Old Sep 25, 2011, 09:33 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
New Tarot ZYX/ZYX-S/ZYX-S2 Flybarless System
I just found this Tarot ZYX flybarless 3 axis gyro system:
Description: Name: Tarot_ZYX_2.jpg
Description: Name: zyx012.jpg
Description: Name: Prg_Box.jpg
Description: Name: USB_Link_Cable.jpg
Description:
Name: ZYX-S2 and box.jpg
Description: Name: zyx-s2-1.jpg
Description:
Says it's for 200 to 700 size helicopters on the box.
They have used the single plug with 3 Rx wires to keep the size down.
This unit can be programmed by the Tx or by a programming box. The Tx programming works fine, but the larger values are trickier to set. Setup is easier with the program box and a lot more options are available.
Note: This gyro does not have a total limit setting or a cyclic ring, so it is not possible to stop binding at stick corners.
!!! HOT !!!
The new ZYX-S2 - 32 bit processor, new MEMS sensors: Details Link - New Software Link
Dr.M's 3D plane settings: http://www.rcgroups.com/forums/showp...ostcount=10031
IFHELI's Quad setup: http://www.rcgroups.com/forums/showp...postcount=9447
ZYX v4 compared to VBar v5.3: http://www.rcgroups.com/forums/showp...postcount=8380
V4.01 for the ZYX and ZYX-S: http://www.rcgroups.com/forums/showp...postcount=7092 - See this also: http://www.rcgroups.com/forums/showp...postcount=7206
-V4.01 has separate versions for helicopter/airplane and quadcopter. The heli/plane version does not initialize the servos until after the gyro initializes to avoid a servo kick.
-Safe v4 upgrade steps: http://www.rcgroups.com/forums/showp...postcount=7608
V3.50 for the ZYX and the ZYX-S: http://www.rcgroups.com/forums/showp...postcount=4014 - PLEASE READ THIS ALSO: http://www.rcgroups.com/forums/showp...postcount=4039
The new Tarot ZYX-S and ZYX v3.0: http://www.rcgroups.com/forums/showp...postcount=1843
John_nz's PC application and information: http://fbl.net.nz/
!!! NOT HOT !!!
-None of the ZYX/ZYX-S tools (bluetooth adapter, program box, PC app) work with the ZYX-S2
-Fusuno canopies. Poor customer service and very slow to ship. It would seem their canopies all come from Vietnam. When it did finally arrive they had also forgotten to put the 4 mounting holes in the canopy, and had not provided any grommets.
-Compass Warp 360. Poor inconsistent quality, causing crashes.
-xmseller/xmhobbies/CNC helicopter. They say you only find out how good a company is when something goes wrong. I found out.
NOTE:
It's come to my attention that people don't want to post in this thread, because they think their question is too simple or should be obvious. Quite the contrary! Hey, we all had to start with zero knowledge of FBL and FBL controllers and we don't all have time to search the entire forum, so please, no matter how simple you think your question is, ask away. There are a lot of kind people subscribed to this thread that are happy to share their knowledge of FBL with you. Look forward to your post. David
NEW STUFF!!!!!!!!!!!
What's in the box: http://www.rcgroups.com/forums/showp...6&postcount=22
Installed in a 250: http://www.rcgroups.com/forums/showp...3&postcount=29
Setting the limits: http://www.rcgroups.com/forums/showp...&postcount=402
Flight report: http://www.rcgroups.com/forums/showp...8&postcount=30, http://www.rcgroups.com/forums/showp...3&postcount=43
Flight video 500EFL Pro: http://www.rcgroups.com/forums/showp...&postcount=830
Tail/yaw settings: http://www.rcgroups.com/forums/showp...postcount=1836
My 250SE with DFC setup file: http://www.rcgroups.com/forums/showp...postcount=3402
My 450 Pro setup file: http://www.rcgroups.com/forums/showp...postcount=2986
Spektrum/JR Rx connection diagram: http://www.rcgroups.com/forums/showp...&postcount=796
ZYX-S Binding instructions:
http://www.rcgroups.com/forums/showp...postcount=3268
http://www.rcgroups.com/forums/showp...postcount=5239
Video (thanks bionicbone): http://www.rcgroups.com/forums/showp...ostcount=10185
What's inside the Tarot ZYX (thanks Desmogod): http://www.rcgroups.com/forums/showp...6&postcount=95
Dimensions:
37 x 25 x 13
Cyclic timings: (thanks eagle777)
Guides:
bionicbone's howto Downloading, unzipping and Installing all the required software: http://www.rcgroups.com/forums/showp...ostcount=10076
Arey's getting started tips: http://www.rcgroups.com/forums/showp...postcount=3286
sp00fman's basic beginners steps: http://www.rcgroups.com/forums/showp...postcount=5795
Dr.M's advanced tuning and troubleshooting: http://www.helifreak.com/showthread.php?t=485789
My recommended initial setup: http://www.rcgroups.com/forums/showp...postcount=9064
raven_darkcloud's installation and setup manual: http://www.rcgroups.com/forums/showp...postcount=9173
2Doggs USB driver installed correctly: http://www.rcgroups.com/forums/showp...postcount=9788
wc_wickedclown's bank switching video: http://www.rcgroups.com/forums/showp...ostcount=10756
Videos:
Setup video using the Tx (thanks ZeroPitch): http://www.rcgroups.com/forums/showp...&postcount=308
Setup guide for PC App and flybarless conversion: (a big thanks to sgbfly/Simon)
Part 1 to 5: http://www.rcgroups.com/forums/showp...postcount=2311
ZYX
Flight video 250 (thanks MikeHRC): http://www.rcgroups.com/forums/showp...6&postcount=62
Flight video 250 (thanks queadlunnrau): http://www.rcgroups.com/forums/showp...&postcount=269
Flight video miniTitan (thanks RaptorTechnique): http://www.rcgroups.com/forums/showp...2&postcount=53
Flight video Blade 400 (thanks ZeroPitch): http://www.rcgroups.com/forums/showp...&postcount=229
Flight videos Trex 450 (thanks zhnme523): http://www.rcgroups.com/forums/showp...postcount=1712
Flight video Trex 550 (thanks pitchp) http://www.rcgroups.com/forums/showp...postcount=1975
Flight video Trex 600 (thanks unochen): http://www.rcgroups.com/forums/showp...&postcount=477
Flight video Trex 700 (thanks unochen): http://www.rcgroups.com/forums/showp...&postcount=311
Flight videos (thanks pitchp): http://www.rcgroups.com/forums/showthread.php?t=1629287
ZYX-S
Flight video Trex 700 (thanks pitchp): http://www.rcgroups.com/forums/showp...postcount=5012
ZYX/ZYX-S v3.5
Flight video 450 (thanks peter24): http://www.rcgroups.com/forums/showp...postcount=7668
Flight video 450 SE (thanks pani): http://www.rcgroups.com/forums/showp...postcount=5023
Flight video Trex 500 (thanks DerClown) : http://www.rcgroups.com/forums/showp...postcount=5685
Flight video Protos 500: http://www.rcgroups.com/forums/showp...postcount=4823
Flight video Gaui X5: http://www.rcgroups.com/forums/showp...postcount=4674
Flight video Trex 550 (thanks pitchp): http://www.rcgroups.com/forums/showp...postcount=4275
Flight video M-3D 600: http://www.rcgroups.com/forums/showp...postcount=4340
Flight video Logo 600SX: http://www.rcgroups.com/forums/showp...postcount=5539
ZYX/ZYX-S v4.0
Flight video 450 (thanks sp00fman): http://www.rcgroups.com/forums/showp...postcount=7244
Flight video 450 Sport: http://www.rcgroups.com/forums/showp...postcount=7322
Flight video 450 (thanks sgbfly): http://www.rcgroups.com/forums/showp...postcount=7323
Flight video 450 (thanks wc_wickedclown): http://www.rcgroups.com/forums/showp...postcount=2288
Flight video 450 (thanks wc_wickedclown): http://www.rcgroups.com/forums/showp...postcount=8965
Flight video Mini Protos (thanks Sp00fman): http://www.rcgroups.com/forums/showp...postcount=9171
Flight video Protos 500 (thanks pani): http://www.rcgroups.com/forums/showp...postcount=7554 & http://www.rcgroups.com/forums/showp...postcount=7564
Flight video Logo 400: http://www.rcgroups.com/forums/showp...postcount=8977
Flight video Logo 550SX: http://www.rcgroups.com/forums/showp...postcount=8035
Flight video Logo 700 Extreme (thanks pitchp): http://www.rcgroups.com/forums/showp...postcount=8390
Main site: http://fbl.net.nz/
Information: http://fbl.net.nz/info
USB/Bluetooth link PC software:
http://www.rcgroups.com/forums/showthread.php?t=1568592
USB Link tips:
1/ Make sure the USB link is assigned a COMs port of 4 or less (COM1, COM2, COM3, or COM4). This is done in device manager.
2/ The gyro must also be initialized to connect (Tx and Rx on and the single red or blue LED lit on the gyro).
PC Connection issues:
Thanks JetPlaneFlyer: http://www.rcgroups.com/forums/showp...postcount=6522
Windows 8:
Thanks ahamay: Post 6420, Post 6444 & Post 6454
Thanks pitchp: http://www.rcgroups.com/forums/showp...postcount=6445
Advanced Manual: (thanks to Dave Settle and Jaakko Haavisto)
http://fbl.net.nz/files/fblmanual.pdf
Wiki Page: (thanks RobinBennett)
http://www.eflightwiki.com/eflightwi...itle=Tarot_ZYX
Firmware updates (gyro and program box):
See here: http://www.rcgroups.com/forums/showthread.php?t=1568592
Links:
Tarot ZYX: http://www.infinity-hobby.com/main/p...oducts_id=7609
Tarot ZYX-S: http://www.infinity-hobby.com/main/p...oducts_id=8201
Tarot USB Link: http://www.infinity-hobby.com/main/p...oducts_id=7935
Tarot Program Box: http://www.infinity-hobby.com/main/p...oducts_id=7853
Tarot ZYX with 250 head: http://www.oomodel.com/tarot-zyx-3-a...2-p-61906.html (NOTE: I prefer the Align DFC head now)
Tarot ZYX with 450 head: http://www.oomodel.com/tarot-zyx-zyx...d-p-61907.html
Tarot ZYX with 500 head: http://www.oomodel.com/tarot-zyx-3-a...d-p-61851.html
Note: These are just links for reference material. They are not necessarily the best prices or best service available.
beenflying is offline Find More Posts by beenflying
Old Sep 25, 2011, 10:07 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Looks like it could be this Helicox TG-1 rebadged to Tarot:
Description: Name: Helicox_TG-2.jpg
Description: Name: Helicox_TG-3.jpg
Description:
http://www.myrcmodel.com/index.php?m...oducts_id=2249
Old Sep 26, 2011, 04:32 AM
pitchp is offline
Find More Posts by pitchp
Retired
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
How much is it BF?
pitchp is offline Find More Posts by pitchp
Old Sep 26, 2011, 04:40 AM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
I'm not sure what price the Tarot one is going to be. The Helicox TG-1 appears to be $98 from Hobby-Wing, but that doesn't appear to include the programmer. The strange thing is, I can't find the programmer listed on it's own, so perhaps the text in the listing is wrong.
Old Sep 26, 2011, 06:52 PM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
i guess we'll find out the price in about a weeks time. infinity-hobby has them aswell
Old Sep 30, 2011, 08:16 PM
cap231ex is offline
Find More Posts by cap231ex
Track clear , smoke on !
cap231ex's Avatar
3 miles from AMA HQ Muncie, IN.
Joined Jan 2009
Saw it too , been you going to test this one when it's avalible?
cap231ex is offline Find More Posts by cap231ex
Old Sep 30, 2011, 08:44 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
I'm no sure yet. It probably depends on how well the ALZRC unit flies. The 3GYS gyro on it's own is going to be pretty cheap, and I like how it works so far, but it all means nothing if it doesn't fly well.
Old Sep 30, 2011, 10:04 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Infinity Hobby have put up a video:
http://www.infinity-hobby.com/main/a...rticles_id=251
I don't see the cable tie in the installation hardware pack.
Old Oct 01, 2011, 12:12 AM
jockstrap is offline
Find More Posts by jockstrap
jockstrap's Avatar
Joined May 2011
The Tarot one has 3 LEDs on it thou? So there are some differences ?
Maybe just a newer model..
jockstrap is offline Find More Posts by jockstrap
Old Oct 01, 2011, 02:58 PM
ridge_racer is offline
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
I love all this. Maybe once I go FBL to reduce repair time between crashes, I'll be more compelled to fly my heli more...
ridge_racer is offline Find More Posts by ridge_racer
Old Oct 09, 2011, 09:17 PM
emberjelly is offline
Find More Posts by emberjelly
emberjelly's Avatar
N.S.W, Australia
Joined Mar 2010
Any news on the release date yet?
emberjelly is offline Find More Posts by emberjelly
Old Oct 10, 2011, 12:10 AM
Desmogod is offline
Find More Posts by Desmogod
Australia, WA, Exmouth
Joined Jan 2010
Mid October according to infinity.
Desmogod is offline Find More Posts by Desmogod
Old Oct 10, 2011, 12:20 AM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
looks good on the big birds. I hope it will perform just as good on the small birds.
TAROT ZYX 3axis Gyro Test (3 min 16 sec)
Old Oct 12, 2011, 06:43 AM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
I might try this one day
http://www.infinity-hobby.com/main/p...oducts_id=7611
TAROT ZYX 3AXIS GYRO with Trex 250 FL TEST (5 min 6 sec)
Old Oct 12, 2011, 01:11 PM
cap231ex is offline
cap231ex's Avatar
Joined Jan 2009
Not a bad price , and seems to include the 250 FBL head as well.
Discussion New ALZRC 3GYS Flybarless System beenflying Mini Helis 644 Dec 07, 2012 04:44 AM
Found Tarot 450 or like, long flybarless feather shafts TubeBarHeli Aircraft - Electric - Helis (FS/W) 2 Jul 25, 2011 01:13 PM
For Sale New Align 3G Flybarless System V2.1 ptt81 Aircraft - Electric - Helis (FS/W) 1 Jun 06, 2011 04:55 PM
For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system blueindian Aircraft - Electric - Helis (FS/W) 0 May 31, 2011 06:09 PM
Discussion Tarot Flybarless avengedkevinfold Electric Heli Talk 1 May 04, 2011 04:46 AM
