This thread is privately moderated by timecop, who may elect to delete unwanted replies.
Old Sep 29, 2011, 01:01 PM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
Originally Posted by Musgravehill View Post
timecop good work!
What about IMU algorithm? DCM, Kalman? Quarternions/Euler angles?
Do it have horizon drift when copter makes turn (centrifugal force appears and effects on accelerometers)?
I cant see any advantages and features for this price..
How good are your ARM asm skills? Then maybe you can find out.
I need to get myself a USB->CAN dongle (since I'm too lazy to tap the signal after CAN xceiver... though I should probably just do that) and see what format the IMU outputs data as.
Some preliminary testing I've found IMU spits out about 80? bytes of data at 1kHz, then 3 32-bit signed ints (these could be gyro values?) but I need to get this data in realtime and plot it to see the relation as its hard to compare by static analysis.
For some strange reason IMU lamely-encrypts the data, by XOR'ing its output with a random value decided at power up, so it's not exactly hard to figure out but I just wonder why they bothered.
IMU messages on the CAN bus take the most bandwidth, and are transmitted on channel 090 (lowest priority). There is other stuff on other channels (LED, GPS/compass), but I've not looked at them in detail yet. Only IMU appears to be scrambling data.
I find it kind of interesting that magneto is not inside the IMU cube - so there is a possibility the IMU isn't really doing any calculations and just outputs raw data and main controller is doing all the math. But then its weird that they would use a fairly large/expensive FPGA in the IMU .. Who knows. Maybe time will tell.
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Sep 29, 2011, 01:32 PM
Joshbb is offline
Find More Posts by Joshbb
Ironbridge (UK)
Joined Jan 2009
TC, is any of the cabling shielded or is it just standard multicore type stuff?
Joshbb is offline Find More Posts by Joshbb
Old Sep 29, 2011, 01:57 PM
Musgravehill is offline
Find More Posts by Musgravehill
Musgravehill's Avatar
Россия
Joined Feb 2011
Sorry, but Im noob in ARM. Arduino\AVR only. I trying to mod my megapirate copter..
May be it RAW data from IMU because its rate is 1kHz. Its quite high speed.
I advise you to put system in critical conditions like very fast oscillation or slow drift, or with centrifugal force. You`ll see accelerometers work, gyros response. In home you`ll see IMU work without GPS correction.
You are totally right! Its like sensor board for ArduCopter, which send raw to main processor. It realize DCM algorithm with Euler angles with given data.
Delicate analog sensors like AXRS620 put in separate box. I think, that the main board collects raw data from IMU, GPS and magnetometer. Thats why it can correct linear drift by GPS, and yaw gyro drift - by magnetometer. Or GPS\mag data cross-sending through main board to IMU and processing there. Result returns to main board.
Musgravehill is offline Find More Posts by Musgravehill
Old Oct 01, 2011, 05:09 AM
Joshbb is offline
Ironbridge (UK)
Joined Jan 2009
MrC. cables- shielded or not? I cant tell from piccies
thanks
Old Oct 01, 2011, 08:46 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
TC,
I would guess that they have done proper factory IMU sensor calibration including temperature range calculations and this is where it is stored/used for accurate sensor output for the flight controller.
Cheers,
Jim
Quadrocopter and Tricopter Mega Link Index
jesolins is offline Find More Posts by jesolins
Old Oct 02, 2011, 02:56 AM
eyeball is offline
Find More Posts by eyeball
eyeball's Avatar
United Kingdom, England, Puriton
Joined Mar 2009
Hi Guys,
ive been trawling the rc forums to get a much information as poss on this FC as I have a Copter control board, fy91Q and a simple KK and Im trying to build a super stable hex for steady hover and this seems tobe the new controller on the block and this would be the most expensive controller ive bought by far and I cant really afford to spend a 1000.00 gbp only to find its not all its cracked up to be.
So would you guys say this is the board to use at this price or should I look at another that could be around this price range??
Your all doing an excellent job...keep it up!!!
eyeball is offline Find More Posts by eyeball
Old Oct 02, 2011, 04:08 AM
timecop is offline
Joined Dec 2010
If your budget is 100gbp, you should probably look elsewhere.
Old Oct 04, 2011, 02:06 AM
hexa is offline
Find More Posts by hexa
hexa's Avatar
United Kingdom, Scotland, Edinburgh
Joined Nov 2010
The dji led is super bright. These would come in handy for led light projects. Any idea where I can source them. Part number any info?
hexa is offline Find More Posts by hexa
Old Oct 04, 2011, 02:21 AM
Photoship One is offline
Find More Posts by Photoship One
by Alary Design
Photoship One's Avatar
United States, AZ, Mesa
Joined May 2002
While not really spectacular, that's 5ms, and is probably more than enough for a stable platform. I was told anything below 25ms is acceptable for multirotor stability as things like motor response and etc are the biggest factor here.
That's an interesting comment from you because on Sept. 8th in another thread you said:
Mikrokopter main loop runs at < 500Hz, 480-ish or so.
If this flies properly, I'll be surprised. So for the last motor in the order, throttle change command could come as much as 1.8ms later.
As far as I know 25ms is far greater than 1.8ms. What gives?
Photoship One is offline Find More Posts by Photoship One
Old Oct 04, 2011, 04:08 AM
CaLviNx is offline
Find More Posts by CaLviNx
not surprised.........
CaLviNx's Avatar
Cyprus, Ammochostos, Liopetri
Joined Jan 2005
Troll Alert !!!!!!!!!!!!!!
CaLviNx is offline Find More Posts by CaLviNx
Old Oct 04, 2011, 06:35 AM
ddmt is offline
Find More Posts by ddmt
Gravity sucks :)
Indonesia
Joined Jul 2005
Yeah DJ is pissed because TC said his overpriced power distro board is uncool
ddmt is offline Find More Posts by ddmt
Old Oct 04, 2011, 10:25 AM
by Alary Design
Joined May 2002
numbers are numbers guys. numbers are unbiased. my questions stands.
Old Oct 04, 2011, 02:34 PM
timecop is offline
Joined Dec 2010
People I won't mention keep saying how "amazing BL-ESC" is amazing because it will respond in < 150ms normal ESC responds in. So apparently adding 2ms on input is "bad idea". And yea, troll alert, I should just delete all the stuff since its MY thread ^_-
Old Oct 06, 2011, 04:40 PM
eyeball is offline
eyeball's Avatar
Joined Mar 2009
Hi timecop
With regards to my post about buying a quality flight controller and my price range.. I think you might have misread my post as I my price range is not 100.00 gbp but 1000.00 gbp...so how does the DJI stand up against other FC's in the range as I can pick one up tomorrow if there worth it?
Regards
Paul
Old Oct 07, 2011, 10:25 AM
hexa is offline
hexa's Avatar
Joined Nov 2010
Eyeball Get a mikrokopter set up. It has more features and far better support now. You have the option of speaking to the holger the creator personally he replies to emails. Not like dji who seems to be cocky and thinks we the costumers must beg for new features, answers and email reply.
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20265 Jan 01, 2016 09:39 PM
Discussion DJI - WooKong eStab for Scale sidneyw Scale Helicopters 97 Dec 30, 2012 11:48 AM
Cool Karbonic-XXL 50CM DJI WooKong-M frame superdave42 Multirotor Talk 12 Mar 09, 2012 11:01 AM
Discussion DonsRC KA20-22L technical "review" CuStOm Power Systems 13 Jan 18, 2008 10:57 AM
