Old Sep 23, 2011, 08:29 PM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
Do 5c charge rate batteries charge over twice as fast as 2C's?
Been thinking about getting a higher amperage charger but my batteries are currently limited to 2C so I have been also looking at gen aces.
Does balancing the last 5% of the battery take the longest though? The 5C gets you up to this point faster but I have noticed my icharger drops the amps when it gets towards the end of its cycle.
stgdz is offline Find More Posts by stgdz
Old Sep 24, 2011, 01:02 AM
rebell is offline
Find More Posts by rebell
JustFlying
rebell's Avatar
Joined Dec 2005
For the same good batteries like the GensACE, it all depends on the charger. Good batteries will not need much if any balancing so that does not take much time. I have seen chargers which will start at the current you set it, but as it the voltage goes up, the input current drop, and I am not talking about the CC-CV change over. (Constant Current - Constant Voltage) It is when it is supposed to still be in the CC phase when the current drops.
I don't know the iChargers, but the PL8 I am using charge at full set current until the battery reach 4.2v/cell where after it changeover to CV. You can set it to balance all the time or only in the CV phase.
The time it spend in the CV phase depend on the quality of the battery. A battery with a high IR will take longer to reach full charge after the changeover, meaning the CV phase will take longer.
So, to answer your heading question, for good batteries, yes.
rebell is offline Find More Posts by rebell
Old Sep 24, 2011, 06:24 AM
TreeDiver is offline
Find More Posts by TreeDiver
BrainFart RC-Pilot
TreeDiver's Avatar
Echt, Netherlands
Joined Aug 2003
fast charge mode at the iCharger is a great feature!
Indeed the last few mAh takes long....and this avoids this. Saves allot time...even with 2C charge.
5C charge is indeed much faster...and in combination with 'fast charge mode' at your iCharger ......very fast
TreeDiver is offline Find More Posts by TreeDiver
Old Sep 24, 2011, 09:07 AM
The Tug is offline
Find More Posts by The Tug
Barbados
Joined Jan 2011
As i understand it the I Charger in Fast charge mode cuts off at 4.15v with no balancing or going into CV phase,therefore it's quick but safe.
The Tug is offline Find More Posts by The Tug
Old Sep 24, 2011, 09:13 AM
crusey_aus is offline
Find More Posts by crusey_aus
Melbourne
Joined Aug 2010
Not quite right
Fast charge simply terminates when current drops to 1/5c during the CV phase
Normal charge is 1/10c current termination
Can also select when to begin balancing when balance charging (always, storage or cv)
Cheers
crusey_aus is offline Find More Posts by crusey_aus
Discussion 5C Charge rate batteries from NeuEnergy! sneu Batteries and Chargers 21 Jun 28, 2015 06:35 PM
Discussion What's a Safe Fast Charge Rate? ecarfar Batteries and Chargers 13 Sep 07, 2009 01:54 PM
Discussion 5C Charge rate batteries! sneu NeuMotors 4 Dec 08, 2008 05:50 PM
Discussion 5C charge rate batteries from NeuEnergy! sneu High Performance 42 Nov 15, 2008 05:11 PM
Question GWS lipos charge rate 1.5C? waldo p GWS (Grand Wing Servo) 7 Jan 26, 2005 01:58 AM
