Old Sep 27, 2011, 10:02 PM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
While integrating the FrSky telemetry into the 9X screen is very cool, to my mind the DHT-U unit is both simpler and provides better usability since the screen ends up at the top of the Tx. Or if you prefer, the FLD-02 is also a good option. Neither of these require any modifications at all to the Tx and give you access to the telemetry features of the FrSky product family.
kgfly is offline Find More Posts by kgfly
Old Sep 27, 2011, 10:16 PM
RC_Crazy23 is offline
Find More Posts by RC_Crazy23
RC_Crazy23's Avatar
United States, IL, Des Plaines
Joined Sep 2011
I was scratching my head looking at all the codes and attempting to mess with my Tx with no circuit soldering experience is a BIG NO NO for me. I'll have to stick with something plug n play.
Thanks for all the info n keep it coming!
RC_Crazy23 is offline Find More Posts by RC_Crazy23
Old Sep 27, 2011, 10:39 PM
Kalikikopa is offline
Find More Posts by Kalikikopa
United States, HI, Kailua
Joined Jun 2010
If soldering scares you, then it will cost a little more. I flashed mine with an $8 programmer. For $40 there is an add on board that will give you a really nice usb plug in the radio, and a backlight. it's a great deal for $40 and it's customer's service is via this board. Check it out, it's called spartieparts, and has it's own thread on here. Also for FrSky modules, the DHT-U looks totally cool. If I were to use that I would connect the module to a servo plug so it could be plugged and unplugged in case you'd like to change out modules.
Kalikikopa is offline Find More Posts by Kalikikopa
Old Sep 27, 2011, 10:54 PM
kgfly is offline
Joined May 2006
smartieparts: http://www.smartieparts.com/shop/ind...roducts_id=331
Old Sep 28, 2011, 01:34 PM
seuchato is offline
Find More Posts by seuchato
Joined Jun 2008
Consider it again: If you set up some alert levels in the DHT-U and change the model which uses another alert level you have to enter them each and every time you change forth and back in between these models. Th DHT-U simply cannot store these values and if it could, still it would not know which model you selected.
DHT-U as it is now is on the loosing end here. The only way to overcome this would be to store config data set with FDD or DHT-U or anything else in the rx.
Greets
chris
seuchato is offline Find More Posts by seuchato
Old Sep 28, 2011, 06:41 PM
kgfly is offline
Joined May 2006
Good point.
I believe they have some enhancements on the way for the DHT-U, perhaps a set of model memories is amongst them? You would still need to remember to change models on the DHT-U as well as the Tx.
Old Sep 28, 2011, 08:37 PM
springer is offline
Find More Posts by springer
treefinder
springer's Avatar
SE MI
rc crazy: I have a turnigy 9x radio with the smartieparts addon board. I like it a lot, but i'd have to say that it's a bit of a do-it-yourself kind of situation. That's not bad, just if you don't like tinkering, just want to fly, then it may not be for you. On the other hand, the smartieparts board goes in without soldering (uses pogo pins that touch on the correct traces of the main tx board) and it was an easy install. With this setup, you can reflash the firmware, load and save models to your pc (or just program them on the tx) and the new firmware adds incredible new capability to the tx, and it's easier to program than the original firmware to my mind. Also, the threads that deal with the tx, board, and other issues like telemetry are the most active ones on this forum, and have tons of info in them if you use the search function.
springer is offline Find More Posts by springer
Old Sep 29, 2011, 07:24 PM
RC_Crazy23's Avatar
Joined Sep 2011
Thank you Springer and everyone else that has given me info. I have spent my early days of rcgroups on the plane I put together and didn't realize that there's a section on telemetry. This new addiction of mine has gotten me in ZOMBIE mode.
BTW I like your avatar Springer.
Old Oct 15, 2011, 01:00 PM
deadaim57 is offline
Find More Posts by deadaim57
deadaim57's Avatar
United States, LA, Winnfield
Joined Jul 2011
Does anyone no what servo's will work with the rx?
Tom
deadaim57 is offline Find More Posts by deadaim57
Old Oct 15, 2011, 05:09 PM
kgfly is offline
Joined May 2006
Any modern servos will work with any modern Rx. Some servos (e.g. those from Futaba) have a thin key on the edge of the plug which can be easily trimmed off if it prevents the plug from seating properly.
Old Oct 15, 2011, 06:46 PM
MarLi is offline
Find More Posts by MarLi
United States, IN
Joined Jun 2011
Anyone using this radio? I'm considering changing out my stock Airfield radio with this one. It seems to be a steal for all the options that come with this $89.00 radio.
RC_...,
I don't have a lot of experience in RC, but I have many, many years of experience with electronics, so as a owner of a Hitec Aurora 9 and a FlySky TH-9X I can tell you that if you can live without ball bearing gimbals and touch screens, etc. - the FlySky/Turnigy Tx with a ER9X firmware and FrSky module is nothing to be ignored !
The ER9X firmware enables 95% of the functionality that Aurora has and the FrSky radio will failsafe your model like any other $500+ radio.
All depends on your skills. If you can add a Smartiboard ($45) and feel comfortable handling the soldering iron to install the FrSky module, you are big time in the game. If not, go for Aurora ( and you won't regret).
cheers,
Marian
MarLi is offline Find More Posts by MarLi
Old Oct 15, 2011, 08:30 PM
deadaim57's Avatar
Joined Jul 2011
O thanks for the info,I bought the radio and it will be here Monday.Also got 2 extra rx's.
Tom
Old Oct 15, 2011, 08:32 PM
deadaim57's Avatar
Joined Jul 2011
Originally Posted by MarLi View Post
RC_...,
cheers,
Marian
What is a smartiboard and where do ya get it?
Tom
Old Oct 16, 2011, 03:53 AM
MarLi is offline
United States, IN
Joined Jun 2011
Tom
http://www.rcgroups.com/forums/showthread.php?t=1338412
Old Oct 16, 2011, 02:11 PM
deadaim57's Avatar
Joined Jul 2011
Discussion New Flysky FS-TH9X 2.4ghz 9ch Transmiiter Overview RaidenTech HobbyPartz.com 3 Feb 17, 2012 09:37 AM
Discussion Leadershobby 9 Channel 2.4Ghz Transmitter and Receiver FS-TH9X only $53.99 rcgogo Radios 12 Aug 11, 2011 01:02 PM
Sold FlySky/Turnigy/Eurgle FS-TH9X 2.4Ghz 9ch MiG-3 Reno Rocket Aircraft - General - Radio Equipment (FS/W) 7 Jul 01, 2011 07:24 PM
Discussion Opinions on 2.4GHz Antenna teopbako FPV Talk 3 Apr 04, 2011 02:41 AM
