Old Sep 23, 2011, 04:00 AM
Dynasti is offline
Find More Posts by Dynasti
Joined Sep 2011
Upgrade ESC instead of engine AND ESC.
Hey guys. I'm quite new to this hobby and I'm enjoying every second of it.
I bhought a cheap plane that that was on 50% sale and I find very manouverable and very fun to fly. This is my plane.
I have 2 batteries, 1 with 1500mAh and 1 1300mAh. Can fly for 13 to 16 minutes till the battery is dead.
Now I'd like to upgrade the performance of the engine but I was wondering if I can upgrade my ESC 20a to 30a instead of buying a new engine AND esc?
The plane is so close to being able to climb straight up in the air, thats why i'd like to upgrade the performance just a litle.
I'm buying a new plane eventually but I'd like to try to upgrade this one first.
Thanks in advance!
Dynasti is offline Find More Posts by Dynasti
Old Sep 23, 2011, 04:56 AM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
If the motor runs cool now you way be able to run it at higher power without burning out. If you upgrade the ESC you will need a larger prop to get the improved performance.
RC Man is offline Find More Posts by RC Man
Old Sep 23, 2011, 05:02 AM
Dynasti is offline
Joined Sep 2011
Ah ok. Upgrading ESC does not improve the RPM? Just improves the strength of the engine? I don't know how to choose a correct propeller. All I know that the current blade measures are 7x? The information is not on the blade so I measured the length.
Old Sep 23, 2011, 05:58 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
DYnasti, welcome to RCGroups. The ESC does not "provide" current, the motor demands it. Changing the ESC to a higher rating will not increase power, the motor/prop combination will still draw the same current. You can increase the power available by changing both the motor and ESC or by increasing the prop size on your current motor. However, if you change the prop size without knowing the limits of your motor, you risk burning up both the motor and the ESC.
Azarr
Azarr is offline Find More Posts by Azarr
Old Sep 23, 2011, 06:35 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
If you're going to experiment, you need a wattmeter like one of these http://www3.towerhobbies.com/cgi-bin...eter&search=Go so that you can see exactly what amps the motor draws with each different prop. As has been said, you increase the power simply by increasing the prop size, but you need to make sure that the resultant increase in amps doesn't exceed the motor's, ESC's, or battery's spec.
With a model like that it's likely that they've picked a power system that's on its limits already, so you'll probably have to change the motor and ESC if you want to get more power.
abenn is offline Find More Posts by abenn
Old Sep 23, 2011, 06:46 AM
Dynasti is offline
Joined Sep 2011
Thanks for reply!
The motor doesn't get hot after flying for 15 mins, so I guess increasing the propeller size and pitch might do the trick. I'll give it a shot and feel how warm the motor gets.
Thanks!
I guess feeling the ESC and the motor temperature isnt enough?
Old Sep 23, 2011, 06:49 AM
Davee1 is offline
Find More Posts by Davee1
UK, Sussex
Joined Jan 2009
Check that the ESC and battery aren't getting hot (as well as the motor). Don't leave it for 15 mins though, check after 30 seconds or 1 minute of flight. You should really use a wattmeter though, or you risk burning things out. Only make a small increase in prop diameter or pitch, and not both at the same time.
ps, also don't run your battery till it's dead. Aim not to use more than 80% of the charge. Especially if you're drawing more current than the original setup. This will extend the number of times the battery can be recharged without losing performance drastically.
Davee1 is offline Find More Posts by Davee1
Old Sep 23, 2011, 06:50 AM
fmw is offline
fmw
Find More Posts by fmw
fmw
fmw's Avatar
Joined Jul 2009
What determines the airplane's power performance is a combination of the propeller and the speed at which it turns (RPM) along with the design and weight of the airplane. The spinning motor and propeller draws electric current from the battery through the ESC. The ESC is a rapidly moving switch which controls the propeller's RPM. The current rating of the ESC is a measure of how much current can be drawn through it without damaging it. Putting a larger ESC won't hurt anything. It will simply make your drive train a little more rugged. However, as stated above, it won't change the overall performance of the plane.
In order to change the performance of the plane, you need to change the propeller and/or the speed at which it turns. This may cost more than the plane cost in the first place because it might involve the entire drive train. I don't recommend you do this without knowing what you are doing and why. My advice is to enjoy the plane for what it is and, when you are ready for something more powerful, get a second plane.
fmw is offline Find More Posts by fmw
Old Sep 23, 2011, 07:12 AM
Dynasti is offline
Joined Sep 2011
Thanks for your advice. I don't literally fly till the battery is dead but as soon as I hear the motor speed decreases I stop the engine and land. But I guess thats 90-95% so still not good enough I guess?
I bhought 4 different propellers wich are close to my current propeller. Same lengths but different pitch. I have no idea what pitch my current blades have so I'll just have to test it.
Old Sep 23, 2011, 07:18 AM
Davee1 is offline
UK, Sussex
Joined Jan 2009
The battery will last longer long-term if you don't run it until the power drops off.
Be aware that without a wattmeter and knowledge of the maximum current of the motor, ESC and battery, you are taking a risk doing this, though it may be fine.
Dynasti is offline
Joined Sep 2011
Nice explanation, now I understand how it all works.
The airplane costs $333 without the discount in norway and a new motor costs around $30, ESC 30a for about $25-35. It's not a chrisis if I burn my current engine as I am soon buying a new plane so.
Old Sep 23, 2011, 07:24 AM
Dynasti is offline
Joined Sep 2011
How do you know how much power is left on the battery when you're flying? I know now that with my 1300mAh battery lasts ~11 minutes, dependant how I fly thought ofcourse. 10 minutes feels like 2 minutes when I fly so I find it a litle hard to guess how much power is left on the battery while it's in air.
I will be cautious when I'm testing so I guess I'll do fine(I hope).
Old Sep 23, 2011, 07:58 AM
flypaper 2 is online now
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Couple of other little things. Going up in prop diameter will give you more pulling power (going vertical) than pitch. More pitch works better for more speed. Using a timer is a good gauge for how much batt. power you used. Set for 5 mins for instance. Charge the batt and it puts back in 1040, your at your 80% Of course, you need a charger that shows the ma. put in. Hope this helps.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Sep 23, 2011, 07:59 AM
abenn is offline
Joined Jul 2004
How do you know how much power is left on the battery when you're flying? I know now that with my 1300mAh battery lasts ~11 minutes, dependant how I fly thought ofcourse. 10 minutes feels like 2 minutes when I fly so I find it a litle hard to guess how much power is left on the battery while it's in air. ...
The only way is to see how much power the charger puts back into the battery after you've flown. If your charger doesn't have a display, you can put a wattmeter in line between the charger and the battery, and it will display how many mAh go in. Ideally you should see a figure which is around 80% or less of the battery's nominal capacity, so for your 1300mAh battery your charger shouldn't put back more than 1040mAh.
You then use a timer to time your flights, instead of waiting for the motor to lose power. You find out what time will use 80% by trial-and-error -- start with short flights and then increase them until your charger is putting back about 1040mAh.
Old Sep 23, 2011, 08:07 AM
Dynasti is offline
Joined Sep 2011
Thanks for the tips. I sadly don't have charger with a display or a wattmeter, I'll get a more advanced charger eventually.
Thanks. Think I need a litle of both if the engine can handle it. I'll figure it out.
Question Ultima brushlessmotor/esc upgrade? FoamieFlying Electric Power Cars 6 Sep 19, 2011 07:59 AM
Discussion Madbeast ESC Upgrade with HobbyWing System hobbypartz HobbyPartz.com 0 Sep 08, 2011 03:27 PM
Question Substituting Product? (Proton ESC instead of Volcano?) hpiguy HobbyPartz.com 10 Apr 13, 2011 12:35 PM
Help! Upgrade NiCad Rx bat to Lipo but 7.4v instead of 4.8 or 6.0v…how??? WBFAir Batteries and Chargers 2 Jun 01, 2009 09:08 AM
