Old Dec 05, 2011, 04:10 PM
gilb55 is offline
Find More Posts by gilb55
Joined Dec 2011
Cool
It is quite a good saving isn't it
http://www.hobbyking.com/buddy.asp?c...7-9982E9BC457B
gilb55 is offline Find More Posts by gilb55
Old Dec 06, 2011, 06:59 AM
Pigs dont fly is offline
Find More Posts by Pigs dont fly
How high does it go?..duh
Pigs dont fly's Avatar
Currently in...UK
Joined Jun 2004
Originally Posted by gilb55 View Post
Cool
Thanks for the buddy code, I just got two more for $88 .... I just hope they really are the Tarot box without the label.
Pigs dont fly is offline Find More Posts by Pigs dont fly
Old Dec 06, 2011, 09:29 AM
TX_Winds is offline
Find More Posts by TX_Winds
TX_Winds's Avatar
USA, TX, College Station
Joined Aug 2010
Any news on when Tarot will release a programming box?
TX_Winds is offline Find More Posts by TX_Winds
Old Dec 06, 2011, 11:11 AM
queadlunnrau is offline
Find More Posts by queadlunnrau
Luck is my skill
queadlunnrau's Avatar
United States, WA, Seattle
Joined Jun 2009
Cool
Thanks for that buddy code, WOW CHEAP
I'm loving this on my T-Rex 250 but at that price I'm thinking of getting one just to try in a plane. Horizon Hobby's coming out with some micro planes with a 3 axis why not try this in a larger plane? Should make hovering a lot easier.
queadlunnrau is offline Find More Posts by queadlunnrau
Old Dec 06, 2011, 01:04 PM
gilb55 is offline
Joined Dec 2011
hey thanks for using the buddycodes, appreciated
The tarot programming boxes are showing up on ebay over here in the UK
From some of the comments on the HK page it seems that the tarot programming boxes are working with the HK ZXY, so that should confirm that the HK is the tarot with a different sticker?
Old Dec 06, 2011, 01:51 PM
FixYourLAN is offline
Find More Posts by FixYourLAN
Joined Jan 2011
More ZYX Discount Buddy Codes
Here is another Buddy Code for the HobbyKing ZYX box for $44.16. It's discounted from $57.99! Make sure you are logged into HobbyKing to get the $13.83 discount!
http://www.hobbyking.com/buddy.asp?c...B-B134B860F59E
HK also has flybarless upgrade kits: 450 ver for $26.91, 500 ver for $43.49, 450 ver for $9.99
FixYourLAN is offline Find More Posts by FixYourLAN
Old Dec 06, 2011, 02:06 PM
BouncingProtos is offline
Find More Posts by BouncingProtos
Joined Jul 2011
I'm trying to level my swashplate and I have a problem. To level the swash at mid stick, you have to go to setting servo trim. Where do you go to level the swash at each end of the pitch range?
BouncingProtos is offline Find More Posts by BouncingProtos
Old Dec 06, 2011, 02:08 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
I wonder if the Hobbyking ZYX will work with the Tarot program box? Having the same name might mean yes, but so far all of the other program boxes are locked to work with their gyros only.
beenflying is offline Find More Posts by beenflying
Old Dec 06, 2011, 02:15 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Supposedly you don't have to set the swash to level other than at mid stick, with a 3 axis gyro, but I'm two minds about this. Basically there is nothing you can do, except to use better servos that have more even travel.
Old Dec 06, 2011, 02:26 PM
prop bender is offline
Find More Posts by prop bender
USA, CA, Red Bluff
Joined Dec 2007
Deleat11
prop bender is offline Find More Posts by prop bender
Old Dec 06, 2011, 03:21 PM
Luck is my skill
Joined Jun 2009
I think I recall you can move you collective during the servo trim step. I'll try it at home when I get there, but I think you can as long as you have your collective range available on throttle hold.
Old Dec 06, 2011, 04:42 PM
Joined Jul 2011
Thanks for the reply guys. I do know that when powering up, you hold left or right ail or left or right rudder to get into setup mode. This will disable the gyro itself so you can set up the pitch range with the gyro moving around on you.
I have a 450 with the tarot system also and I don't think I have this problem. Maybe it's the servos that I'm using. I have hs65 on the 450 and hxt900 on my 250.
If I can't set up my end point on individual servos then I'll leave and see if it will fly.
The tarot 250 head has alot of play in it, along the spindle and up and down if you know what I mean.
Old Dec 06, 2011, 05:03 PM
barnstorm100 is offline
Find More Posts by barnstorm100
barnstorm100's Avatar
United States, CA, Rancho Cordova
Joined Jan 2011
I saw on Ebay the programer for 35.98 free shipping. From Force Hobby. I'm wondering if I should get that one or wait for something cheaper/better? Like updated
barnstorm100 is offline Find More Posts by barnstorm100
Old Dec 06, 2011, 06:28 PM
Luck is my skill
Joined Jun 2009
Loving this setup ... I still can't get over the price of this 3-Axis gyro ... Life is good.
Tarot ZYX Flybarless T-Rex 250 (2 min 16 sec)
Old Dec 06, 2011, 07:22 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Check again! They're now down to $29 (free shipping):
http://www.ebay.com/itm/F01996-Tarot...item3f10ff489e
Discussion New ALZRC 3GYS Flybarless System beenflying Mini Helis 644 Dec 07, 2012 04:44 AM
Found Tarot 450 or like, long flybarless feather shafts TubeBarHeli Aircraft - Electric - Helis (FS/W) 2 Jul 25, 2011 01:13 PM
For Sale New Align 3G Flybarless System V2.1 ptt81 Aircraft - Electric - Helis (FS/W) 1 Jun 06, 2011 04:55 PM
For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system blueindian Aircraft - Electric - Helis (FS/W) 0 May 31, 2011 06:09 PM
Discussion Tarot Flybarless avengedkevinfold Electric Heli Talk 1 May 04, 2011 04:46 AM
