Old Sep 25, 2011, 08:10 PM
IdahoAir is offline
Find More Posts by IdahoAir
IdahoAir's Avatar
South Central Idaho
Joined Mar 2009
R L Adams foam board question
The "dollar store" foam we have in my area is principally R L Adams foam board, paper backed on both sides and about 4mm with the paper on. Been using it to build electric planes for over a year.
Now I'm working on a more sophisticated soaring glider design and I'd like to know more about its physical qualities.
However, try as I might, I can't find out what "kind" of foam it is. R L Adams doesn't list what type of foam it is anywhere. About all I can find is that it's "acid-free".
Does anyone know? Cheers.
IdahoAir is offline Find More Posts by IdahoAir
Old Sep 25, 2011, 09:26 PM
springer is offline
Find More Posts by springer
treefinder
springer's Avatar
SE MI
It's polystyrene just like the Dow blucor or PBlll. The only difference is color, cell size/density and absence of a plastic film covering. The part that's acid free is probably the kraft paper on each side. RL Adams also makes the Dow products for Dow in Michigan.
springer is offline Find More Posts by springer
Old Sep 25, 2011, 09:47 PM
justwanttofly is offline
Find More Posts by justwanttofly
I just want to fly
justwanttofly's Avatar
United States, IN, New Albany
Joined Aug 2008
If your worryed about strenght I econolight and cover the whole plane it makes the plane so much durable with very little weight gain..good luck with the build
justwanttofly is offline Find More Posts by justwanttofly
Old Sep 25, 2011, 11:08 PM
IdahoAir is offline
IdahoAir's Avatar
South Central Idaho
Joined Mar 2009
It's poly ... excellent. I'm working on a simple method to "cold form" a 2m wing and it involves some compression of the foam. I also needed to check out its thermal resistance as it will be covered with a lightweight material as well such as Solarfilm Solite. Now, to build the test fixture....
Thanks guys ...
