Old Apr 11, 2012, 06:48 AM
OlliW
Joined Sep 2009
Just to clarify, it is not possible to mechanically get equal pitch with the Tarot 250 FBL head. This is due to the angle of the blade arm pushrods, which gives you more positive than negative, for the same swash plate movement.
as regards collective pitch this is incorrect, moving the swash up or down by the same distance will result in identical but opposite pitch on the blade holders
OlliW is offline Find More Posts by OlliW
Old Apr 11, 2012, 06:53 AM
OlliW
Joined Sep 2009
Yes, but its easy to disagree when it's a serious compromise between resolution or a correct geometry. I'm all for resolution, but I'm against crippling things when it's unnecessary!
you are welcome to reinvent the wheel. Good luck.
(I myself at least would wonder why all FBL heads experienced pilots fly look similar in that regard.. could be for a reason...)
Old Apr 11, 2012, 06:58 AM
Never trust laughing dolphins
Joined Feb 2011
Nope, I think we are actually on the same page here. When the swash it at the correct height, there won't be any issues.
PHMX is offline Find More Posts by PHMX
Old Apr 11, 2012, 08:41 AM
Joined Dec 2011
hey ,guys i got a tarot zyx running on a trex 500 i set it up right 1 sevo swash type in dx6i n everything but funny thing is am unalbe to get the elevator channel working elevator moves correct with pitch movement but not with elevator input pls help asap
livedemon is offline Find More Posts by livedemon
Old Apr 11, 2012, 08:47 AM
Texas NewB
Black_heart's Avatar
United States, MD, Princess Anne
Joined Dec 2011
what is it doing wrong?
if it is moving backwards then in the setup revers direction for it.
Black_heart is offline Find More Posts by Black_heart
Old Apr 11, 2012, 09:59 AM
Joined Dec 2011
no buddy it does not move when i move the elevator stick ....the elevator servo only moves when i move the pitch/throttle stick....i cant figure it out y it does not move when i move the elevator stick
Old Apr 11, 2012, 10:02 AM
Texas NewB
Joined Dec 2011
How are you programing this?
Old Apr 11, 2012, 10:05 AM
Joined Dec 2011
am using the usb programmer n the tarot software
Old Apr 11, 2012, 10:06 AM
Texas NewB
Joined Dec 2011
in the monitor screen dose it show the stick moving?
Old Apr 11, 2012, 10:09 AM
Joined Dec 2011
no it the tarot software the elevator does not show any movement .....i tried enabling the tx 120ccpm n elevator works but then set it back to 1 servo n it stops back again
Old Apr 11, 2012, 10:10 AM
Joined Dec 2011
nothing shows on the moniter no elevator movement at all everything else works fine
Old Apr 11, 2012, 10:14 AM
Joined Dec 2011
am using the pc software version 2.5 for the tarot
Old Apr 11, 2012, 10:19 AM
Texas NewB
Joined Dec 2011
check your plug from RX to ZYX make sure it is plugged in properly at both ends.
Old Apr 11, 2012, 10:22 AM
Joined Dec 2011
yes i did do tht i checked it thrice rudder goes to rudder ail goes to ail ,red wire goes to elevator ....white to pitch and black to gyro gain
Old Apr 11, 2012, 10:33 AM
Joined Dec 2011
hey buddy thanx i just removed and repluged everything it started working .....thanx for the help
Discussion New ALZRC 3GYS Flybarless System beenflying Mini Helis 644 Dec 07, 2012 04:44 AM
Found Tarot 450 or like, long flybarless feather shafts TubeBarHeli Aircraft - Electric - Helis (FS/W) 2 Jul 25, 2011 01:13 PM
For Sale New Align 3G Flybarless System V2.1 ptt81 Aircraft - Electric - Helis (FS/W) 1 Jun 06, 2011 04:55 PM
For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system blueindian Aircraft - Electric - Helis (FS/W) 0 May 31, 2011 06:09 PM
Discussion Tarot Flybarless avengedkevinfold Electric Heli Talk 1 May 04, 2011 04:46 AM
