Old Sep 25, 2011, 03:31 AM
Great Britain
MrBen.'s Avatar
Joined Dec 2008
FS Dominator or CZ Cinemizers?
Who has tried both and which do you prefer? The FOV/Screen size is simular right?
MrBen. is offline Find More Posts by MrBen.
Old Sep 25, 2011, 10:01 AM
Romania, Dolj, Craiova
Joined Sep 2007
I tried a FS in 2009 and that version does not compare with Cinemizer. I don't know about Dominator.
No, FOV is not similar at all ! FS use a forced optical formula to obtain an abnormal wide FOV, over 45 degrees or so, which make the edges very blurry, making some OSD impossible to read. For the same reason the IP distance tuning is very critical.
Cinemizers use a normal FOV, about 32 degrees, somewhere in this ballpark, anyway wider enough to not experience tunnel effect, but also to not affect resolution at all, in any point on the screen. The clarity is stunning, we have a saying in our country when we want to define the transparency of a thing: "Zeiss Crystal" ! I hope this should say all.
renatoa is online now Find More Posts by renatoa
Old Sep 25, 2011, 02:11 PM
Great Britain
MrBen.'s Avatar
Joined Dec 2008
Both the cinemizers and the dominators have a 30degree FOV, I have the FS base already and have briefly tried the cinemizers and my first impressions were 'small screen' compared to fs base. Im leaning towards the dominators due to the fact they have light blocking and add-ons like HT and RX available, probably more suited to field use too. However the picture is the most important factor that's why I am asking if anyone has compared both.
Old Sep 26, 2011, 08:11 AM
AnthonyRC's Avatar
Switzerland
Joined Sep 2004
Image quality on the dominators is very good, slightly smaller image than the RCV922, but very crisp.
The built-in 5G8 receiver option is very good, as is the head-tracker. Combine with a couple of cloverleafs, and a 600mW 5G8 Tx, and the smiles are guaranteed.
The silicone eye pieces are just plain cool, and very functional.
One was made for FPV, one was not.
The facts are presented, the decision pretty easy :-)
AnthonyRC is offline Find More Posts by AnthonyRC
Old Sep 26, 2011, 09:01 AM
hannson's Avatar
Poland / SILESIA
Joined Nov 2005
Anthony . Did you tried both ?
Cinemizers have a lot better picture quality than FS BASE.
the question is who tried both and can compare Dominators to Cinemizers ?
hannson is offline Find More Posts by hannson
Old Sep 26, 2011, 10:37 AM
Netherlands, NH, Edam
Joined Jul 2004
I tried both and Anthony outlines exactly my train of thought. Cinemizers are JUST video goggles, Dominators are an integrated FPV solution, it is all you need to bring to the field, the Cinemizers need cables, a Rx, a battery for the Rx, more cables, etc. etc. The decision you need to make for FPV use is pretty clear to me ...
ssassen is offline Find More Posts by ssassen
Reply With Quote  (Disabled)
Old Sep 26, 2011, 11:04 AM
hannson's Avatar
Poland / SILESIA
Joined Nov 2005
ok thanks
how about picture quality comparasion?
Old Sep 26, 2011, 12:01 PM
Chris R
United Kingdom
Joined Dec 2009
Which has best picture quality?
Cir2kuk is offline Find More Posts by Cir2kuk
Old Sep 26, 2011, 12:11 PM
malcr001's Avatar
United Kingdom, England, Gt Lon
Joined Nov 2007
All of that is irrelevant if you’re using a groundstation minus headtracker. I just want the goggles to be good at what they are intended to do and that’s provide a good picture, block sun light and have adjustable IPD. Which one is better under those specifics?
malcr001 is offline Find More Posts by malcr001
Old Sep 26, 2011, 12:35 PM
Joined Sep 2007
Cinemizer does not have adjustable IPD, just adjustable diopter.
Dominator, unlike older FS models, seems to have also fixed IPD, at least so suggest tech specs:
"Tecnical Specification:
- FOV 30 degrees diagonal - Interpupillary (IPD) distance:63.5mm
Latest blog entry: JRSky - birth of a dream radio
Old Sep 26, 2011, 01:02 PM
malcr001's Avatar
Joined Nov 2007
So they seem to be more or less the same so preference would be to fatshark since they are more suited to FPV'ers?
How do the fatshark dominators compare against these?
http://www.foxtechfpv.com/allinone-f...ade-p-258.html
Old Sep 26, 2011, 02:25 PM
CEL abuser
USA, CO, Denver
Joined Dec 2010
I've never used fatsharks but I'm happy with my AIOs. Very easy ground station, if you even want to call it that, really I plug it into my futaba trainer port for power, screw a turbine CP antenna on the goggles and fly.
pr0ject42 is offline Find More Posts by pr0ject42
Old Sep 26, 2011, 02:31 PM
Great Britain
MrBen.'s Avatar
Joined Dec 2008
well I've gone ahead and ordered the dominators from Tim @ readymaderc
New Product New Fat Shark Dominator - specs/photos fatshark Video Piloting (FPV/RPV) 730 Apr 13, 2013 09:59 PM
Discussion scherrer lrs uhf and dominator ht combine? gider Video Piloting (FPV/RPV) 13 Sep 19, 2011 09:01 PM
Discussion Freeair cz or Robotburds streetraceer micro warbirds summyboy Indoor and Micro Models 0 Mar 08, 2011 12:03 PM
FS: Dominator 500 (Plane or RTF) WJ Birmingham Aircraft - Fuel - Airplanes (FS/W) 0 Apr 23, 2003 10:19 AM
FS: Lanier Dominator 500 (Plane or RTF) WJ Birmingham Aircraft - Electric - Airplanes (FS/W) 0 Apr 22, 2003 09:42 PM
