Old Sep 24, 2011, 11:11 AM
Toysrme is offline
Find More Posts by Toysrme
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
Resoldered Balance Tab, Still Won't Balance
So I pulled two wires off my balance tab. Soldered them back on. Check it on the MM & the voltages are there.
But the charger still refuses to see the pack. What's the deal?
Toysrme is offline Find More Posts by Toysrme
Old Sep 24, 2011, 11:41 AM
flydiver is offline
Find More Posts by flydiver
flydiver's Avatar
United States, WA, Seattle
Joined Jan 2007
Absolutely certain you soldered them to the right place. If you switched them...could be an issue.
flydiver is offline Find More Posts by flydiver
Old Sep 24, 2011, 07:42 PM
rampman is offline
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
As you work from the black to red wires, put black mm probe on black, red next to it. Move red mm probe one spot, repeat till you move to last wire. Do you voltages increase with every probe? It should. If not, fix that and try again.
If OK post what pack and charger you are using. A nice picture/pictures would help us too.
Rick
rampman is offline Find More Posts by rampman
Old Sep 24, 2011, 09:40 PM
lipoflyer is offline
Find More Posts by lipoflyer
lipoflyer's Avatar
Australia
Joined Nov 2010
you could also use a lipo monitor if you have one?
lipoflyer is offline Find More Posts by lipoflyer
Old Sep 24, 2011, 11:14 PM
rampman is offline
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
No, those will not work if he crossed 2 wires.
Old Sep 25, 2011, 06:46 AM
lipoflyer's Avatar
Australia
Joined Nov 2010
In which case it would be a give away that something is wrong
Old Sep 29, 2011, 12:50 PM
Toysrme is offline
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
Rick
yes
Old Sep 29, 2011, 12:53 PM
Toysrme is offline
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
it would have been hard to cross the wires. one was ground & the other was the only wire on that solder point
just wondering if maybe i didn't heat something up too much or what.
Old Sep 30, 2011, 12:29 AM
rampman is offline
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Still waiting on a picture of your pack and charger...
If you have correct voltage on balance tap what else can it be? Does your charger have a plug for the balance connector AND a discharge connector?
Rick
Old Sep 30, 2011, 05:31 AM
flypaper 2 is online now
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
What are the voltages of the individual cells?? If one is not high enough, it won't see it.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Discussion Balance charge won't complete Bob A Batteries and Chargers 2 Aug 27, 2011 06:53 PM
Discussion DSM2 6ch OrangeRX won't bind--won't even flash the LED horseflesh Radios 12 Jun 08, 2011 11:06 PM
Hummimgbird still won't fly oldman2 Micro Helis 8 Nov 24, 2003 12:40 PM
Slow stick still won't fly air4se Parkflyers 10 Aug 17, 2003 10:27 PM
Light batteries are GREAT ! Now my plane won't balance :( RPatrick Batteries and Chargers 9 Aug 06, 2003 11:42 AM
