
Discussion Tarot Flybarless avengedkevinfold Electric Heli Talk 1 May 04, 2011 04:46 AM
