Old May 22, 2012, 06:31 PM
ricoalonso is offline
Find More Posts by ricoalonso
ricoalonso's Avatar
USA, KS, Derby
Joined Mar 2003
Originally Posted by lcc014 View Post
Great information. Also, when I spool up my heli, it has the similar "shake" as yours. I definitely will try out this method instead of getting a mini camera.
Ching-Ho Cheng
definitely, you need to find the cause of the 'shake' and try to minimize it. I know I never took the time to check if my head is balanced. In fact, I know there is a slight play between the main shaft and the main bearing and it woobles a little. I'm still working on it, replacing parts a piece at a time. For the meantime, I see it as a good test as to how tolerant the ZYX to vibrations and it is passing so far .
ricoalonso is offline Find More Posts by ricoalonso
Old May 22, 2012, 08:15 PM
lcc014 is online now
Find More Posts by lcc014
AMA Member # 458448
lcc014's Avatar
United States, MA, ALLSTON
Joined May 2011
My heli "shake" during spool up was not as much as yours. Once it get to mi-stick, no more shaking. Both of the main blades and head were balanced. I balanced main blades first - dynamic and the head + blades balance - static. I am using 250 Pro main shaft to get rid of the collar. No play at all - same as using collar. I loaded the new pitch and roll gain of 45 to ZYX. Swashplate level was checked again at mid-stick, highest stick and lowest stick. Level at all these 3 positions. I will try it out in the weekend, hopefully, weather will be good.
Ching-Ho Cheng
lcc014 is online now Find More Posts by lcc014
Old May 22, 2012, 09:36 PM
VArchT is offline
Find More Posts by VArchT
SoCal
VArchT's Avatar
Joined Oct 2011
Originally Posted by PHMX View Post
I'm starting to think there's no real issue at hand, but perhaps you're surprised about how different these flybarless systems work?
For a good example of this see Bert's "hands off fff " @ ~3:30 min.
http://youtu.be/9xXJpyzlOE4
VArchT is offline Find More Posts by VArchT
Old May 23, 2012, 12:40 AM
Slinger1 is offline
Find More Posts by Slinger1
Joined Jan 2007
90 degree wash out when pitch pumping
Originally Posted by Arey View Post
Try this solution by beenflying.
Quick update: Changing the "collective tail compensation" did not fix the problem. I even tried a setting of +12, but the result was more or less the same.
I am back to thinking it might be a mechanical problem (flex in the tail push rod or tail rotor control arm?).
Slinger1 is offline Find More Posts by Slinger1
Old May 23, 2012, 01:04 AM
Arey is offline
Find More Posts by Arey
Arey's Avatar
Philippines, NCR, Taguig
Joined Aug 2011
Tail Blade Pitch
In case you don't have enough right tail pitch..try this. Details here.
Arey is offline Find More Posts by Arey
Old May 23, 2012, 01:50 AM
MikeHRC is offline
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
The other thing to consider is your pitch and throttle curves - if your HS is too low and you put in a big pitch change the tail won't have enough power to hold and will kick out anti-clockwise
MikeHRC is offline Find More Posts by MikeHRC
Old May 23, 2012, 07:22 AM
timhoffman is offline
Find More Posts by timhoffman
timhoffman's Avatar
The Netherlands, ZH, The Hague
Joined Apr 2007
Question on hover with ZYX
Hey guys,
i maidened my Mini Titan V1 today with the ZYX gyro and the new Mini Titan V2 FBL head. The flight was successful but i have one important question.
When lifting of or landing the heli drifts more side to side and in pitch more than it was when flybarred. (ie. it does not lift off slowly and hold in a stable hover). It also tends to drift a bit in hover and does not sit in the same place as much as when flybared. It does not woble though and apart from the drifting seems quite stable in forward flight. Tail is locked in. I used the setup recomendations from Raptor technique, who has provided great instructions on setting up the ZYX.
Should i adjust the gains on the main setup screen of the software (configuration page), and therefore increase the gain a bit on the ROLL and PITCH menu? (I will quote my settings later today on what they are configured at).
OR is this something to do with the PID settings in the advanced menu?
Very happy it flies and came down after several short flights in one piece.
Tim.
timhoffman is offline Find More Posts by timhoffman
Old May 23, 2012, 10:17 AM
airtimeallen is offline
Find More Posts by airtimeallen
airtimeallen's Avatar
United States, WA, Port Angeles
Joined Nov 2010
I know it's tough when dealing with a low budget, but I still wouldn't recommend analog servos when going flybarless though. There's a bigger risk that they won't perform well enough to keep up with the flybarless unit.
Obviously you'll have to select the analog servo setting, but it will also be the slowest setting of communication for the flybarless controller.
Digital servos, especially when you take care that they do not have binding issues, will give a much better performance at almost the same price when you're buying quality analog servos.
Well i went ahead and pulled the trigger on some 65mgs cause thats what the lhs had in stock. So i got home and put em in and hooked everything up and wah la! Sittin on the bench worked good for about 10secs. Then the collective stopped working up and down. Then the aileron and elevator stopped and the servos just stopped. Wouldn't work at all. Funning thing is the rudder works fine. Just to make sure that it was getting enough power i disconnected the esc bec and hooked up an external 6v regulator. Same results.
So i contacted infinity hobby and the gyro is going back today. Nothing but troubles with this thing lately and now its prolly gonna be 2 months before this birds is airborne again and no backup. fk it! Back to airplanes for a while...
airtimeallen is offline Find More Posts by airtimeallen
Old May 23, 2012, 10:18 AM
Joined Nov 2010
65mgs are going back to the shop too. Thanks for the advise, think i'll pickup some digitals when i get a gyro back.
Old May 23, 2012, 11:04 AM
PHMX is offline
Find More Posts by PHMX
Never trust laughing dolphins
Joined Feb 2011
That really socks man. Hope the LHS is going to help out.
The important thing when using analog servos is really that using the ZYX or CopterX flybarless gyros or any other flybarless system that supports analog servos is to FIRST select the right analog servo modes, before you plug your servos in.
It's true that it can ruin perfectly good and brand-new analog servos within 10 seconds. Not sure if that's what happened of course, but just to clarify what might have happened.
PHMX is offline Find More Posts by PHMX
Old May 23, 2012, 12:02 PM
Joined Nov 2010
Yeah, i changed the settings in the gyro before plugging in the servos. I have the programmer so the settings change is real easy. The servos are fine so the shop doesn't have any problem taking em back. Especially if i order digital servos from them to replace the 65mgs
Old May 23, 2012, 01:12 PM
Truglodite is offline
Find More Posts by Truglodite
Registered Aircraft Offender
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Thanks, that's the first I heard about the MSH controller and Bert gave a very compelling review. The price, performance, and features seem revolutionary; almost too good to be true. Can't wait!
Kev
Truglodite is offline Find More Posts by Truglodite
Old May 23, 2012, 06:09 PM
fpainter3 is offline
Find More Posts by fpainter3
fpainter3's Avatar
USA, KY, Florence
Joined Aug 2007
The high dollar Skookum has a lot of the same stuff like the recovery switch, etc.
They have Gyros as well as Accelerometers built in. I wonder if Bert has tried one of those yet?
fpainter3 is offline Find More Posts by fpainter3
Old May 23, 2012, 07:14 PM
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
I'd like to see more heli god videos with SK hardware too, but the "switching from vbar..." statement pretty much says it all for me. I've been leaning towards vBar for my fb 450, but I've been waiting for the verdict on the 540. Now the MSH Brain and Align APS are just around the corner... wish everyone would give me a break launching new stuff so I can actually buy a darn controller for my dream heli, LOL! j/k Good times and affordable controllers ahead!
Kev
Old May 23, 2012, 07:28 PM
ridge_racer is offline
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
Kev
There is something for everyone's budget...
ridge_racer is offline Find More Posts by ridge_racer
Discussion New ALZRC 3GYS Flybarless System beenflying Mini Helis 644 Dec 07, 2012 04:44 AM
Found Tarot 450 or like, long flybarless feather shafts TubeBarHeli Aircraft - Electric - Helis (FS/W) 2 Jul 25, 2011 01:13 PM
For Sale New Align 3G Flybarless System V2.1 ptt81 Aircraft - Electric - Helis (FS/W) 1 Jun 06, 2011 04:55 PM
For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system blueindian Aircraft - Electric - Helis (FS/W) 0 May 31, 2011 06:09 PM
Discussion Tarot Flybarless avengedkevinfold Electric Heli Talk 1 May 04, 2011 04:46 AM
