Joined Nov 2010
beginner settings with zyx gyro hk500
I am just starting to do basic figger 8s and nose in hovers and just removed the fly bar and went to zyx fbl gyro and was hopping some one could give me some basic settings.I set it up on beginner mode but it dose not feel that stable compaired to my fb set up (the tail is rock solid and stops very hard) but when hovering it seems like it needs a lot of input (my friend has a best x and can hover hands off) I have the tarot head and zyx gyro and usb interface plug in and all digital servos. Should I try 3d soft settings or just tweek beginner settings
any help would be great. thanks Ben this is video of first flite
Oxfordshire, UK
Joined Jan 2007
Ben,
Flying inside and low to the ground is never going to be as smooth as flying higher and outside as there will be a lot of air bouncing off walls + you are in ground effect (basically air bouncing up off floor). However there are some things that you can do to help - what are your dead-band settings ? Do you have the USB domgle - if so can you download your .ini file and post it up here Cheers, Mike |
And since you asked about other peoples settings most of the guys are here http://www.rcgroups.com/forums/showthread.php?t=1568592 for settings and here http://www.helifreak.com/showthread.php?t=375742 |
Latest blog entry: tgz
Joined Feb 2011
![]() As for heads-off hovering, that can be two things. Either your swash plate isn't level and moving level when controlling the collective or the gain on your flybarless unit is not high enough. Bear in mind though that with such a huge headspeed it should have already flown extremely stable (less gain required to achieve the same 'hold' on all axis), so it must be something mechanical. I also agree that you might have to simply dial in more exponential in your radio. These units do require a lot when you're not really using them for 3D (whether not yet or not at all ) and do not want the touchy responsiveness. You could also change the ATV (adjustable travel value or channel end point settings) to something lower than 100% high and 100% low. This will also tone the responsiveness down, without messing with the flybarless settings too much.
@bsovermars
Nice flying, that did not look too bad at all. That being said, +1 to PHMX. That HS looked very high, probably 3000+... way too hot for a beginner, and probably pushing the safe limit on a 500-class. BTW, the material quality of these HK clones probably cannot handle more than 2900 RPM HS. Particularly, your tail rotor is likely to explode. or your main blade grips might let go of the FS ![]() ![]() I'd recommend changing your pinion to get 2400 RPM at 80-90% throttle. This should be plenty HS for moderately aggresive sports flying and aerobatics. In my experience, 500-class helis don't fly very well under 2400 RPM unless you have really soft dampers and blades, or a multi-bladed rotor. Setting up your collective range to +/- 10 degrees, and cyclic range to 7 deg will also help tone it down a notch. You can also go to the FBL unit settings and drop the pitch/roll agility a few points. Drop piro speed in the tail settings as well. Also good idea, as recommended above, to drop your D/R and add a good amount of expo (30-40%). If you have the program box or USB cable, go and decrease the RC deadband to a value of 10-15 for both tail and swash. Finally, I think the Beginner mode is quirky on these units, particularly on the tail. I would start with the mild 3D preset and tune it down in the agility/piro speed, as well as decreasing the coll/cyclic ranges. |
Joined Aug 2010
This one has me stumped
I have a Tarot 450 Pro V2 FBL with ZYX gyro. The best helo guys in the area went over this helicopter with a fine tooth comb and said it looks and feels perfect mechanically.
The issue is, is I have programmed the Tarot 450 Pro to 3D Soft and the only modification was to change the RC deadband from 64 to 10. The helicopter flies fine in Headlock mode but NOT Rate mode. DX6i gain set at 71% as per the manufacturer for Headlock mode and Rate mode is set at 28% (also as per Tarot) I can fly around fine in Headlock mode but it feels like I am right on the edge of tail wag. If I bump the rudder, it wags a little and dampens out. If I try to fly in Rate mode, I get moderate to severe tail wag just before the heli breaks ground. I have to abort and switch to headlock mode to get a flight in (probably a bad idea) I tried changing rate mode all the way down to 15% but no change. I am seeing the ZYX01 change modes on the heli with the red light and blue light. So, is there something in the ZYX 2.5 software that I should change to tame down the Rate mode?? Thank you for your help. |
see MH this is what I'm talking about. I've seen people with the beastx with similar issues, they change their tail servo into the mks ds95i, increased their cyclic pitch to 9 degrees, dropping the collective pitch to 11 deg and not higher etc etc until they got their tail to lock. Are we having incompatibility issues just like the beastx? Or are we just going on the assumption that all tail servos are compatible with this gyro? We need to look at this at a professional level like the spartan creating a database of compatibility servos. I dunno like i said MH i'm just a geezer waiting for the zyx101 video.
![]() The info was taken from my friend holger with his beastx and 250.
P.S I'm not saying everyone should buy an mks ds95i, i'm just saying it could be incompatibility issues?? I've seen other setups that seems to work nicely with the Tarot
![]() But you really don't need it. Any issues you might have can be worked through here on the forum. Just ask away.
Latest blog entry: RC Parts Suppliers - The Good and the...
I understand my friend, it's ok, someone here will make a professional setup video, there's always another finless bob.
with an almost 200,000 views and so many of the pros using this tarot zyx, one of them will do it. I could feel it.
| Thread Tools | |
| Discussion New ALZRC 3GYS Flybarless System | beenflying | Mini Helis | 644 | Dec 07, 2012 04:44 AM |
| Found Tarot 450 or like, long flybarless feather shafts | TubeBarHeli | Aircraft - Electric - Helis (FS/W) | 2 | Jul 25, 2011 01:13 PM |
| For Sale New Align 3G Flybarless System V2.1 | ptt81 | Aircraft - Electric - Helis (FS/W) | 1 | Jun 06, 2011 04:55 PM |
| For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system | blueindian | Aircraft - Electric - Helis (FS/W) | 0 | May 31, 2011 06:09 PM |
| Discussion Tarot Flybarless | avengedkevinfold | Electric Heli Talk | 1 | May 04, 2011 04:46 AM |
