Old Sep 25, 2011, 01:54 PM
Dennis Sumner is online now
Find More Posts by Dennis Sumner
Wanted for breaking Ohm's Law
Dennis Sumner's Avatar
United States, MI, Canton
Joined Sep 2002
Build Log
LoPresti Fury (Globe Swift)
I came across the Lopresti Fury a while back and always liked the Globe Swift so I decided to try and capture the Fury in 1/7 scale.
A little history of where the LoPresti Fury came from. The following is from the Lopresti Fury website; Loprestifury.com "The LoPresti family owns the Fury design and the prototype. Roy left behind the plans, the tooling and even the bill of materials with every nut and bolt specified. More importantly Roy left behind a family of aviation engineers. Curt LoPresti heads the family business "Speed Merchants". They are known as the premier go-fast aviation company which "re-engineers" the designs of others. Speed Merchants is the place aviators go to when they need more you know what. (Speed!)" Work started back in 1990 and they continue to fine tune the design today.
My model will have a 50" span and have about 385 square inches. I will be using a Scorpion 3014-1040Kv motor, Ice 50Amp esc and E-Flite 15-25 85 degree electric retracts.
Here are some pictures of the real one. I just found out that they are in process of repainting the Fury. I believe the new paint scheme will have the current scheme inverted, what is now yellow will be red and what is red will now be yellow.
Denny
Dennis Sumner is online now Find More Posts by Dennis Sumner
Old Sep 25, 2011, 01:57 PM
Joined Sep 2002
Here are the fuse formers and firewall. The fuse sides will be 1/16 as well as wing sheeting....
Old Sep 25, 2011, 02:02 PM
Joined Sep 2002
The tail feathers will be 3/16 balsa and I will cut the stab in half and glue at the 16 degree dihedral after shaping and hinging.
The cowl is built up from layers of 1/4 balsa assembled on 1/8 music wire rods.
I will post more pictures when the build gets underway.
Denny
Old Sep 25, 2011, 03:02 PM
rickhensley is offline
Find More Posts by rickhensley
GliderPilot
rickhensley's Avatar
United States, NC, Charlotte
Joined Aug 2011
Nice plane and will watch this one. Do not often see this one modeled.
rickhensley is offline Find More Posts by rickhensley
Old Sep 25, 2011, 03:36 PM
raipe is offline
Find More Posts by raipe
raipe's Avatar
Finland
Joined Oct 2008
Way cool!
Thanks a lot for sharing. The Fury is the sexiest GA aircraft I've seen.
Here's a great read from The pilot Corkey Fornof:
Plane talk
Lots of great info on the plane among other stuff.
raipe
raipe is offline Find More Posts by raipe
Old Sep 25, 2011, 04:51 PM
GeoffinIN is offline
Find More Posts by GeoffinIN
Two left thumbs
Muncie, IN
Joined Sep 2006
The Swift is an elegant looking plane in stock configuration, and the mods don't seem to detract from it. Great choice!
Geoff
GeoffinIN is offline Find More Posts by GeoffinIN
Old Sep 26, 2011, 04:19 AM
OzparkPilot is offline
Find More Posts by OzparkPilot
Watts up ?
OzparkPilot's Avatar
Australia, NSW, Sydney
Joined Nov 2006
sub`d !
OzparkPilot is offline Find More Posts by OzparkPilot
Old Sep 27, 2011, 05:19 PM
Joined Sep 2002
I've made some progress on the fuse...I cut the two sides out of 1/16 balsa and located the firewall, F1, F2, F3, and F4. I also glued the additional 1/16 sheet which will form the turtle deck. The triangle stock, wing saddle doubler, and 1/4 square have also been added.
Denny
Old Sep 27, 2011, 05:26 PM
Joined Sep 2002
Building up the fuse;
Here I have the top view of the plan with center line highlighted and the fuse sides and firewall and formers positioned but not glued.
I made sure everything was squared up then glued the F2, F1 and finally the firewall. Note the top of the 1/4 square is 0-0 so by shimming the fuse until the 1/4 square is at 0-0 you can then use a triangle to make sure thrust is 0-0 and by sighting down on the top view make sure I am not building any left thrust!
Denny
Old Sep 27, 2011, 08:03 PM
BluIIs is offline
Find More Posts by BluIIs
O'Fallon, Mo.
Joined Apr 2010
Subscribed and fascinated. I love that little Swift!
BluIIs is offline Find More Posts by BluIIs
Old Sep 27, 2011, 08:07 PM
Watts up ?
Joined Nov 2006
Originally Posted by raipe View Post
Way cool!
Plane talk
raipe
Great stuff... Corkey was the Pilot flying the BD-5 though the hanger in James Bond Octopussy film !
Old Sep 28, 2011, 04:03 AM
raipe is offline
raipe's Avatar
Finland
Joined Oct 2008
Great progres! Do you have a 3-view or what are you using as a plan?
Among other cool movie stunts
raipe
Old Sep 28, 2011, 06:05 AM
Joined Sep 2002
Raipe,
I am working from my plans developed from a 3 view. I drew it up in CAD and had the formers, ribs, etc laser cut.
Denny
Old Sep 29, 2011, 07:06 AM
raipe is offline
raipe's Avatar
Finland
Joined Oct 2008
Originally Posted by dsumner View Post
Raipe,
Denny
I had a hunch about laser cutting when I looked at the pics, good work. Did you use a Swift 3-view or do you have one for the Fury. I have never seen one and trust me I've searched
Keep up the good work
raipe
Old Sep 29, 2011, 07:59 AM
Joined Sep 2002
Raipe,
Here's what I started with....
Denny
Globe Swift R. Green Scale Kit/Scratch Built 19 Jan 10, 2016 07:19 PM
Help! Looking for Plans? Globe Swift 1946 Ken Park Scale Kit/Scratch Built 18 Oct 06, 2009 04:47 AM
JDM GLOBE SWIFT-Ready for Maiden tahoecrest Parkflyers 25 Nov 08, 2004 12:41 PM
FS: Globe Swift with retracts hole digger Aircraft - Electric - Airplanes (FS/W) 3 Oct 19, 2004 06:57 PM
Motor Suggestion for Globe Swift? RCFlybry Parkflyers 4 Nov 12, 2002 02:16 PM
