Old Dec 09, 2011, 01:37 PM
bobbyshafter is offline
Find More Posts by bobbyshafter
bobbyshafter's Avatar
Joined Sep 2008
Originally Posted by ZeroPitch View Post
Just shot some raw footage for a Tarot/HobbyKing ZYX setup video... does anyone care about the mechanical setup? Or just the programming part? The mechanical part needs to be cut down quite a bit, which will take a while...
Both are important
bobbyshafter is offline Find More Posts by bobbyshafter
Old Dec 09, 2011, 04:13 PM
Grawyl is offline
Find More Posts by Grawyl
United States, IL, Plainfield
Joined Dec 2010
Show us what you got...
Grawyl is offline Find More Posts by Grawyl
Old Dec 09, 2011, 06:49 PM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
Didn't mean to offend, but I thought there was a difference between toyish and toy. lighten up people!
mhills51 is offline Find More Posts by mhills51
Old Dec 09, 2011, 07:06 PM
ZeroPitch is offline
Find More Posts by ZeroPitch
What goes up, must come down..
ZeroPitch's Avatar
United States, CA, Mission Viejo
Joined Sep 2011
Originally Posted by bobbyshafter View Post
Both are important
Cool. I'm uploading the setup & programming vid right now, but at 40 mins (yikes!) and 5.35G HD1080, it won't be finished uploading until some time tomorrow morning... about 975 minutes to go, lol...
This weekend I'll cut down the FBL head installation video (gotta use different software to get some time-lapse, and it needs serious editing). Will try to post it up within a couple of days, if there's enough good footage to make it worth while...
Stay tuned
ZeroPitch is offline Find More Posts by ZeroPitch
Old Dec 09, 2011, 07:11 PM
barnstorm100 is offline
Find More Posts by barnstorm100
barnstorm100's Avatar
United States, CA, Rancho Cordova
Joined Jan 2011
Just installed the Tarot head/gyro on my Mini Titan. Havn't flown it yet but pretty sure it will work.
http://youtu.be/0ebgeonQ0mQ
Sorry, I forgot to turn down the TV
barnstorm100 is offline Find More Posts by barnstorm100
Old Dec 09, 2011, 07:30 PM
ZeroPitch's Avatar
Joined Sep 2011
Lookin' really good!
How much pitch & cyclic throw did you give? Remember, the cyclic limits setting is bugged and will give you more throw during actual operation... best to double check for binding outside of programming mode. That worked to my advantage on the B400... meant to set 8 degrees, but I bet I'm running 10 degrees cyclic which is why it's such a monster in flips ;-) Also, make sure to set 40% expo... you'll thank me later, lol.
Old Dec 09, 2011, 07:54 PM
Joined Jan 2011
Pitch and cyclic throw are default but thanks, I'll be sure and check that before I fly it. Looks like +10 -10
Old Dec 10, 2011, 08:35 AM
ZeroPitch's Avatar
Joined Sep 2011
Alright, here's my setup video for the Tarot ZYX 3-Axis Gyro.
Covers transmitter settings, swashplate adjustment, and gyro
programming using the Tx.
It's my first instructional video, so go easy on me ;-)
Gimme a "thumbs up" on YouTube if you like 'em...
Tarot ZYX 3-Axis Gyro Setup & Programming (40 min 1 sec)
And, here's a vid (shot BEFORE the one above) of dialing in the
gyro gain setting + maiden flight of that HK250GT after converting
it to flybarless.
Since this was shot earlier, the instructional video includes lessons
learned ;-) Noteably, I hit the Wag 'o Death a few times because
gain was too high from my previous gyro (65.5% IIRC); if you set
the ZYX to 3D mode, I highly recommend starting a 250 at 57%
(14% actual), my final value, which seems to be holding the tail
very well.
After this maiden flight, upped the head speed a bit...
and it's much, much snappier!
I think I like it!
HK250 GT FBL with Tarot ZYX - Maiden Flight (11 min 3 sec)
Finally, maiden (take two) of my Blade 400, also sporting the Tarot ZYX.
Completely transformed this bird!
She was wagging at gyro gain of 60%, but at 58.5% (17% actual), the
tail holds rock solid.
Blade 400 FBL with Tarot ZYX - Maiden (Take Two) (7 min 38 sec)
Old Dec 10, 2011, 10:59 AM
Grawyl is offline
Joined Dec 2010
Nice work Zeropitch!
If you want more collective or cyclic pitch, try moving the ball in one hole on the blade grips.
I noticed you have them in the last hole. Tis gives you good mechanical advantage but requires more servo travel. Moving it in one or two holes, will increase the amount of force required to change the pitch but will give you more throw and prevent your servo horn from hitting the main gear.
Grant
Old Dec 10, 2011, 12:12 PM
ZeroPitch's Avatar
Joined Sep 2011
Grant
Thanks for the complement
And nice tip... figured that moving those in one hole on the blade grip would increase throw, but not sure I'll need it just yet... after bumping my headspeed up by going from 85% to 90% governed, she really came alive!
Old Dec 11, 2011, 12:44 PM
unochen is offline
Find More Posts by unochen
Joined Sep 2005
My friend installed the Tarot gyro on 700.
王喬聖ChiaoSheng Wang ZYX三軸裝700首航 (3 min 47 sec)
unochen is offline Find More Posts by unochen
Old Dec 11, 2011, 04:38 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Alright, here's my setup video for the Tarot ZYX 3-Axis Gyro. It's my first instructional video, so go easy on me ;-)
And, here's a vid of gyro gain setting + maiden flight of that HK250GT after converting it to flybarless.
Thanks, ZeroPitch. This will be a big help to a lot of people.
I've added a link to your post in the first post.
beenflying is offline Find More Posts by beenflying
Old Dec 11, 2011, 04:42 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Thanks. That's impressive!
Old Dec 11, 2011, 05:33 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
I've updated the first post. Thanks to everyone that has contributed to this thread.
Old Dec 11, 2011, 06:10 PM
ZeroPitch's Avatar
Joined Sep 2011
Anyone know how to delete a post?
Discussion New ALZRC 3GYS Flybarless System beenflying Mini Helis 644 Dec 07, 2012 04:44 AM
Found Tarot 450 or like, long flybarless feather shafts TubeBarHeli Aircraft - Electric - Helis (FS/W) 2 Jul 25, 2011 01:13 PM
For Sale New Align 3G Flybarless System V2.1 ptt81 Aircraft - Electric - Helis (FS/W) 1 Jun 06, 2011 04:55 PM
For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system blueindian Aircraft - Electric - Helis (FS/W) 0 May 31, 2011 06:09 PM
Discussion Tarot Flybarless avengedkevinfold Electric Heli Talk 1 May 04, 2011 04:46 AM
