Joined Feb 2011
Thanks guys. Looks like the 7C just is not the right TX. I will use it for now for low close flight while I learn the WKM.
I have an 8FGS on order and it should be able to do what I need and best of all will eliminate a bunch of wires with the S bus. Only bummer is a whole new radio to learn.
Joined Mar 2010
Hi Tony,
"Frame-Droidworx Skyjib8 Octocopter ESC-Hobbywing Fentium 80A Motors-Axi 4120/20 Props-APC 14 x 4.7 Camera 5D Weight without cam is over 5.5 Kilos" I am also planning to get the SkyJib 8. How's the flight time on it and you managed to get t to fly stable? Cheers. |
Lake Zurich, IL
Advance parameter tuning-
“I” value Better left alone, it is mainly for forward flight with head wind. Increase for strong head wind. Decrease for strong tail wind. “V Damping” value Ascending and descending braking, as to how fast you want the multi to stop. Increase value to have fast braking. “Disturb Gain” value Increase to have higher position hold; decrease to have less. Fine tuning between ATTi and GPS modes in position hold. All advance parameters are only good in GPS mode. ------------------------------------------------------------------ A short clip using WKM inside DJI
Have a Original Gaui 330XS witch I upgraded with DJI wookokng M.
I setup all function for 3 mode switch, and failsafe is working. Jr XG7 with 8ch RX. When I try to fly, it was flipping over. I tried to calibrate the ESC with same procedure as with original Gaui, but cannot complete this. I put TX on, and set it to full throttle. Connect RX, and hear the melody of 3 beeps, other 3 beeps, an then 1 beep at the end. When i lower the stick to 0%, there is no confirmation. Why? Picture of my Quad: http://www.raceinfo.no/temp/tn_IMG_8442.JPG |
Belgique, Région Wallonne, Wavre
Joined Feb 2011
I think I had the same problem as yours when trying to calibrate my Turnigy Plush ESC, and my issue was that I had already cut/removed the red wire from the ESCs, then tried to calibrate them and it wouldn't work. If this is your case, you need to put back the red plug/cable on your ESC, and one by one calibrate them by only having it connected one by one to your receiver, then remove back the red wire and connect to the DJI MC. This is one main reason I think people telling to cut the ESC's red wire are giving a wrong advise - most ESCs come with a standard servo connector getting in the flight controler or receiver and it is quite easy to just remove the pin coming from the red cable from the ESC's connector, this way you can put it back whenever needed. |
Thanx for this advise. I will try this today
In fact if that's how you have your motors wired up as per your numbers on the arms, they are wrong also. If the green sting is front then you need to turn your GPS 180 and your motor's should be wired up as per the manual, front right 1, front left 2... Rear left 3 and rear right 4 |
| Thread Tools | |
| New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** | DJI INNOVATIONS | Multirotor Electronics | 18047 | Yesterday 08:07 PM |
| Discussion DJI - WooKong eStab for Scale | sidneyw | Scale Helicopters | 97 | Dec 30, 2012 10:48 AM |
| Cool Karbonic-XXL 50CM DJI WooKong-M frame | superdave42 | Multirotor Talk | 12 | Mar 09, 2012 10:01 AM |
